Technical fenderwell headers ??
Discussion in 'Traditional Hot Rods' started by axel's40, Nov 2, 2017.
  1. axel's40
    axel's40
    Looking for some info on fitting more than performance fenderwell headers, $300 or under.Lots of them on ebay for almost too cheap, but would work if they'd last 3-4 years, street driven weekends. sbc, 40 plymouth, 6" drop straight axle
    Hardrider77 and chevy57dude like this.
  2. Tim
    Tim
    from KCMO
    OK I’m goin to try to decipher that.
    You have a 40 Plymouth with a sbc and a straight axle and want to know what fenderwell headers that may fit are available in the sub $300 price range.
    You have seen cheap ones on eBay but question the quality. You need something that will last st least 3 or 4 years on a weekend driven car.
    Did I get that right?
    INVISIBLEKID, X38, mad mikey and 7 others like this.
  3. squirrel
    That was, like, a public service.
    Todd553, F-ONE, INVISIBLEKID and 6 others like this.
  4. axel's40
    axel's40
    Just looking for a resonable answer not sarcasim, if i gotta spend more fine,not building a full blown show or race car, just want to buy parts once.
  5. flatheadpete
    flatheadpete
    from Burton, MI
    That was a tough read. Thanks for the deciphering Tim.
    Just remember: You get what you pay for.
    lothiandon1940 likes this.
  6. henry's57bbwagon
    henry's57bbwagon
    I read his post and understood it right off.
  7. manyolcars
    manyolcars
    You are one of those people who always amaze me with your ability to understand illegible offerings
  8. greybeard360
    greybeard360
    Some folks need to learn sentence structure and punctuation.
    You may find out that you will be guessing at what might fit the car and may have to try a couple of different sets. Each set will cost shipping to return if it doesn't fit. Buy a fenderwell header kit and weld them up yourself. Then you will know what the quality is.
    Sent from my Moto G Play using The H.A.M.B. mobile app
  9. JimSibley
    JimSibley
    To answer the original question, I doubt that a pair of generic fenderwell headers are going to work without some cutting and altering. Look at the flange thickness to judge your quality. A less expensive setup might be wise since you will most likely need to cut them up a little anyway.
    mad mikey likes this.
  10. axel's40
    axel's40
    for sure,just feeding on info.
    thanks
  11. axel's40
    axel's40
    thanks, thats probably the route to go
  12. axel's40
    axel's40
    Thanks
  13. Terrible80
    Terrible80
    Would the 6'' drop be a problem with fenderwell headers?
  14. squirrel
    I needed some fenderwell headers a few years ago, didn't find any that looked like what I wanted, so I made a pair. Took a few days. They came out pretty nice. I recommend it.
  15. Tim
    Tim
    from KCMO
    Absolutely no sarcasm ment, I had to read that a couple times to understand what you were trying to ask.
    We have a lot of non native speakers and older people that just don’t type very well here and so sometimes it’s hard to understand what they want.
    Oftno one writes it out more clearly and they post gets no replies and the original poster grows frustrated.
    I was actually trying to be helpful.
    In that vein here are some thoughts.
    1: a photo of your motor in your car would help a ton.
    2: 57 Chevy fenderwell headers from speedway and first generation nova/ Chevy ii fenderwell headers seem to be the most commonly used in situations like this.
    When it’s not stock you may have mounted something, wether it be the engine, steering or brakes, in a slightly different spot and it makes it hard to give you a 100% answer.
    3: speedway has a chart that gives you most of the needed measurements for each set of headers they offer. It’s in the catalog but the web site typically offers much more information and measurements.
    If you can post photos for us my first step would be find some 57 Chevy fenderwell headers, find the part number and either find the chart of measurements in the catalog or online and print it off to take to the garage and see if it looks close.
    Some of speedways offerings are really nice as far as header go, and some are probably recycled pop cans. But I’d say even the cheapies should last you 3 or 4 years of weekends unless you keep them un painted and live next to the ocean or something weird.
    X38 and lothiandon1940 like this.
  16. Tim
    Tim
    from KCMO
  17. choptop40
    choptop40
    Hamb to the rescue once again.....
  18. vtx1800
    vtx1800
    I am running those Speedway headers in my 38 Chevy. So far so good[emoji6]
  19. DDDenny
    First gen. Chevy II/Nova 62-65 and second gen. 66/67 are the same.
    Note:
    None of these are under $500.
    https://www.summitracing.com/search...vrolet/model/chevy-ii/header-style/fenderwell
    I never liked how most application ch***is style headers hung down so low, my 67 Nova is quite low so the only solution was to either build a set from scratch or modify some existing ones.
    These are S&S (no longer in business) 13/4" headers for 28-34 Fords that were heavily modified to fit my Nova.
  20. chevy57dude
    chevy57dude
    Denny - those look expensive. To the OP - Racingjunk sometimes has vintage stuff. Can't remember swap meet headers for any more than a couple hundred bucks. Not exactly help but they're out there.
    mad mikey and lothiandon1940 like this.
  21. DDDenny
    This won't be news to the OP but things aren't always cheap, easy or achieved overnight.
    Ya gotta want it!
  22. axel's40
    axel's40
    Thanks for all the info, its hard thru this" new fangled" texting coummunicating with people for us old farts (me), easy to take it the wrong way,appreciate the follow up. Will definately add photos as i get that far, just starting to design ch***is for straight axle and ladder susspension, lot of fun. Probably should also learn how to spell. thanks,
  23. lothiandon1940
    lothiandon1940
    Whatever you buy, get them coated, even if it's just some Hi-Temp brush -on stuff from Eastwood or somebody else.
    lothianwilly71 and mad mikey like this.
  24. DDDenny
    Only if you are sure they will work, you'll notice I ordered these coated (unrealistically) thinking I could make them work without mods, guess again.
    Btw, my roadster has the same headers, as mfg. and coated.
  25. squirrel
    Having the white VHT paint flake off the headers is super traditional. So is repainting them every year.
    As seen in Hot Rod mag: :)
  26. chevy57dude
    chevy57dude
    Summit Racing # PTE H033 Fenderwell for fat fender ch***is $265
  27. Sheep Dip
    Sheep Dip
    from Central Ca
    Used em on the 40 and fit like they were made for it!
  28. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    ^^^^^ Nice wrap job. But- give it a year or two, and if you ever decide to "un wrap", you might be a lil sad with what you see......:(. The OP is on the cheap/less expensive, which I get, but having them coated is the way to go for heat issues......Or- spring for coated ones.
  29. greybeard360
    greybeard360
    Yup.... wrap holds moisture and if they are wet when you park it.... they will start to rust faster than a Dodge in Michigan.
    Thor1 and lothiandon1940 like this.
  30. vega1
    vega1
    What I got was his old headers were leaking fumes into the car so he needs new ones
    Sent from my XT1710-02 using The H.A.M.B. mobile app
