Technical felt window channel
Discussion in 'Traditional Hot Rods' started by backrodebob, Apr 28, 2020.
  1. backrodebob
    backrodebob
    HELP! can someone tell me how to remove rear felt window channel from a 29 ford tudor sedan?
  2. RICH B
    RICH B
    If it is stock; there is a hook on top and retainer on the bottom. To remove, the channel is slid up and unhooked at the top and then slid down until the lower retainer is out of the slot.
  3. backrodebob
    backrodebob
    Hey Rich, thanx! now I’m ***uming the window has to come out? how does that happen, because I’m look’n at this thing and can’t for life of me how that’s go’na happen? course I haven’t tried yet, just look’n at!
  4. Kevin Ardinger
    Kevin Ardinger
    I had the opposite problem. Putting the windows in. Car had no windows when I bought it. Had to put the gl*** in and then install the felts. So in your case, I guess you need to remove the felts and then the gl***. I ***ume you are talking about the quarter gl***?
  5. backrodebob
    backrodebob
    ok, all I need to do is get something behind felt track, window is to loose need to tighten up a little. so if I unhook top I might be able to slide something behind felt, what do you think?
  6. Kevin Ardinger
    Kevin Ardinger
    Yes, one of my front windows was slightly loose causing it to **** when rolling up. Put some shim behind the felt. I think I use some dense foam you can get at a fabric store.
  7. backrodebob
    backrodebob
    were you able to do that without removing anything?
  8. Kevin Ardinger
    Kevin Ardinger
    I think I took the felt out and slid it back in with the shim behind it. My windows are only 9” tall though.
  9. backrodebob
    backrodebob
    thanx for all your help!
    RICH B likes this.
