Projects Fat fender bumpers ideas
Discussion in 'Traditional Customs' started by topher5150, Feb 11, 2022.
  1. topher5150
    topher5150
    I'm on another one of my ADD rabbit holes again, and I was thinking about some affordable bumper options for my 47 Ford coupe just in case I can't salvage mine.
    dana barlow likes this.
  2. Rickybop
    Rickybop
    Polished tubing.
  3. topher5150
    topher5150
    I was thinking more OEM. I know the ribbed Plymouth bumpers are going for gold, but would a Chevy bumper be a cheaper option that would fit on my car?
  4. Tim
    Tim
    from KCMO
    Can we see the condition of your current bumpers?
    I always thought AD chevy truck bumpers looked like the could fit
  5. Rickybop
    Rickybop
    I think I read that the reproduction 1949 through 1952 Chevy bumpers are available for reasonable prices.
    topher5150 likes this.
  6. dana barlow
    dana barlow
    from Miami Fla.
    Custom made Nerf bars have been one of my fav. for a long time,on almost anything.
    I do think they look best on cars with rolled pan.
    Tman and El Mirage Garage like this.
  7. topher5150
    topher5150
    This is the best pic I have right now. The driver's side of the bumper, and the horn need to be straightened out. I can get a pic of the back bumper later, but they're both peeling and pretty pitted and rusty.
  8. Tim
    Tim
    from KCMO
    That’s pretty straight I’d be tempted to take them down to bare metal and find a suitable finish maybe from KBS coatings to make them look nice
    They’ve got some great stuff and even a new clear that’s supposed to be good for bare metal
    I spent a long time finding bumpers for my 46 that were better than I had because the repops are so much cash.
    As an aside 46 bumpers irons and over riders are not the same as 47-8 and won’t bolt on with out modification.
  9. topher5150
    topher5150
    Does it take much to straighten the bumper and horn? They're aren't horribly mangled but they're bent enough to notice.
  10. 19Fordy
    19Fordy
    What does "horn" refer to? Is it the front end of the frame rail?
  11. El Mirage Garage
    El Mirage Garage
    Absolutely!..Almost anything with a proper roll pan can be very cool with nerf bars and you can create a style that’s all your own.
  12. topher5150
    topher5150
    Sorry, not the frame horn, but the two bumper guards. I don't know the proper old-timey term.
  13. 19Fordy
    19Fordy
    topher5150:
    Consider making a custom bumper out of the bumper you already have.
    For instance:
    Section the bumper guards on the stock bumper to make them look less prominent, turn the bumper upside down and see how it would look with sectioned bumper guards and turn the sectioned bumper guards upside down on the upside down bumper.
    Just Gary and topher5150 like this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    fauj and Tim like this.
  15. Tim
    Tim
    from KCMO
    They are pretty thick I bet you can hammer them into shape with out going to far. Send me a DM
    With a shot of the dents etc and I’ll walk you threw how I’d go about getting them in better shape
  16. I'm a fan of removing the bumper guards. The bumpers look cleaner without them to my eye.
    If you're building a custom...then looking for a licence surround from slightly newer/different vehicle is another way to go. For example, 50's era Pontiacs were used a fair bit.
    40FORDPU, '28phonebooth and 302GMC like this.
  17. Torchie
    Torchie
    Don’t give up on the 49 Plymouth bumpers.
    I’ve been using them on some builds since the 70’ s when you could buy them cheap.
    The last set I found on FB market place got $150. Be aware that you may end up using 2 fronts. Regardless of what you may read the fronts and back aren’t the same. The rear one wraps around the corner much farther then the front.
    You can trim it done to fit your needs.
    I’m using them on my current build. Custom 49 Dodge Coronet.
    I will have to lengthen the front bumper as the Dodge is much wider then the Plymouth.
    Torchie 90FC82CC-3A67-4991-ACD4-CFB5ECA0B2BB.jpeg 33D764C2-4711-43E7-82DE-6E3CD6FD6645.jpeg 74A479A7-0E53-4AD9-9769-A31B22DC4FE4.jpeg
    bchctybob, fauj, Packrat and 2 others like this.
  18. topher5150
    topher5150
    I haven't given up on those either, to bad they're in Ohio. If they're the set I saw on facebook
  19. Torchie
    Torchie
    Well I bought last summer and they were in Ohio. But now they aren’t. So who knows. I’ll keep my eyes peeled for any more.
    Torchie
  20. evintho
    evintho
    Don't discount repairing and chrome plating your own bumpers. The local shop who just did mine are very reasonable and do quality work. Looks like $385 ea for your bumpers and $85 per guard. One of my guards had a pretty good dent and they repaired it for an additional $15.
    https://www.atbumpers.com/ford-car
  21. Rickybop
    Rickybop
    Not cheap, @evintho ...
    But not nearly as expensive as I might've guessed. Doable.
    And look how nice.
  22. Quick Glow might clean them up enough to use for a while until you can rechrome or find an option. I agree with @dana barlow as well NERFS!
  23. topher5150
    topher5150
    I think I may have found something. Surprised that I've never seen something like this before.
  24. 19Fordy
    19Fordy
    Keep in mind that photo is distorted.
    However, the nerf bar idea looks good.
    That Chevy liscense frame might look better if combined with some custom made horizontal bumper.
  25. Jalopy Joker
    Jalopy Joker
    take a look at 46-48 Merc - blue one has custom bumper 20220211_193348.jpg 20220211_193443.jpg 20220211_193654.jpg
  26. Flat Roy
    Flat Roy
  27. jnaki
    jnaki
    upload_2022-2-14_3-50-22.png @TrailerTrashToo has a similar design idea an open nerf bar design to keep the front wide coverage, but to not have a solid bumper taking away from the build and style. Nice…
    upload_2022-2-14_4-9-49.png Picture the tubular nerf bar bumper on the reddish 1947 Ford Coupe and it would fit right in to the 2022 Valentine’s Day display post for today.
    Hello,
    My brother and I always like the custom nerf bars that we saw on hot rods and show cars. Practical street bumper protection was not a topic of discussion, as the nerf bars offered little in the way of bumper to bumper collisions. But, at the time, no one thought of the outcome for their hot rods that way. It was a pure styling issue and the custom made nerf bars on just about any coupe or sedan made the hot rod cool looking.
    When we were building our model cars, from the t-bucket to coupes and sedans, we had access to some small wax rods that were able to be shaped to any design with a little heat applied. They were jeweler’s custom design implements. Curving around in any design, melting short portions together then creating the whole ring design in a “lost wax” pour design was very cool way to make custom jewelry.
    But, for us, we had custom made front and rear nerf bars that were similar to the original chrome bumper, but the center section was taken out and the cool round bars curved back to fit the form of the front fenders or tires.
    For your 1947 Ford coupe, the front is a little large and the stock or smooth front bumper, as nice as it looks, shows the front end as being big/and sticks out. But, if the tubular nerf bar is in the same place, the color of the car comes through and the style would be a little less accentuating the large front end design.
    Jnaki
    Over the years in hot rodding, there were plenty of hot rod shops and local welding shops that could create custom nerf bars to fit every front fender arrangement. The rears were just as nice when they had custom fit custom made nerf bars, too. But, alas, the nerf bars were not for everyone.
    https://www.mcmillanrodandcustom.com/nerfchinbars.html
    In doing some research, if people and shops were still doing some custom nerf bar designs and applications, I came across this company. Mc Millan Rod & Custom
    Their work seems pretty good and the Midwest folks, probably already know of this custom hot rod shop.
    bchctybob and TrailerTrashToo like this.
  28. j hansen
    j hansen
    Thats looks good and really cheap!I paid for the bumpers, horn and the special bolts 900 dollars here in Sweden! Skärmavbild 2022-02-14 kl. 13.36.58.png
    210superair likes this.
  29. topher5150
    topher5150
    That's almost what I paid for my car. Kind of ****s that anytime those deals pop up like that I would end up driving 5-6 hours one way.
  30. TrailerTrashToo
    TrailerTrashToo
    This nerf bar came as a weld together kit from Speedway - on sale for $78.99 at this moment.
    https://www.speedwaymotors.com/Nerf-Bar-Kit,3401.html
    Ed Smoot of Smooth Engineering came up with the idea of vee-ing the front bumper to match the angle of the front valence.
    Russ
    jnaki likes this.
