Folks Of Interest Fatman upright issue...maybe
Discussion in 'The Hokey Ass Message Board' started by StefanS, Jan 13, 2022.
  1. StefanS
    StefanS
    from Maryland
    Hey there everybody. Quick question for those who have Fatman dropped uprights. I got mine delivered today (for my '49 Ford if that matters). I went to push the pins out of them since they come installed in the bushings, but both pins were super tight and had to be twisted back and forth to get them out. I'm concerned that them being that tight will cause a ton of bushing wear. Do they all come that way or is my set the oddball?
  2. jaracer
    jaracer
    I'd give Fatman a call.
    Hnstray likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Did you let them warm up ?
  4. lostone
    lostone
    from kansas
    I agree, let them get to room temp then check again. Also see if they have any kind of grease or film to prevent rust on them
    IF they have any grease or coating on them clean the pins and bushings with either carb or brake cleaner then try again. If they stay as stiff as you say even after temp and cleaning I'd be worried. Shouldn't be that tight.
  5. StefanS
    StefanS
    from Maryland
    If I slide the pins in either the top or bottom bushings individually they're fine. It's when I try and put them through both at the same time that theres the problem
  6. AngleDrive
    AngleDrive
    from Florida
    Not honed properly.
    2OLD2FAST and Nailhead Jason like this.
  7. StefanS
    StefanS
    from Maryland
    That's what I'm worried about. I'm hoping somebody else that has used them will jump on here and tell me if theirs were like that as well
  8. dalesnyder
    dalesnyder
    As long as they don't need more than a small hammer it's good.
    That's the way I have been taught.
  9. krylon32
    krylon32
    from Nebraska
    They should be a slip fit with a little white grease. Should go in without any force.
    Nailhead Jason likes this.
  10. Nailhead Jason
    Nailhead Jason
    If they are too tight they will be a bear to steer and will wear the bushings out prematurely. Send me a message to f you need them re bushed. I have a good friend with the proper pin ore machine that can bore them perfect. Not just hand ream.
  11. StefanS
    StefanS
    from Maryland
    I think Fatman's going to exchange them for me so hopefully the new set is good.
