Projects Final chapter in the crummy chop
Discussion in 'The Hokey Ass Message Board' started by Thommyknocker, Aug 20, 2009.
  1. Thommyknocker
    Thommyknocker
    from Colorado
    There is a '52 4door in the yard.
    Chev's of the 40s shows the back gl*** is the same, 49 to 52.
    I'll bring by garnish molding out and verify the size is the same.
    even if the sail panels arn't quite large enough, it would save me quite a bit of work.
    Gota figure out a plan to get it.
  2. Thommyknocker
    Thommyknocker
    from Colorado
    Oh YEA!
    Nice productive morning, My buddy Mark and I went to our local pull a part with a generator and saws-alls.
    $32 bucks later and I'm a happy man :cool:
    Now the work begins
  3. Thommyknocker
    Thommyknocker
    from Colorado
    First test fit.
    I'm thinking:
    The bottom of the window needs to drop a little more.
    The window needs to tip forward a bit more.
  4. Bash'n'Weld
    Bash'n'Weld
    Yep, sounds about right.
  5. picasso
    picasso
    I put a new roof on mine as well, the first chop was such a mess that the previous owner lopped the roof off and ditched it. I found a good 52 roof and door tops and started over.
  6. Thommyknocker
    Thommyknocker
    from Colorado
    Mang.
    There are some awsome chevys out there being built right now!
    It's starting to look like something now.
    I've got an extra trunk so I'm going to pancake this one. That will let me get the catwalk and the trunk to flow together.
  7. 38FLATTIE
    38FLATTIE
    from Colorado
    Now your talking!
  8. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks Flatty,
    I snuck a little play time in this afternoon.
    This is 3" vertical (overlap for now) on the back of the trunk.
    I tried 4 but I looked to far.
  9. Thommyknocker
    Thommyknocker
    from Colorado
    The ***** tuck is coming along nicely so far.
    A few tacks to start with, I'll do the center strip next then the front piece.
    Looks like it will line up ok with the roof, might need to lower it a bit more and bend that piece below the belt line.
  10. Bash'n'Weld
    Bash'n'Weld
    Give us a couple of close ups around the back, lookin good so far.
  11. Thommyknocker
    Thommyknocker
    from Colorado
    Sure thing!
    Is this what your looking for?
  12. Bash'n'Weld
    Bash'n'Weld
    Yeah that's it.
    What made you dice it up instead of just cutting out around the outside of the boot? Any problems with the fitment?
    Cheers
  13. Thommyknocker
    Thommyknocker
    from Colorado
    Do you mean cutting a pie section out and squishing it down like Flop did?
    Well, Flop said he had a bunch of trouble getting it to fit again after doing that.
    I figured that's because the inner structure is stiff enough to cause the outside lips to warp when the center is forced down. (I started off by t******* up the inner structure with pie cuts to get it to move. I eventually cut it complete out cause it wouldn't move far enough easily)
    I've seen a few other pictures where they did it this way. Cutting the center out, repositioning it, and weld it back up.
    It seemed like the better way to me.
    Thom
  14. Flop
    Flop
    nice work seems alot easier doing it the way you are doing it . ohh and is that your tool box in the back of the pic with all the brightly colored handles hahahahah
    sorry im goin completley crazy with this broken hand
  15. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks Flop for chiming in, I'm a little worried about puting the inner structure back in, can't do it without opening the trunk LOL
    Should be able to get it close enough though.
    Those are my fire supression system/child chasers/ kittiecat drenchers :D
  16. Flop
    Flop
    i tacked mine from the inside(me in the trunk ) to get it mostly secure still havent finished the rest yet
  17. Thommyknocker
    Thommyknocker
    from Colorado
    LOL I bet that was fun
    Dang, I'd never get in there, all my air ride stuff is over the rear axle.
  18. Thommyknocker
    Thommyknocker
    from Colorado
    Nice productive few days.
    Got the trunk all pached up.
    That center strip down the middle sunk on me a little (bout 3/16")
    I stacked some 2x4s under there and with the weight of the trunk on the end of a stud, I stiched it up around it.
    Repeat a few times and I'm only 1/16" low in a few spots.
    When I have it stiched up more, would I be doing hammer on dolly from the inside to bring that up a it more?
  19. Bash'n'Weld
    Bash'n'Weld
    It's looking really good.
    As you were, carry on.
  20. landst
    landst
    keep it up Looks like its going to come out nice
  21. 38FLATTIE
    38FLATTIE
    from Colorado
    It's looking great! I need to catch up with you one of these days.
  22. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks guys for the kind words.
    It helps a LOT!
    Absolutely, looking forward to it.
    I'm going to try and hit the show at king stoopids on 35th ave.
    Prolly before lunch, then it;s on to a friends welding party on his IH
  23. 38FLATTIE
    38FLATTIE
    from Colorado
    I'm still at work in NoDak, so I'll holler at you when I get home.
  24. Thommyknocker
    Thommyknocker
    from Colorado
    Looking forward to it.
    As you can see in this pic, I wasted my weekend welding the trunk up LOL
    It's not to shabby, I've got an oil can right in the middle I gota work on, but the shape is there.
    I'd like a bit of advice on how to proceed with the roof.
    Namely where they overlap, it's about 1/4" sunk all along that seam.
    Illistrated by the gap under my ruler.
    How would one go about bringing BOTH pieces "up"?
    Would a few pie cuts on both pieces let me do that?
    Thanks for the help.
    Thom
  25. sko_ford
    sko_ford
    i hate to say it but you cut it to small and to will take a lot of releaf cuts to pull that up
  26. Thommyknocker
    Thommyknocker
    from Colorado
    Dont say that! I havent final trimmed yet
    There is still 2" of extra metal on the back window section.
  27. sko_ford
    sko_ford
    it just looked like be for you had a lot more on the roof side of the rear window
  28. Thommyknocker
    Thommyknocker
    from Colorado
    Ah, well I did trim it down a bit.
    I'm still "exploring" options.
    If I slide it forward the low spot shrinks, but not that much.
    Here is 3" forward from the last pic, and the low spot is 3/16"
    Still more procrastinating to do LOL
  29. Thommyknocker
    Thommyknocker
    from Colorado
    I think I've got it figured out.
    I wound up skootching is forward just a bit more so the roof slopes lined up better.
    Got a little more t******* to do and start exploring the area just ahead of the trunk before I trally throw some wire at it.
  30. MUNCIE
    MUNCIE
    from Houston
    Your getting it just keep on keeping on!!
