Hot Rods Filler over rattle can paint
Discussion in 'The Hokey Ass Message Board' started by Gus68, Feb 18, 2024.
  1. Gus68
    Gus68
    from Minnesota
    So im putting together some junk, and i had to put in a few patch panels. I ground the welds down and sprayed some rattle can paint over it all to keep it from rusting. Now im ready to for a little filler and some sanding to get it good, or should i say "gooder". So do i have to completely sand and remove all the rattle can paint before? Or can o just scuff it up and go for it? I tried some googling, but couldn't really find what i was looking for.
  2. KenC
    KenC
    Your filler will adhere to the paint just fine, if it's scuffed first. Will you paint stick to the metal as well? That is the gamble. I wouldn't.
    Desoto291Hemi and loudbang like this.
  3. lostone
    lostone
    from kansas
    I wouldn't do it either, sand to bare metal and go from there...
    Bandit Billy and Desoto291Hemi like this.
  4. Id get at least the majority of it off.
  5. rockable
    rockable
    Some lacquer thinner will wipe that rattle can paint right off. Don't put filler over that.
  6. Gus68
    Gus68
    from Minnesota
    Ok. Ill try the lacquer thinner and a little scuff and go from there. Thanks alot!!!
  7. BamaMav
    BamaMav
    from Berry, AL
    Or gas. Painted a carb one time, looked good until it got some gas on it, paint peeled like an old barn.
    I'd go back to bare metal if it was me.
    Desoto291Hemi and rockable like this.
  8. gene-koning
    gene-koning
    I'm going to say that it depends on which spray paint you used, and how the surface was prepared before the spray paint was applied, and how long ago it was spray painted.
    Lacquer thinner doesn't have much effect on the old oil base paint from years ago, after it has cured. I'd say get as much of the old paint off as you can. "Gooder" will be OK because you are probably not expecting it to last forever.
    Then, if you want to go back in someday and make it "more gooder", the old filler has to all come off or cracks between the new filler and the old filler happens.
  9. twenty8
    twenty8
    Just reading it made my **** clench, so I am going to say 'get rid of it first'.
    mad mikey and Desoto291Hemi like this.
  10. Gus68
    Gus68
    from Minnesota
    Ya. Its not real old. Its rustolium, so im guessing it should come of with lacquer thinner. I just wasn't sure if all that would be necessary.
    Tow Truck Tom likes this.
  11. Bandit Billy
    Bandit Billy
    If you are going to do a cheap paint job or a primer thing, whatever. If, on the other hand, you are going to put some paint down and have something that endures and looks good, no way. Risk-reward. That's like hitting driver off the deck over 250 yards of water. Better off laying up
    lostone likes this.
  12. 57Fury440
    57Fury440
    Remove it. It can't be that hard to remove some sprayed on Rustoleum.
    rockable likes this.
  13. greybeard360
    greybeard360
    Gasoline?
    Would not be my first choice. It will leave an oily film on the surface.
    Tow Truck Tom and guthriesmith like this.
  14. A 2 B
    A 2 B
    from SW Ontario
    I have never seen a good result from building over Rustoleum. Knock it all off, prep, using a compatible paint system and refinish. Otherwise it is just a matter of time before it bites you in the a$$ ( as in time & money).
    57Fury440, lostone and Tow Truck Tom like this.
