FE stuff. .040 over 390 block, Forged pistons, 428 crank. etc
Discussion in 'What's It Worth?' started by winr, Sep 11, 2024.
  1. winr
    winr
    from Texas
    428 crank is a 1U, wet magged and checked straight, .010/.010 with inserts
    Forged Sealed Power .040 over later model pistons with .040 over moly rings.. new
    .040 over service block
    Victor Reinz Complete gasket kit ... new and unopened
    Pistons are lighter than factory piston and need around ..083 shaved off the top
    Plenty of material left on top and the ring land as well
    C7 rods, balanced, new small end bushings and both ends resized with ARP rod bolts
    Would make a 418
    I also have another setup like the above but with cast pistons that would be around .025 below deck and .040 over moly rings.... pistons, rings and inserts are all new
    Both blocks have cam bearings installed but have 7 or 8 sets of new cam bearings for a bit more
    Ricky.
