Technical Fighting a model a starter
Discussion in 'The Hokey Ass Message Board' started by Stu, May 31, 2023.
  1. Stu
    Stu
    Tried the fire up my new project this weekend and the starter is not engaging the flywheel, took the starter off and looks like the bendix had been living under a rock, is there a trick to get this outer collar off
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    That collar normally slides right off after loosening the big bolt.
    Try alittle heat, spray some good lube and start tapping.
  3. Stu
    Stu
    The one with the bolt came off, this one just spins
  4. woodiewagon46
    woodiewagon46
    from New York
    You need to source another starter that isn't loaded with rust.
  5. Stu
    Stu
    Agreed, i have one on the way, just figured i would mess with this one while i wait
    Bob Lowry likes this.
  6. Stu
    Stu
    Here we go
  7. brjnelson
    brjnelson
    I have heard that the "modern" bendix you just got is the way to go.
    I seem to break the old style like your rusty one every other year.
    I want to try that modern bendix, I will get one soon.
