fenderwell headers measurements
Discussion in 'The Hokey Ass Message Board' started by v8nova64, Oct 7, 2011.
  1. v8nova64
    v8nova64
    from !!
    please delete
  2. shoprat
    shoprat
    from Orange, CA
    You need to find out how long the primarys should be for your engine first
    and go from there. How big the motor is determines size of tubing.
    and collector
  3. been there done that... not even close to working... Nova are all by themselves
  4. rotten johnny
    rotten johnny
    from Mi
    Making headers from pictures and measurments and going home to bolt on just is not going to happin, there are alot of bends and obstacals that come into play. As well as tube diam and lenghts. I would suggest a mock up car build then make the headers to fit the mock up. Here is a top veiw of mine. they clear the foward rollbars by 1/16th. These are speedway headers off a 55 or 57 chevy, dont remember.
  5. rotten johnny
    rotten johnny
    from Mi
    I used a bare block and heads. Mounted clutch linkages and any parts that come close,roll cage, set motor mounts and go from there. Use the same heads and block configuration as there are tall decks and tall port heads. You need to be accurate as possible. Hope this helps
  6. rotten johnny
    rotten johnny
    from Mi
    Yes, thats the only way you will kmow how to route your tubes
  7. PRO 48 fleetline
    PRO 48 fleetline
    from ohio
    Heres the hod rod headers for fat fendered cars they just might work!
    By profleetline at 2011-04-14
  8. Those measurements are exactly what they look like.
    A is how far the outer most part of the header is from the heads.
    B is the height of the header from the highest point to the lowest
    C is how long they are from the front of the first tube to the back of the collector.
    We (Patriot) make those headers. They are for fat fendered cars - no reason to try and adapt those when we make Nova Fenderwells as well.
  9. SmokinBill
    SmokinBill
    Hookers part # 2214 made specific for the early nove. you can find them used for $150-$300
  10. novas4life
    novas4life
    from vnc,wa
  11. rotten johnny
    rotten johnny
    from Mi
    Nice Brandon.........widh I seen this when I was building. Lots of good points here
