Fender Piping, or what ever its called
Discussion in 'The Hokey Ass Message Board' started by Westerman, Dec 28, 2010.
  1. Westerman
    Westerman
    from Cincinnati
    I'm ripping this 47 Chevy apart to get ready for a color change and new interior. As I'm pulling the rear fenders off I realize, where can I get some custom color fender piping? I'm not sure if that is the correct name (most likely not) however, it is the vinyl (or whatever its made of) piping that goes between the body and the rear fender. Anyone know who carries custom colors of this?
  2. Ford Guy
    Ford Guy
    Speedway has it, I think.
  3. RDR
    RDR
    you could probably have an upholstery shop make some in any variety of colors you want...other than that 'Chevs of the 40s' or 'Filling Station' would have original which is usually black
  4. Westerman
    Westerman
    from Cincinnati
    Why no to the color stuff?
  5. noclubjoe
    noclubjoe
    http://www.fillingstation.com/ its called fender welt, i just bought a ton of it for my 38 chevy i know they have a few different colors out there.....
  6. Mr.Musico
    Mr.Musico
    from SoCal
    3 or 4 different diameters out there and usually just black or one thats a chrome bead. havent seen any colors, if you paint it wont stick well looks like crap.
  7. noclubjoe
    noclubjoe
    i think 3/16" is the normal diameter, the chrome stuff looks like shit to me on any car........the color stuff like badfun said NEVER matches your paint, go black youll never go back! so they say??
  8. 49ratfink
    49ratfink
  9. plym_46
    plym_46
    from central NY
    Seems Ford used a lot of Brown welting, and Mopars used a stainless steel and canvas style.
  10. Jimmy2car
    Jimmy2car
    from No. Cal
    I bought some from C W Moss in Socal. It is SS and has held up extremely well on my 39. Just a bit difficult to bend, but not too bad and looks great. Been there for more than 20 yrs
  11. aaggie
    aaggie
    I've owned lots of old cars with the welting between the body and fenders. Black is definitely the way to go. Chevs of the '40s sells the correct size and pattern for your car.
    The last time I painted my '40 I left the welt out during the spray and spaced the fenders out with a few washers. after sanding and buffing I took out the spacers and sliped in the welt. No overspray and it looked great.
  12. plywude
    plywude
    from manteca ca
    Just redid my 36 and used welting, there is an additive that you can add to you car's paint color and spray the welt it comes out looking good and with a little wax on it from when you do your car it should last as long as your car color, this is available at your auto paint store.........:D
  13. Westerman
    Westerman
    from Cincinnati
    That is great to hear. I will check into that. Has anyone else heard of or used the additive?
  14. Anyone know where to get the stainless welt?
  15. Gator
    Gator
    Because it's not 1985 anymore.
  16. Paul2748
    Paul2748
    Try Juliano's in Connecticut - I think they have different colors.
  17. Master of None
    Master of None
    www.yogisinc.com has it in different colors, think they are from Juliano's sold by the foot.
  18. lo-buk
    lo-buk
    from kcmo
    I used colored fender welting from julianos and still looks good after 25 years.
  19. mj40's
    mj40's
    Most any VW parts supplier sells some realy nice black fender welting.
  20. big bad john
    big bad john
    .....When you buy fender welting....it pays to buy high quality....Juliano"s has great welting and stands behind it.....they also have different shades of black....I think Yogi's carry Juliano's too
  21. theHIGHLANDER
    theHIGHLANDER
    Point of fact, the higher priced cars in the 30s and 40s used fenderwelt painted the same color as the car. If you buy cheap shit made of plastic it will indeed fade from UV exposure. Find a good grade of vinyl that matches the color as close as humanly possible and have it made. Don't fall into the thinking that it's a cheap add-on. Done right it's a touch of class.
  22. john worden
    john worden
    from iowa
    Welting can be painted. Vinyl welt----use additives required to paint vinyl. Fabric welt----probebly don't need additives. Stainless welt----should prime it first. In all cases don't load on heavy coats. Try to achieve color with as few coats as possible. Paint it after it is fitted to the car after careful masking.
  23. careyohio
    careyohio
    Got mine from Dennis Carpenter.
  24. onlychevrolets
    onlychevrolets
    NO to the color stuff.... it's cheezy
  25. fab32
    fab32
    One more time for Juliano's. They have quite a selection of colors. Reread what Highlander posted.......... good information and he does it on some very high end cars.
    Frank
  26. socalmerc
    socalmerc
    from socal
    if you really want color go get marine grade vinyl at your upholstery supply house and the welt piping and just have some one sew it up. if you want it painted get some ppg flex additive and mix it in your paint just get the vinyl to match close to the color you want to paint and spray just enough to cover it. the welt will flex with out the paint cracking off. my old boss used to do this all the time back when cars were being painted turquoise and baby blue back in the 90's
  27. vtwhead
    vtwhead
    Julianos in CT does custom colors. Send a color swatch to them and they can send samplesback to you.
