Customs Fendered Hotrod model A help
Discussion in 'The Hokey Ass Message Board' started by ruggs, Dec 27, 2010.
  1. ruggs
    ruggs
    Hello everyone,
    My name is Ron, been lurking for quite some time and have fiqured out that this would be the place to get some information that could save me both time and money on my build. My project is a 1923 C-Cab with full 28-29 running boards. Everything is going as planned except knowing what really works best with the fenders as far as track width, wheel offsets and tire sizes. If anyone with a fendered model A could post a picture of their ride and the specs I would truly apreciate it.......ruggs[​IMG]
  2. Rpmrex
    Rpmrex
    from Indiana
    Your adding fenders from a totaly different model to that car. It's going to be custom fitted not buy and bolt on.
    Looks cool and it's a great idea though. I wanted to build a C cab hot rod once.
    Good luck! and welcome!
  3. wingedexpress
    wingedexpress
  4. pitman
    pitman
    You'll likely want the fender to mount to the frame rail in a "standard" format. I'd look for a '28-'29 light bar and inner front fender mounts, the cast mounts are better than the stamped steel ones. And you can bend them to the best location to pickup the outer fender carriage bolts. Of course to center the fender in-side-view to match the wheel/axle. This location can be matched by using A frame horns and locating them to suit. Note in Winged express's pickup. If you are able to locate the axle "approx" beneath the radiator, then the fender and frame horn location will work out OK. The light bar would be ~ 1/2" ahead of the shell.(on a typ Ford model A)
  5. Rpmrex
    Rpmrex
    from Indiana
    ^^^^^^^^^^^that's not a T model Ford^^^^^^^^^^^
  6. ruggs
    ruggs
    For everyones infomation the fenders , slash shields and running boards are all at original model A deminsions. Also the body is gl*** and called a 23....can't afford an all metal one.....ruggs
  7. Dirk35
    Dirk35
    Get you a set of fibergl*** ones, block them up to where you want them to set, fibergl*** in the difference.
  8. ruggs
    ruggs
    Wingedexpress, like the look of your ride, saved the photo and what you wrote..Thanks....ruggs
  9. The37Kid
    The37Kid
    First thing I'd do is buy a pair of splash aprons, that way you can clamp the fenders to something and get a idea of how things look.
  10. wingedexpress
    wingedexpress
    Thanks,If you need more measurements let me know.
  11. ruggs
    ruggs
    All the parts are in the shop, just not in the photo.All of the details of the fenders etc are already worked out using original type brackets. I am just trying to find the track width and wheel ofset that works best. here is a photoshop of what it should look like....ruggs[​IMG]
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    My Full Fender build, if i can help ..PM me..im not really sure what your looking for or need , but would like to help if i can
    my rear axle is 56" wide.Drum face to drum face..with a 3.5" Back spacing running 235 75R 15's
  13. Rpmrex
    Rpmrex
    from Indiana
    I like the photoshop with the fenders and boards on, I have some front fender braces if you need a set that will work on 28-31 ford.
  14. ruggs
    ruggs
    RPMrex thanks for the offer but I already have the parts...Von Rigg Fink, where can I find a photo of your car....Your rear track width seems to be the same as Winge***press's........ruggs
  15. ratfink56
    ratfink56
    Ruggs, I'm in Harrison. Where are you?
  16. ruggs
    ruggs
    Ratfink56,
    I'm in Holiday Island, (near Eureka Springs).....Von Rigg Fink, the link you gave me doesn't work, please try again.......Ruggs
  17. ruggs
    ruggs
    Thanks Wingedexpress and Von rigg Fink for responding.I had hoped for more photos and specs but, you guys at leased got me in the ballpark...thanks again........ruggs
