Hot Rods Fastest V8-60 ?
Discussion in 'The Hokey Ass Message Board' started by khead47, Dec 17, 2020.
  1. blowby
    blowby
    from Nicasio Ca
    Wow 14:1. Must take some careful planning to keep breathing adequate in the chamber. Sounded great I'll bet.
    On my street engine I figured the best path was a huffer. Just push it through.:)
  2. khead47
    khead47
    ^^^^^^^^^^ Would love to see what the dome on a 14 to 1 piston looks like.
  3. lippy
    lippy
    from Ks
    That's some pretty good squeeze! Lippy
  4. RichFox
    RichFox
    img015.JPG 50 some year old picture img015.JPG from my misspent youth
    stillrunners and harpo1313 like this.
  5. Marty Strode
    Marty Strode
  6. RichFox
    RichFox
    Yes. Didn't spend much time helping this car. I mostly wanted to go in straight lines. This was Chuck Foley's midget. He also had a 270 Offy powered sprint at that time. Billy Cantrell was driving as I remember. Chuck was a foreman at UAL at the time. My shop stewered was his mechanic, It was a fun place to work then.
    stillrunners and tractorguy like this.
  7. Pete1
    Pete1
    from Wa.
    Nothing much to see. It is as flat as a table top. It has to do with math. A single plane circle has less area than a spherical circle. Remember, this is a flathead, NOT an overhead engine. Totally different concept.
  8. stanlow69
    stanlow69
    The one with Ardun heads ?
  9. Speed Gems
    Speed Gems
    Let me help you out on the crop job with those @RichFox .
  10. khead47
    khead47
    Pete1.......I was thinking of the area in head for valve clearance making it hard to get that high a CR.
  11. RichFox
    RichFox
    I made the head for my 32 Plymouth V4/GMR Bonneville car. By the time I had cut clearance to open the valves, and made a tapering ramp from the valve area to the cylinder, 10 to 1 was very hard to get. I had flat top pistons and the head was flat about half way across the cylinder. 14 was impossible. This was with a 4 5/8 stroke 3 7/8 bore cylinder. Should have been easy to build compression.
  12. khead47
    khead47
    Rich. That was my thinking.
  13. Pete1
    Pete1
    from Wa.
    I am not the guy that figured it out. I just followed what others did.
  14. 49ratfink
    49ratfink
    a buddy stored his 37 with a V8-60 at my house so I took it for a spin every time i needed my garage for my projects.
    from my experience they don't go over 40 MPH.... since I only drove around the neighborhood.
  15. cheap-n-dirty
    cheap-n-dirty
