Fatman Ultra Low MII for 49-54 Chevys??
Discussion in 'The Hokey Ass Message Board' started by louder50, Aug 4, 2006.
  1. louder50
    louder50
    from Michigan
    Anybody know about these? I was told this is the MII setup that lends itself best to bagging a 49-54 Chevy. Can I run OEM arms and struts with this? Do you have to notch the frame or make any other changes? Would I be better off modifying the original front susp on my 50 Coupe for bags in some other manner?
  2. Hotrob
    Hotrob
    from DFW, TX
    Check www.50chevy.com web site, he has a series about the intall of that kit on his chevy.
    Hotrob
  3. Killer
    Killer
    I've never understood why someone would clip a car that already had IFS... especially a Chevy.
    stupid dogbone steering on the Chevys can be fixed with a rack and pinion.
    bolt on some disc brakes, dropped spindles and bag the stock stuff...
    my opinion anyway... and I get paid to fabricate!
  4. 53sled
    53sled
    from KCMO
  5. Hotrob
    Hotrob
    from DFW, TX
    Is there a direct fit rack and pinion setup for these? If so who makes it or what fits?
    Hotrob
  6. Killer
    Killer
    not anymore. Butchs Rod Shop used to make one that used a 93 Chevy Cavalier rack...
  7. 53sled
    53sled
    from KCMO
  8. 50chevy
    50chevy
    RE:
    Yes
    Here is partial info/pics on the install (page not completed)
    http://50chevy.com/ifs.html
    No, need to use tubular arms w/o struts.
    yes you need to notch teh frame for the rack.
    IF you want to save $$ you could. There is still issues with header clearance and the mustang2 does perform better.
    IMHO the stock ifs work well and rides good.
    FYI, Dirty hooked up a stock IFS with a saaab rack and did a tech post but the photos seems to be missing.
    http://www.jalopyjournal.com/forum/showthread.php?t=97657
    Another rack article
    http://www.y-blocksforever.com/tech/html/rpinbird.html
    Another thing people may not realize about the stock IFS is all the bushings are metal to metal. So there designed to be jacked up and regreased every 1000 miles not alot of people performed the maintenance so therefore alot of the stock ifs are worn out.
    Hope that helps.
  9. 50chevy
    50chevy
  10. louder50
    louder50
    from Michigan
    I was worried about having to use the tubular lower arms, that's why I am leaning towarsd the Chassis Engineering bolt in one. I have a full set of rebuilt OEM arms that I could run on the CE unit, and I still like the idea of retaining the struts on the heavy 50's cars. Am I off track?
  11. Slide
    Slide
    According to this, not at all.
