Projects Father/Son 29 RPU - first build
Discussion in 'The Hokey Ass Message Board' started by TBone69, Jul 21, 2013.
  1. TBone69
    TBone69
    from NJ
    Well it's been awhile since my last update so it's about time.
    Cleaned up and painted a few items, wishbone, front axle, spindles and rear bones.
    Then a few weeks ago after much research I added a Hobart Handler 140 mig and auto darkening mask to the tool box.
    So today on the hottest most humid day I decided it was time to weld.
    The rear cross member was cracked. I am a beginner welder but an excellent grinder :)
    After some grinding and dremelling out the cracks. I also drilled the end of the cracks but don't have a pic.
    Prepped the underside as well
    Time to weld, I know it's not the best looking bead but I got better the more I did
    Grind, weld, repeat and it looks pretty good.
    Took a break for lunch and did get much else done. Too damn hot.
    Next up need to straighten or replace front frame horns and weld in the front cross member.
  2. TBone69
    TBone69
    from NJ
    Got some more work done this weekend. Tackled the center cross member.
    Here's what we started with.
    I started a new thread pertaining just to the frame rehab. You can find all the steps over here http://www.jalopyjournal.com/forum/threads/model-a-frame-rehab.941917/
    I will continue to post before and after pics on this thread and continue with the progress of the entire build.
    Robert Crosse likes this.
  3. TBone69
    TBone69
    from NJ
    Frame horns straightened, motor mounted to help place and square up replacement cross member. Got it clamped in nice and tight. Need to add a couple tack welds to hold everything in place. Then motor comes back out for final welding.
  4. Fordgasser1
    Fordgasser1
    from Jersey
    Nice job guys! Keep up the good work! See you on the beach in 2015!
  5. TBone69
    TBone69
    from NJ
    Well the Frame is 95% completed!!!!! I say 95% because I found another area that need some addressing while painting. So I will go back replace a small area and touch up.
    Check out my Frame Rehab thread for all the steps it took to get to this point.
    So for now here is the frame in all it's glory!
  6. TBone69
    TBone69
    from NJ
    While waiting for paint to dry I figured I would work on one of the many small jobs that are part of this build.
    For the front suspension we will be running an aftermarket reverse eye spring. This one came with rubber bushings and the stock style shackles won't work with them.
    So after popping out the rubber bushings I test fit the stock metal bushings and the result was too loose.
    So armed with my 1950's Craftsman/Atlas 618 lathe and some s**** round stock I got to work. First by centering the piece.
    Then I found a drill bit just undersized so I could ream out to final size and started making metal chips.
    Once all the way thru I parted it to length and ended up with this.
    Using a bushing driver I installed into the spring eye and it's a tight fit. 1 down 1 to go.
  7. kidcampbell71
    kidcampbell71
    Old equipment to the rescue! Cool man. Looks good.
    1927graham likes this.
  8. TBone69
    TBone69
    from NJ
    Man what a weekend, beautiful weather and made some good progress not as much as I wanted but that's how it always seems to go.
    The plan for the front suspension is to drop the drop the front end and keep the mechanical brakes. SO I went about collecting the parts that I needed. Model A wishbone, 34 front axle, 34 perch pins and reverse eye front spring and bolt it all together, sounded easy enough. Well at this point I think I have had to repair, refurbish, modify and even make a few parts to get everything together.
    First the Model A Wishbone, after cleaning it up and painting last summer I discovered it was bent. No biggie, put it in the press and gave it a few pumps and good as new.
    Now the ball end was just plain wore out.
    So short of finding a new wishbone and since I spent the time straightening I would give it a go trying to weld it up. Weld, Grind repeat and though not perfect, and I plan on running the rubber ball on it, I am pleased with my work, 1st time trying this and looks way better than it was
    Atwater Mike and kidcampbell71 like this.
  9. TBone69
    TBone69
    from NJ
    Now that the wishbone was complete move on the the 34 axle, though in good shape it had some home made shock mounts welded on and since I am running friction shocks or original style shocks I didn't need them.
    After a little grinding of the weld beads and a few whacks with the BFH old brackets were off
    Little grinding and wire wheeling all cleaned up.
    Then I put my painter to work priming
  10. TBone69
    TBone69
    from NJ
    Now on to the spring and a little internet magic of stepping back in time as I admit the following happened a month or so ago.
    Being this was an aftermarket spring the sping eyes were larger than stock and came with rubber bushings. Wanting to run the stock style shackles I ditched the bushings and tried my hand at making my own. I then discovered the rear spring bushings had the correct OD but the length was too long. No worries just parted them to lenght on the lathe.
    Two bushings ready to install
    After installing and running a reamer thru the bushings to clean up any burs from cutting the stock shackles fit nice
    While I was on a roll I discovered that the Reproduction 34 perch pins have seem to use a different size busing as well. Again armed with rear spring bushings I had to turn them down a thou or two, lost my notes or I would be more specific, test fit the perch pin and it's just about right, needs a little persuasion with a bushing driver.
    Parted to length and installed.
  11. TBone69
    TBone69
    from NJ
    Now test fiting the wishbone to the axle I discovered the 34 axle is about 1/4" shorter in height than the A axle.
    A little search on the HAMB and I find I can buy some spacers from McMaster but I have a lathe and a pile of round stock. I'm gonna make my own, only took 3 to make 3 good ones :)
    Atwater Mike likes this.
  12. TBone69
    TBone69
    from NJ
    On to the spindles to install new bushings and grease fittings.
    First thing first is to knock out the old bushings, hey where's my bushing driver? Cant find it so again armed with my trusty lathe and a piece of round stock I made my own.
    While I was whittling metal into a useful tool, I figured now would be a good time as any to put my helper to work with the engine brush kit and clean out all the bores and grease p***ages on the spindle in prep for new bushings and grease fittings.
    Armed with my bushing driver , we installed new bushings and new grease fittings
    Being a budding 12 year old car designer I figured it's time to learn how to ream a king pin bushing :) Well when I opened up my king pin reamer I found my king pin bushing driver, oh well it was more fun to make my own.
    The old man was wearing him out and he looks like he is about to fall asleep so I let him call it a day to retire to the cool ba*****t and XBox to play a game of Halo
  13. TBone69
    TBone69
    from NJ
    Laying out the parts to get ***embled.
    One area I forgot to do***ent was all the work that had to go into the spring.
    The center bolt that came with the spring had a round head and as we all know the A cross member has a square hole to locate the spring. Unfortunately it was as easy as to just use a stock replacement bolt. The replacement bolt was bigger in diameter. So after reading up on how to drill spring steel, use slow speed, plenty of pressure and constant flood of oil I only burnt up 1 bit.
    Once the center bolt was in trimmed to length and peened over. The spring clamp brackets were stock replacements and too long, cut them down and re drilled them. everything bolted up nice and painted the spring.
    I can see the end of the tunnel at this point and have visions of the front end once again supporting the ch***is.
    With a little help from my wife, my big *** Dewalt clamp set up to push and a few choice words we persuaded the wishbone, axle, spacers and perch pins to fall into place.
    Made a few nicks and gouges in the paint so off to the back yard paint booth for a little touch up work and it's starting to look like something.
    Now for a little game, whats wrong with this picture :)
    While the paint is drying I figure its time to hang the spring from the cross member. It's at this point I realize I am missing the bottom plate that holds the spring in. A little rummaging around I find it, and after cleaning and painting I get to work.
    Now at this point I would like to say and now the completed goal of the weekend. At this point I discover the spring pack is too short by 1 leaf and can not be tightened anymore. Well at this point I am thinking I love working this project but I hate working on this project. I am just too impatient but yet find the whole process teaches me patience.
    So after a lap or two around the house with a frosty cold one I do what anyone of us in this predicament would do. That's right post a want ad on the HAMB for a single spring leaf and withing less than 24 hours HAMB to the rescue.
    Hope to get it hung this coming weekend and start prepping the banjo rear for a full rebuild.
    kidcampbell71 and patmanta like this.
  14. TBone69
    TBone69
    from NJ
    Finally got the front axle ***embly back in. 34 front axle, 34 perch pins, reverse eye spring and model A wishbone.
    Being that the eyes on the spring are reversed the spring spreader wont work. So what to do.
    I bolted up one shackle then put a 2x4 under the spring eye on the other side. Then I used two ratcheting tie straps and a racheting clamp and kept tightening until the shackle slid in.
    Tomorrow we start tear down of the banjo rear.
  15. TBone69
    TBone69
    from NJ
  16. TBone69
    TBone69
    from NJ
    Quick update.
    After the rear sitting apart during the winter I finished it up a few weeks ago. Well almost done, the hard parts are finished anyway.
    Over the July 4th weekend I needed to clean the garage/workshop which desperately needed it. My son and I got after the rear spring in preparation of mounting the rear.
    We took a 10 leaf A spring, removed 3 leaves and reversed the main leaf. Still need to clean it up a bit, trim the second spring and chamfer the edges.
    I made a tech doc here
    http://www.jalopyjournal.com/forum/...-a-model-a-rear-spring.1025063/#post-11597682
    I have also changed the ***le of the thread to Father/Son 29 RPU build to better reflect the direction we are headed. Saving our pennies and nickels for Hershey this year in hopes of scoring the body.
    Sent from my SCH-I545 using H.A.M.B. mobile app
    brEad and kidcampbell71 like this.
  17. TBone69
    TBone69
    from NJ
    Made some good progress this weekend, got the rear hung back in the ch***is.
    Rear bones bolted on, rear painted, helper cleaning out the bushing holes
    Hard at work bolting in the rebuilt "Hot Rodded" rear spring
    Working smarter not harder using a furniture dolly to get the rear in place and drop frame down instead of lift rear up.
    Now we work harder and smarter since reversing the eyes on the main leaf negates using the spring spreader. Using a couple blocks of wood, grease, ratchet strap, clamp and some stern language to persuade the rear into position.
    Viola!
    After getting the rear mounted and spring spread we discovered the spring was loose in the cross member, we removed a couple leaves. It's an easy fix just need to get the spring pads designed for a 7 leaf spring instead of the 10 leaf that I have.
    kidcampbell71 likes this.
  18. timwhit
    timwhit
    Love the thread! It's great to see your son involved. He's learning more than just how to put a car together. Keep us posted. Tim
  19. What Tim said, you are lucky to have a son who's interested in hot rods, lucky man!!
  20. TBone69
    TBone69
    from NJ
    Thanks guys, he's into imports but I am slowly converting him :)
  21. TBone69
    TBone69
    from NJ
    Started working on fitting Wide Five brakes this weekend. I will be running Wide Five mechanical brakes to be different.
    I originally had planned on using the A Spindles but I could not get them to fit the 35 drums so I decided to keep the 35 spindles knowing I will need to modify the steering arms.
    I started with the right side spindle. Since the 35 Ford used a cross steer the steering arm has a second mounting point that will not be used I cut it off.
    Before
    After taking a cut off wheel to it
    A little grinding and work with the belt sander
    Then it was time to mock it up on the axle. After mixing and matching parts I ended up with Model A King Pins and Model A brake actuators which are not pictured. For the mock up I used the bushing that were already in the spindles, I'll have to order a new set.
    pat59 and kidcampbell71 like this.
  22. Donald A. Smith
    Donald A. Smith
    from Brook In.
    I Have wide 5 stuff I will take pictures tomorrow. Send me a conversation on the Hamb
  23. TBone69
    TBone69
    from NJ
    Made some progress, she is almost a rolling ch***is!
    Put some feelers out a month ago for wide five stuff and had tons of responses found what I needed locally.
    Had to order some odds n ends and finally had some time this weekend to get to work.
    Bolting up the 36 Wide Five brakes to the 36 spindles mounted on a 34 axle.
    These came off a running car and where good to go.
    Then I slid on the drum
    Bolted on the other side and viola front end is done, well almost still need a tie rod and bolt on steering arm
    Now onto the backs, again using a set of restored brake ***emblies I started test fitting.
    Loaded backing plates bolted up with new mounting hardware., just had to sand of the paint from the inner cir***ference to fit onto the Model A rear.
    Now on to test fitting the Model A rear radius rod, and it hits the brake lever and shaft.
    Hmm what to do, get grinding that's what!
    Grind, Test fir, Grind Test Fit, and Repeat., Yes this the the left side, right side pics didn't come out
    Now during all this test fitting I discovered a couple of my new reproduction mounting bolts were not fitting. The shoulders on the non fitting bolts measure .497 were as the ones that fit were .495 so I took .002 off the non fittings bolts and made them fit. They just don't make them like they used to. Next time I'll just spend the time repairing the threads on the originals.
    Taking off .002
    Fits like it should have in the first place.
    Got both sides bolted up, drums cleaned up and cleaned up some old bearing to test fit the drums.
    Next bolted on some roller using lug nuts from my 90 mustang 5.0 from back in the day, gotta love that the lug nuts didn't change! Ran out of daylight and pushed it in for the day. Need to get two more wheels for the rear!
    Made a list of parts needed next, new wheel bearings front and rear, seals, grease fittings, need to replace a wheel stud and get 20 new lug nuts, tie rod and ends and a bolt on steering arm.
    Might have to invest in a space heater for the garage to keep the momentum going thru the winter!
    kidcampbell71 and MJW like this.
  24. TBone69
    TBone69
    from NJ
    Made a trip up to Saugerties NYthis morning and picked up 6 wide five wheels, she's a roller again!
  25. TBone69
    TBone69
    from NJ
    [​IMG][​IMG][​IMG]
    Scrounged up a 36? Style tie rod off the 'bay and want to run above the wishbone. After some contemplation time with a cold beverage and some discovery on the HAMB I will need to ream the steering arms and most likely have to heat and bend them up a little.
  26. Great thread!!
    My 9 year old and I are about to embark on a similar adventure
  27. TBone69
    TBone69
    from NJ
    Finally broke down and bought a taper reamer to ream steering arms to move tie rod above wishbone in hopes of not having to bend steering arms
    Armed with my trusty cordless drill and some tapping fluid I got to work. Oh and I measured length of taper on the tie rod end and marked the reamer with some tape as not to go too deep. Cut some, clear chips, test fit and cut some more
    ***embled tie rod and checked clearance
    Now lock to lock, uh oh
    After some head scratching I remembered I had to make up some spacers to take up the space between the 36 axle and wishbone and they where mounted on the top of the axle.
    Figured if I moved them from top of the axle to the bottom of the axle it just may work so my helper and I tore into the front end and took it all apart.
    Here's the offending spacer on the floor
    Spacer now moved below the axle
    My main man, helper, gopher, and muscle
    As we we where getting ready to bolt the axle back in the crank handle bracket basically just fell apart. Cheap repo garbage.
    Luckily I had acquired an original along the way, just had to dig thru all my bins of parts before I found it.
    Put my helper to work
    Once the axle was back in and tie rod installed we tested lock to lock and bingo room to spare !
    Now I just need to shorten the tie rod a bit and figure out how to mount hoop steering arm
    bct likes this.
  28. MJW
    MJW
    from NJ
    Hoop replaces two upper bolts that bolt the backing plate to the spindle.
    Sent from my Nexus 6P using The H.A.M.B. mobile app
  29. MJW
    MJW
    from NJ
    Probably have some mechanical brake interference.
  30. TBone69
    TBone69
    from NJ
    Guess I should have elaborated a bit. On the 36 spindle the spacing and size for the holes that the steering arm would bolt to are closer together and smaller in diameter than say on a 37-48. Found a thread where someone welded some 1/4" square bar stock to the edges, welded up the holes and redrilled. Picked up some 1/4" bar stock so thinking of this route but still investigating others.
    As for interference I think I am good, but will double check
