Technical Fenderwell Headers for C1 Corvette
Discussion in 'The Hokey Ass Message Board' started by Gold Top Gasser, Nov 3, 2025.
  1. Gold Top Gasser
    Gold Top Gasser
    I have a 59 Corvette project with a 327. It's not a straight axle, but I'm raising the front end a few inches with blocks, like they did on occasion back in the day.
    I want fender well headers to compete it. Searched everywhere and haven't found any for a C1. I have a set of regular ******s on it now
    Has anyone had experience with the Chevy II Nova fender-well headers? They sweep up high and may clear my steering. The p***enger side is wide open.
    I found a "like new" coated set of Doug's nearby for $500 bucks that were on a 67 Nova. I'm Not afraid to modify them a bit if i need to, ... just curious of what you guys think.
    327 40 over
    30/30 solid cam
    Pro-Topline 235CC heads, 2.08 valves
    Holley 300-36 dual plane Street Dominator
    Muncie 4 speed
    456 Gear Posi
    chryslerfan55, swade41 and Just Gary like this.
  2. swade41
    swade41
    from Buffalo,NY
    I bought a set recently for my 57 chevy pickup, they cleared the drivers side but the p***enger tube hits the firewall.
    The #8 tube runs backwards off the flange towards firewall.
  3. swade41
    swade41
    from Buffalo,NY
    Tri-five headers cleared everything but the turning radius of the tire, maybe visually you can tell if they'd work or not.
    If you were local I'd let you borrow my 3 different sets of fenderwells that didn't work for me on the truck.
    20201116_163138.jpg 20201117_112845.jpg 20201116_162915.jpg 20201116_162806.jpg 20201116_163149.jpg
    And the fat fenders, they cleared everything but the steering column
  4. Gold Top Gasser
    Gold Top Gasser
    Awesome truck. Thanks for the pics. I see now how the p*** tube will be pretty close, but I think they may work. I would have to trim or remove this big plastic air vent tube on my p*** firewall, not using it anyway.
    On the driver side, the steering shaft sits way up as high as the valve cover, but looks like those headers sweep up and will clear it. I looked close at all the fat fender options, the tubes would run straight into the steering shaft.
    When you get time could I get a rough measurement (Nova Headers) from about the flange to where the header collector extends on the driver side. My only other concern is my factory 4 speed shifter Z bar linkage set up. It's on the outside of the frame 3 inches. Past the linkage I have about 12-15 inches of open space. Thanks for all the help!
  5. Corn Fed
    Corn Fed
    @Gold Top G***er make sure you let us know what you eventually find that works. It would certainly help the rest of us solid axle Vette owners out.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. Gold Top Gasser
    Gold Top Gasser
    Thanks for help,... last resort I'll make a custom set of headers.
    If / when I do I'll save a jig so I can make more for anyone else here who needs them
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    were the ones I posted too expensive?
  9. 19Eddy30
    19Eddy30
    from VA
    Yes & No Even Stahl pattern.
    I would spend $$ for decent Tig / mig
    Gas torch ,
    Welder up , Two bird's One stone & have a tool that you can
    Use down road
    mad mikey and chryslerfan55 like this.
  10. DDDenny
    Thinking that was the last resort, nice selection though.
  11. swade41
    swade41
    from Buffalo,NY
    If these don't show what's wanted let me know
    20251104_153852.jpg 20251104_153905.jpg 20251104_153900.jpg 20251104_154034.jpg 20251104_154029.jpg
    bchctybob and chryslerfan55 like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    @jimdillon has fenderwell headers on his 62 Corvette
  13. jimdillon
    jimdillon
    Mark is correct I have fenderwell headers on my red 62 Vette. It has a big block though and the headers were made by Tubular Automotive out of Rockland Ma. (phone is (781) 878-9875). They did make them for small blocks in C1s back in the 60s all the way to the present day. If you look at the 57 Vette called "The Hayseed) running back in the 60s you will see Tubular Automotive advertised on the side although I believe he did not run the fenderwells. Beautiful headers that sound great IMO. I bought mine a number of years ago. May be worth a call if you cannot find any to suit your application. Good luck.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Oh man, I totally forgot that your car has a big block...
  15. Gold Top Gasser
    Gold Top Gasser
    Not necessarily, thanks for that info.
    sometimes I like learning new things. Learning to build awesome headers would be cool and helpful for a lot of us.
    I just got a new AC/DC Tig welder…. But I’m I’m not a welder lol. I’m a good grinder thou lol
    bchctybob and 427 sleeper like this.
  16. Gold Top Gasser
    Gold Top Gasser
    Those pics with measurements really help. Thanks!
    I see you are in New York. Here is a pic if my vette at the Lebanon Valley NY drag way in the mid 60s. I’d like to take it back there one day.
    My son is in NY at the West Point military academy.
  17. noboD
    noboD
    With enough grinding wheels ANY weld can look good.
    Gold Top Gasser and 427 sleeper like this.
  18. jimdillon
    jimdillon
    Mike sound like a fun project and also great you are keeping it as a drag car. I have raised mine with blocks as well. Everyone is different on how high they want to go and I settled on 3" to avoid problems with the steering link. I originally got some solid blocks and they did not work well since it was too hard to feed the bolts through. I made my own blocks with a flange top and bottom so I could easily feed the bolts through. I actually have a black small block 62 that is raised as well. That is the one with 3" blocks. The red car has some really stiff front springs and so I went with 2" blocks to keep the height reasonable. If I made another set I may make them with a little caster built in to avoid too many of the 2* shims. My first p*** at Milan was a handful since I did not have enough caster-couldn't keep it in my lane. I now run right around 5* caster (maybe a little more). Some guys run 7* which may affect the steering wheel return. I have an old modified production ch***is from the 70s (1960 Vette) and he ran 9* but he told me he had to manually return the steering wheel but since it was drag strip only he did not care. Here is a picture of the fenderwell headers from Tubular from back in 2012 when I was ***embling the car.Good luck with your project-sounds Red 62  headers.jpg cool.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    Does @lumpy 63 have fenderwell headers on his Corvette??
  20. swade41
    swade41
    from Buffalo,NY
    Other options to check out or work off of
    Schoenfield truck pull fenderwell headers
    Chevy Truck/Tractor Headers - Schoenfeld Headers https://share.google/QZIPs9l6cxS7z8mKx
    And stock clip headers for a round round car, some are stepped 1 5/8 - 1 3/4 and available from a few manufacturers
    Speedway Stock Clip Small Block Chevy Headers, Raw Finish https://share.google/adUyE90hu3mQyfv9A
    mad mikey, loudbang and 19Eddy30 like this.
  21. Gold Top Gasser
    Gold Top Gasser
    Awesome Vette! and Thanks for all the info, specially on the lift blocks. I bought a single shim on eBay and gave that to a buddy down here with a laser cutter. He's making me a handful out of 1/4 and 1/2 steel. So I plan to weld a desired thickness of square tubing in the center. I'll go 3-3.5 inches and will do you caster idea. If they turn out good I can send you some of these steel plates I'm having cut. I grew up in Toledo, Ohio and used to go to Milan Drags all the time in the early 90s I lived in Dearborn a while also. My dad retired from GM. I still have my 67 Camaro Z-28 Back Half big tire car, but don't race it anymore. If there is anything that will make putting those spacers in easier feel free give me some instruction. Thanks
    jimdillon and bchctybob like this.
  22. Gold Top Gasser
    Gold Top Gasser
    Yes, good find. I was checking those truck pull headers out last night. They look very close and priced good. I'm thinking even if I can get up and over the steering, I can cut and weld the rest of the way down so they fit well in the fenders. I found a guy down here on FB market place selling brand new Doug's coated Nova headers for 650 bucks still with summit tags on them, and another used set of coated ******s for 550. I'm tempted to go get the Doug's as they look like they are going to fit.
    loudbang, 427 sleeper and bchctybob like this.
  23. swade41
    swade41
    from Buffalo,NY
    These S-10 Hedman headers are local to me for $225, I sure thought about them but don't really want to spend the coin on a 4th set that don't fit. Unfortunately I've pulled the engine out of it now in preparation to paint the frame, so there's no telling if they'd fit.
    But another something for you to look at
    Gold Top Gasser and loudbang like this.
  24. jimdillon
    jimdillon
    Good idea on the square tubing in the center. Pretty much what I did and then welded plates on the top and bottom in the shape of the shims and those plates act as the flanges. I relied on others to set the caster and camber originally but I bought a Fast trax gauge and set them myself now. They cost a couple hundred bucks but alignment shops are not doing it for free either. Thanks for the offer. Will be following your build hopefully.
  25. 19Eddy30
    19Eddy30
    from VA
    Its easier to just look for sbc header's
    but look p*** ,
    Look into other engine manufacturers
    Small B & into BB's
    Cut & change head mounting .
    Also If a set of Sbc to short to p*** over frame , cut & add to tubes .
    A few years back we took a set of
    Race sbf & adapted to the
    Evil LS
    Gold Top Gasser likes this.
  26. saltflats
    saltflats
    from Missouri
    Jim good to see you are still around been a spell since we got to meet up.
  27. jimdillon
    jimdillon
    Hopefully we will run into each other-maybe at Meltdown 10-God willing.
    saltflats likes this.
  28. Gold Top Gasser
    Gold Top Gasser
    Update on headers. I got ahold of a brand new set of ceramic coated Doug’s 2” fender-well headers for the early Nova. The guy apparently gets demo and scratch dent part from summit racing in Dallas. For 500 bucks I don’t think I went wrong. They still have the 1400 price sticker on them. Anyway, the p***enger side slide ride on from underneath without cutting anything. The driver side is more challenging. I did some of cutting on the driver inner fender.
    1) The collector runs into the z bar clutch linkage. (So I’m looking at external slave cylinders or hydraulic set up)
    2) The steering shaft is pretty large and I may have to dent one of the tubes at the bottom. Or can you guys tell me if this is an option? Shimming my stock motor mounts a 1/2 inch or so to raise the motor. I would have to double check hood clearance. IMG_5236.jpeg IMG_5239.jpeg IMG_5253.jpeg
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    There are many car fires attributed to these gl*** screw together fuel filters. They vibrate loose and fuel sprays onto the exhaust… please change it before you burn your car to the ground IMG_6470.jpeg
  30. jimdillon
    jimdillon
    Mike the headers look nice and the price was right. Hard to give any useful advice without seeing what you are looking at I suppose but the steering shaft can be in the way. On my headers what they did was the number one cylinder header pipe is s separate piece. The header flange is cut so the flange bolts on to the head separately and the other end is a slip fit. It seems to work quite well and I have never had it leak. Not sure if it would work on your application. As to raising the engine up I know guys that have gone up and down by modifying the front mount and doable although would have to keep the driveshaft angle in mind. Going up a little may not be a bad idea but of course it would probably interfere with the stock hood without a scoop. Good luck-nice headers.
    427 sleeper and Gold Top Gasser like this.
