I need some advice from you FE guru's. I just bought a 65 Mercury Marauder. The Merc-O-Matic transmission is slipping, and the 390 has seen better days. I do have a 430 and a turbo drive auto out of a Lincoln that works perfectly. Does anyone know if the motor mounts are the same between the FE's and the MEL's? Is this a swap that requires a lot of modification, or are the two engines and transmissions close to being the same?
I'm going to say that mounts are different and you could be in for some work modding frame mounts Sent from my iPhone using The H.A.M.B. mobile app
