Technical Figuring out Gear Ratio in these F1 diffs
Discussion in 'Traditional Hot Rods' started by hellerlj, May 31, 2015.
  1. hellerlj
    hellerlj
    from Minnesota
    I have two F1 Diffs, open drive....need to find out gear ratio...
    I thought that there was a number stamped on the banjo that
    you divided by another number and that would give you the ratio ??
    I have looked and looked....NO STAMPINGS !!!!
    Hopefully,. I am looking in the right place
    If there aren't any number anywhere, maybe you could remind
    me what to turn and how to count, so as to be able to figure this
    out...
    Any and All advice or guidance will be much appreciated....
  2. fordflambe
    fordflambe
    Open diff.......... .hold one wheel and turn the other 2 revs, counting the revs on the pinion.........pinion revs will = ratio
    Closed diff.......turn wheel one rev and and count pinion revs..........
  3. hellerlj
    hellerlj
    from Minnesota
    Just a stupid question ???
    Why 2 turns for open and only 1 turn for closed....Just Really Curious ????
    Thanks for your help, I sure appreciate your time and expertise...
  4. F&J
    F&J
    What he meant is a non-posi , you lock one rear wheel and spin the other wheel two turns and count pinion turns.
    and on a posi, both wheels will spin, so only turn a wheel one turn and count pinion turns.
  5. Hnstray
    Hnstray
    from Quincy, IL
    It only takes one turn for open diff IF both wheels turn simultaneously. However, unless you have a helper, that may not happen. The reason is because of the differential gears (spider gears) in the open diff cut the motion by half. The limited slip turns both wheels at the same time and the spider gears are not a factor.
    Ray
  6. atch
    atch
    on all of the banjos I've had I had to wire brush the web to find the numbers. on closed drive banjos the numbers are on one of the vertical webs (I believe the bottom one) on the top/bottom surface.
    my only open drive banjo is 3 hours away from here so I can't just run out and verify this information for it.
    anyway, if/when you find the numbers they will be the number of teeth on the ring gear and the pinion gear. just do the math to find your ratio.
  7. hellerlj
    hellerlj
    from Minnesota
    OK...I went down to the storage....locked one side and turned the free one
    around twice (2turns) the Pinion turned about 3 3/4 times, maybe a hair more.
    SO.....as a guess, what might my ratio be ???????
  8. hellerlj
    hellerlj
    from Minnesota
    Thanks for your lead on the "Web Castings".....Mine are only 30 minutes away, next
    time I got back, I will look there....already left the wire brush there...
    Appreciate your Time and Expertise...
  9. Hnstray
    Hnstray
    from Quincy, IL
    3.78..........."or a hair more"....4.11 ?
    Ray
  10. hellerlj
    hellerlj
    from Minnesota
    Ray....Thanks....pretty sure it is the 3.78....it DEFINITELY didn't go 4 turns...appreciate your help
  11. Mart
    Mart
    I put a video on youtube showing the method described above.
    here's a link.
    You can also hear my Birmingham accent. Think Ozzie Osbourne with less slurring.
    Mart.
  12. Budget36
    Budget36
    Just FYI..if you're going to sell them, they are '42 to '47 PU rear ends, not F1's...good market for them too.
  13. Texas Webb
    Texas Webb
    The numbers are on the bottom rib.If you were closer I'd buy one.:)
    Good video Mart.
