Technical FED spindle ID?
Discussion in 'The Hokey Ass Message Board' started by dumprat, Jan 1, 2023.
  1. dumprat
    dumprat
    from b.c.
    IMG_1290.JPG 69429970799__D56E99A2-1811-4A97-9456-0CF20EC86176.JPG IMG_1284.JPG I bought a front tube axle out of a front engine job today. Trying to ID the spindles. Don't appear to be anglia and it has Lotus disc brakes adapted to it. Spindle arms are not weld on, they are original just bent for clearance. Any ideas?
  2. Marty Strode
    Marty Strode
    I have never seen a real FED with front brakes, must be from a T-Bucket or something similar.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The spindles only remind me of AMC/Ramble unit’s.
    gimpyshotrods likes this.
  4. Pete Eastwood
    Pete Eastwood
    from california
    looks like Willys with an AMC spud bolted on.
    gimpyshotrods and Pist-n-Broke like this.
  5. 1934coupe
    1934coupe
    I don't know Pete, that backing plate flange doesn't look Willys, maybe? Here's a picture of mineI made my own bracket and early Mustang 4 piston calipers.
    Pat
  6. squirrel
    and the spindle dosn't look AMC, either...although its the same idea, just a different shape to it.
  7. dumprat
    dumprat
    from b.c.
    IMG_2943.PNG I guess you could call it more of an altered than a dragster. It was narrow tube frame, one seat, but very short wheelbase. Pic is old and lousy but you get the idea.
  8. dumprat
    dumprat
    from b.c.
    They don't bolt on either. They have 3/4" kingpins, and steering arms forged as part of the spindie.
  9. junkman8888
    junkman8888
    Pictures of the frame it came from might help.
  10. dumprat
    dumprat
    from b.c.
    It's long gone. A tube frame of some sort with a BBC in it. Corvair steering box with extended shaft and an Olds rear end.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sure does look like steering arm, king pin ***embly and spindle are two separate items. 2B5FB812-35C3-4972-819A-DB818446F367.jpeg
  12. Mr48chev
    The caliper bracket being bolted on with spacers behind the spindle causes a bit of an optical dilusion as clarified in post 11.
    I have no better than anyone else idea on what spindle it is though. Maybe by taking the caliper brackets off to get some clearer show and tell photos it can be figured out.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ok I see it know.
    One of the few things I took from my Dad’s way of thinking. When dealing with old dirty parts. “Clean the **** off before having someone else look at.” 99E120F6-3A91-4274-9D0E-1617ADB1C19D.jpeg
    leon bee likes this.
  14. dumprat
    dumprat
    from b.c.
    Cleaning more today. The brackets are kinda neat. They look to be a purchased part and are stamped left and right.
  15. Fordors
    Fordors
    I agree with @Pete Eastwood , those are Willys spindles. The red arrow points to a triangular shaped steering stop (it’s hard to see here) forged onto the tie rod arm, Willys spindles had stops like that.
    Also, in post #8 @dumprat said the king pins are .750, that ID’s them as ‘37-‘41’s.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
  17. RICH B
    RICH B
  18. t-bolt
    t-bolt
  19. dumprat
    dumprat
    from b.c.
    @Pete Eastwood and @RICH B for the win! Looks exactly like Willys spindles and lotus Elan brakes added as some sort of kit.
    Before being horribly neglected this was a pretty high zoot axle. Full chrome with chrome spring and 4 bar. Drilled discs and 2piston brakes. Would have been cool to see it in its original condition.
  20. Pete Eastwood
    Pete Eastwood
    from california
    I took a second look.
    I was wrong!
    Looks like a regular Willys spindle!
    Moriarity, 57 Fargo and dumprat like this.
  21. dumprat
    dumprat
    from b.c.
    @Pete Eastwood
    I did some google and yes they sure are Willys spindles with Lotus Girling 14lf calipers. Might be Willys hub so modified for the chevy bolt pattern and screw in studs.
    I'm going to clean these all up and see if I can use them. Who knows the chrome might even be ok under the black spray bomb.
    Thanks all.
