Technical Fenton Gyro center cap: screw size?
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Jun 9, 2020.
  1. Anybody know the size/thread count of the machine screws that hold Fenton wheels' caps on?:confused:
    Thanks, fellas.
  2. Ericnova72
    Ericnova72
    from Michigan
    Whether they were always the same size I don't know, but mine were #10-32.
    some other companies also used the same size, American Racing and Ansen IIRC.
    Just Gary likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It's a bitch trying to screw this onto a sample board at Home Depot!
    belair and Just Gary like this.
  4. I've run into both 8/32 and 10/32, I'd recommend running a 10/32 tap in there in any case. If you use stainless screws, use plenty of anti-seize... actually, use it no matter what kind of screws you use.
  5. 19Eddy30
    19Eddy30
    from VA
    X2 on Anti-seize
  6. I'll add that if you have issues with the screws loosening in use (and I have), put a small dab of blue locktite under the head of the screw. DO NOT put it on the threads...
  7. jimmy six
    jimmy six
    In aluminum they really should be 10-24 or what is considered coarse thread... I can’t believe you don’t have a thread chaser kit. A couple of bucks a HF.
  8. Thanks guys!:)
    I do have a thread chaser & tap/die set, but thought I'd better ask the HAMB before risking damaging some expensive wheels.:eek:
    Or worse, embarrass myself carrying a wheel & tire to the fastener sample board at Home Depot.;)
  9. Just Gary Fenton Gyros are actually 8-32, same as early Torque Thrusts, early US Indy and even late model Team lll five spokes, that's all I took the time to check quickly.
    loudbang and Just Gary like this.
  10. I'd still take them out to 10/32, those don't break off as easy....
    Besides, if any are broken off, usually by the time you get the remains out 10/32 will leave a thread while the 8/32 may not.
  11. The cap ears are prone to cracking as it is, opening the holes bigger would make them that much more so.
    Just Gary and loudbang like this.
  12. Mine are 8-32.
    Some of the threads are kinda worn but none that won't clean up.:)
    No need to "super-size" to 10-32... at least this time.
    Thanks again, guys.
    swade41 likes this.
