Projects FED with killer Flathead
Discussion in 'The Hokey Ass Message Board' started by fenderless, Nov 16, 2010.
  1. fenderless
    fenderless
    from Norway
    Hi Mark. Fixed the hole with chemical metall. I'm gone fill the block with Block-Rock up to the exhaust ports, the rest will be filled with water. This area around the intake port is not critical when it comes to heat.
    Hope this makes sence ? :)
    /K
  2. Model A Mark
    Model A Mark
    from dallas
    Thanks for the answer, yep makes since...
    I need to look into the chemical metal, Ive ground a couple holes myseif, I always braze them, and Its not fun to do.
    Love your rail too.
  3. fenderless
    fenderless
    from Norway
    Thanks ;)
    Slowly, slowly getting stuff done. Hope to get the engine back together this year ;) Block Rock from Moroso is in the house...;)
    /K
  4. roseville carl
    roseville carl
    probably need to stay away from the juice there Kjell.................
  5. Keep after it Kjell . . . even on the slow days, is always a good time to turn some wrenches and get an old flattie back on the track!
  6. dragsled
    dragsled
    from Panama IA
    Keep at it Kjell , we used the Moroso stuff in ours also
  7. fenderless
    fenderless
    from Norway
    Thanks for the encuragement guys :) Yep, did not get the engine back together in 2016, but now we are getting somewhere. Finally the engine has been line-bored, took some time to get the mains to fit the new block, as it differed alot. I have had time to ponder on the last p***es, and also seen some havoc on other engines, OHV's. I do belive it is critical to have really good spark to ignite the alky, so now I have just gotten a brand spanking new Hunt H3 in the house :) I'll keep you posted on the future progress :)
  8. Model A Mark
    Model A Mark
    from dallas
    Very nice, Love your youtube video ...
  9. fenderless
    fenderless
    from Norway
  10. roseville carl
    roseville carl
    keep us informed Kjell........ good luck in 2017
  11. fenderless
    fenderless
    from Norway
    Thanks Carl :) I'll do :)
  12. fenderless
    fenderless
    from Norway
    Obs! see that we already are in 2018 ;) So no racing in 2017, but 2018 looks promising ;)
  13. roseville carl
    roseville carl
    Go gettum Kjell................
    loudbang and fenderless like this.
  14. Come on Kjell - we have Carl all jacked up on Alky now . . . you better get your **** in gear! LOL
  15. fenderless
    fenderless
    from Norway
    Yes Dale, my **** has been glued to a chair way tooo long ;) But work have been my first prio for some time now, working full time on engines ;) Back to the important engine, it's painted and got a package from the US today. Dale, I will do something you told me long time ago, change the timing gears to early style, making the camshaft trust towards the block, I have allready drilled a tiny p***age from the trust surface into the oil channel. Also got new main bearings from King. Another package are on the way with new Cometic head gaskets, and also an AFR logger (2 channel). Hopefully we will get to monitor the poor old Flathead, preventing another "China Syndrom" ;) Cheers K.
  16. Hey Kjell - now that I've written my fuel injector program software - was wondering if you could send me your pump flow numbers (hopefully at 4,000 RPM - GPM at 100 psi) along with your nozzle sizes, your spring lbs for the idle check and your main pill size. I'd like to see how it compares to some other things I'm working on. Also, have you ever had your rail on a dyno - would love to know if you know the HP it makes with your current tune. Maybe my program can help us better understand your tune in general??? Take care my ole' friend! D
    fenderless and loudbang like this.
  17. Model A Mark
    Model A Mark
    from dallas
    Great thread ...
  18. fenderless
    fenderless
    from Norway
    Hey Dale :) Now that software is very interesting :) Ok lets see. The current set-up: Hilborn 150C-1 pump 6,7 GPM, think it's @4000rpm. 4x64A Hilborn Nozzles. Main byp*** are set to open @ 6 psi, size .75. Idle byp*** set to 14 psi, pill 160. HS, pill 55 @67 psi. I'm about to order nozzles for the new set-up with port-nozzles ;) With port-nozzles it's gone be alot of hoses, but I think it's gone look ok, DSC_0860.JPG
    Roger hade to make some repair after my port job, and he also made a really nice distribution block :)
  19. fenderless
    fenderless
    from Norway
    Finally something done :) All rings are gapped, so just a couple of evenings with some more ***embly, and the long block will be ready :) DSC_0952.JPG DSC_0960.JPG
  20. Hey Kjell: I can run the fuel requirements for your setup - are you going to now run 4 nozzles in the hat and 8 port nozzles as well? Did you run a highspeed byp*** before? I don't have this in my software, but it is strictly a calculation based on the area of the pill. When you say '160' and '55' for pill sizes - I ***ume you mean .160" and .055" - am I correct? Did you only run the 4 in the hat before? If so, you'll need to reduce the size of the hat nozzles, now that you'll have 12 total. Also, we used a pressure canister before the port nozzle block with about a 10 PSI spring in it - so that we didn't dribble fuel into the ports until the pressure came up. How are you plumbed? Can you send me a diagram.
  21. fenderless
    fenderless
    from Norway
    Hi Dale. Those values and sizes are from the old/current set-up. Yes .160 and .055 are pill sizes. We ran with thhe high speed opened @ 67psi. Only 4x64A in the hat.
    When we switch over to port nozzles, we will also change the set-up, with a byp*** canister to open to feed the port nozzles. I'll send you the print out of the new set-up. :) Thanks
  22. Draw me a diagram of the complete injector system - return lines, byp*** lines, nozzles, jets/pills, etc.. It is nice to see how the whole thing is plumbed. :)
  23. Model A Mark
    Model A Mark
    from dallas
    Damn that block looks good, I've not seen a block with clearance notches in the cylinder walls for the rods before, what stroke you run if you dont mind me asking ?
    And looks like roller lifters ?
    Very nice, I remember seeing a video of you running the engine, impressive ...
  24. roseville carl
    roseville carl
    lookin great Kjell...... would love to see her run (at Eagle preferably););)
  25. fenderless
    fenderless
    from Norway
    Last ime it ran, before toasting the old block, 9.05 out in the clip.
  26. roseville carl
    roseville carl
    their english is sure funny.......... nice launch
  27. fenderless
    fenderless
    from Norway
    Mark, to clear the block I had to notch out some. The stroke is 4 1/8" and beefy Crower rods.
    Roller lifters and cam are also supplied from Crower :)
    //KBS
  28. mikebishop37
    mikebishop37
    Great thread, Kjell. I wish I was here earlier. You've developed a textbook of information on building a compe***ive flathead-powered dragster.
    I'd like to add a couple of additional tricks you might find useful in the future. First, a bit more of D-porting on a French block; they really do square off well on the short radius. This is one I did for the Fuller streamliner; no results so far, but we're hopeful.:)
    For the next time you get into a bottom end, you can shed some weight -- 6-8 pounds -- from a **** stroker crank, eliminate stress risers, and substantially reduce windage with some aero reshaping.
    loudbang, XXL__ and kadillackid like this.
  29. Model A Mark
    Model A Mark
    from dallas
    Picture 026.jpg Thanks Kjell, I love Crower stuff, I have a very nasty Crower setup in my big block Ford ..
    Damn that crank looks good Mike,
    Here's the block I did for my coupe,
    loudbang and kadillackid like this.
  30. fenderless
    fenderless
    from Norway
    Thanks guys :) The reason for not D-porting more, is that the ports needs to match the port of the intake runners. Both blocks really looks nice. Thanks to all who have posted on this thread, spesially big thanks to Bored&Stroked ! :)
    loudbang and Model A Mark like this.
