FE waterpump
Discussion in 'The Hokey Ass Message Board' started by ThunderRocket, Nov 9, 2011.
  1. Can you rebuild a FE water pump?
    I have a new '62 pump but the shaft is longer on the Edsel's.
    The 332 one is not available that i've found.
    I have always just replaced the pumps, and usually on a SBC.
    so can the shaft and impeller be swapped?
    Advice?
  2. 390Merc
    390Merc
    from Indiana
    I have an unused FE water pump, still in the box I believe, with an unusually long shaft for the fan pulley. It's way too long to use on my Galaxies or Merc. I can dig it out and send a photo if its what you need. PM me if so.
  3. stillrunners
    stillrunners
    from dallas
    I'm in cause I have some nos and not in boxes FE's...that could go to a new home...
  4. Cliffy
    Cliffy
    Try Kanter, I have sent cores for them to rebuild before.
  5. movin/on
    movin/on
    PM'd you regarding a 58 Edsel long shaft pump I dis***embled. Can supply info.
    BTW the somewhat hard to find tin/stamped Timing chain covers are really neat.
    Movin/on
  6. rprice76
    rprice76
    from Palominas
    From my thread....
    The local NAPA had it to me in one day.
    Good luck!
  7. RAY With
    RAY With
    Your pump can be rebuilt or you can purchase a new or rebuilt one from most parts houses.
  8. Thanks, I was told only 2 were available.
    one for Generators and one for Alternators.
    I have a new Gen one all painted etc
    I had the crazy idea that the shaft possibly could be swapped.
    ill just get a 58201.
    Thanks again.
