Fatman Subframe Info Needed
Discussion in 'Off Topic Hot Rods & Customs' started by Gary Sleeman, Mar 16, 2025.
Tags:
  1. Gary Sleeman
    Gary Sleeman
    from Central NC
    I purchased a 55 Studebaker Champion project 10 years ago that had a Fatman Subframe installed. I have pulled this thing out of storage and to my garage to dismantle and noticed no coils on the front just a threaded rod to set the height. With Fatman out of business I have no way of knowing what coil over I should be looking for. I have searched the net for instructions but found nothing! Anyone have their instructions laying around that have used this product? Thanks!
  2. Sandcrab
    Sandcrab
    I used the threaded rod to set the ride height I wanted so that adding the engine and body parts would not change the stance. Then by weighing the front of the car with rods removed using a formula for the leverage on the A arms I was able to get the springs that gave the planned ride height.
    squirrel likes this.
  3. As @Sandcrab states, best way to get coils, if weigh car loaded, front and rear axle seperately, then consult Eaton Spring or other vendors to get coils to support that weight.
    rockable likes this.
  4. mgtstumpy
    mgtstumpy
  5. mohr hp
    mohr hp
    from Georgia
    I have that front end under my Stude. They used various Mustang 2 and Fox body springs, depending on which engine you use. I know that 5.0 springs were too heavy for me, I think I used 302 V8 M2 springs, but I can check for you if it helps. I had an all iron 454 in mine, and it rode/drove well.
    Algoma56 and pprather like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    aftermarket IFS is strictly off topic here. this is a traditional hot rod forum. moving this to the off topic forum
  7. Gary Sleeman
    Gary Sleeman
    from Central NC
    Sound like a good plan, I'll have plenty of time to source the scales.
  8. Gary Sleeman
    Gary Sleeman
    from Central NC
    Thanks for the reply, I'm planning on an L29 454 with a L480E. I will probably be reaching out to you!
  9. mohr hp
    mohr hp
    from Georgia
    I know I have the exact spring info here in my records, I'll dig it out later. Know that my car sits very low though.
