Customs Fiberglass Resin
Discussion in 'The Hokey Ass Message Board' started by Foulkkustoms, Mar 21, 2013.
  1. Foulkkustoms
    Foulkkustoms
    from Arkansas
    fibergl*** resin is new to me im good with bondo. but how do you mix the resin and harder?
  2. 296 V8
    296 V8
    from Nor~Cal
    in a plastic cup (your not fond of) with a stick
  3. Foulkkustoms
    Foulkkustoms
    from Arkansas
    How do you no how much hardner to use?
  4. Read the can, there should be a chart.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Don't use a Styrofoam cup! HRP
  6. greaser41
    greaser41
    Its also going to depend on how fast you want it to harden. Its alot like mixing bondo.
  7. 296 V8
    296 V8
    from Nor~Cal
    Oh yeah
    And when your done for the day and leave the shop ….. Put the cups outside away from flammable’s
  8. Rusty O'Toole
    Rusty O'Toole
    Just a few drops, roughly a teas****ful to a quart. It will vary depending on temperature, how old the resin is, how fast you want it to kick, etc. just like bondo.
    Experiment with small amounts until you get the feel of it. Different batches of resin, and different hardeners will vary.
  9. NAES
    NAES
    Just to be a **** I'll add that there is polyester resin which uses the liquid drops and then there is epoxy resin which uses a ratio of resin and hardener usually in the 70/30-50/50 range.
    You are probably using polyester resin which is pretty stinky so you'll know it when you smell it. Find the manufacturers website and find out how many drops to add depending on the temperature and humidity.
    Nitrile gloves are mandatory as you will eventually develop an allergy. Everybody does, it just depends on your tolerance. Also keep the place well ventillated or wear some lung protection. The fumes will make you fuzzy.
    Since you are new I would advise not making the resin too hot where it kicks off before you're done gl***ing. It'll harden eventually if you are a bit conservative with the hardener.
    Good luck, NAES
  10. 5559
    5559
    from tn
    mixed some up way to strong in a coffee can one time -used it & it worked good- but when the leftover kicked off in the can it looked like a steam engine!!!!!!!!!
  11. It's a messy adventure and that **** gets on everything - like franks red hot sauce
  12. mustang6147
    mustang6147
    from Kent, Ohio
    ha !
  13. Rusty O'Toole
    Rusty O'Toole
    True about the epoxy but that stuff is like $100 a quart. Not much chance of buying it by mistake.
    Polyester is what everyone uses for fibergl***.
  14. BOBCRMAN
    BOBCRMAN
    from Holly
    Ambient temp is the biggest problem. Most Polyester resin uses 11/2-2 percent hardner. Add more for cool temp and resin will not set (kick) below 60 degrees
    ***umptions:
    · Resin Weight: 9.5 lbs. per gallon
    · MEKP specific gravity: 1.1
    · Catalyst quan***ies rounded to the closest convenient unit
    Polyester GP Resin is general purpose polyester resin. Contain wax. Amounts of MEKP to use denpens on your working time. You can slow it down for more work time, or speeded up for less work time. But cannot add below ½ % or exceed 2%. of MEKP. Must be mixed thoroughly for a minimum of 2 minutes. Work time is 15-25 minutes at approx 77 degrees Fahrenheit with 1 %. Complete cure 45 minutes to 3 hours. Do not use below 60 degrees Fahrenheit. Can be brushed, rolled, or sprayed. Resin Consumption: 2 parts resin, 1 part gl***, by weight. Remove air with a Bubble Buster Roller. May recoat within 24 hours by sanding the surface. Is not UV stabilized and should be coated with a gel coat with wax . Resin may be thinned with styrene by adding no more than 10% by volume. A fillers ( Cab o sil or Qcell ) may be add to make putty. May add up to 4% pigment, by volume, for coloring. Clean up with acetone.
  15. Foulkkustoms
    Foulkkustoms
    from Arkansas
    I need to know how many drops of hardnr for 6oz or resin?
  16. Rusty O'Toole
    Rusty O'Toole
    Start with 6 drops and adjust from there, depending if it hardens too fast or too slow for you. Before long you will get the feel for how much you need, same as bondo.
  17. You need 0.09 to 0.12 oz of hardner for 6 oz resin .
    If you tell me how big your drops are , that is how many of your drops are in 1 oz I can tell you how many drops you need
  18. pimtina
    pimtina
    I did a bit of 'gl*** work today. My can of resin said to use 14 drops per oz.
    Your mileage may vary!
  19. chinarus
    chinarus
    from Georgia
    Make sure you buy fresh materials.
    Some places rarely sell fibergl*** so it sits on the shelf too long.
  20. Fenders
    Fenders
    I have used the polyester resin YEARS old... but I found the MEKP drops have to be fresh.
  21. 3banjos
    3banjos
    from NZ
    3% hardener is the norm. Get it locally from a boat builder here. $50.00 gallon, and a quart of catalyst ($10) will last you forever. Just do a small test 1st, I like to add a few drops extra, to make sure it's hard before the morning. Also really wet out your matte, leaving no white area's (air). Oh, and acetone to clean up. Your cheap stiff brush will do a few rounds if you clean and brush out on the used hand cloth.
  22. BOBCRMAN
    BOBCRMAN
    from Holly
    I found two gallons that had set waay back in the corner. Since 1989. Used it to make the molds for my Studebaker front clip. The stuff was super thick so I mixed it with same brand new stuff. Made great fender/hood molds
  23. DrJ
    DrJ
    CAUTION!
    If you get MEKP in you're eyes, you will probably end up going blind from it.
    You have less that 10 seconds to wash it all out or it permeates the surface of the eye.
    Don't say I didn't warn ya...
    The mixture depends on ambient temperature but is usually about 1%± MEKP by weight at 74º F
  24. tunram2quad
    tunram2quad
    The hardner I've been using lately says right on the back of the tube 14 drops to 1 oz resin. The bigger the hole you put in the tube the bigger the drops.Practice a few batches.you'll be alright..
  25. jcmarz
    jcmarz
    from Chino, Ca
    Can't people read instructions anymore?? It's not rocket science.
  26. jumbogem29
    jumbogem29
    from Alabama
    The slower dry like 8-10 drops works better it will be harder better to work with do not over do it.
  27. Kickstarter
    Kickstarter
    from NC
    Or a Solo cup.
  28. black 62
    black 62
    from arkansas
    follow directions and you will get the hang of ---try to mix the same size batch each time ,it makes it easier to figure out---good luck...
  29. wbrw32
    wbrw32
    If the resin catches fire you will know you used too much MEK..LOL
  30. I have a fibergl*** expert friend who some times hooks me up with a little material. He made sure to make me understand that you don't want to get even a speck of the hardener in your eye. he has a friend who lost an eye to it. Very nasty around eyes.
