After a lot of looking finally found another world class transmission. Got it tore apart and it all looks good. Pressed the gears off and got ready to change it over to my gears and got to looking after i got the gears on it, i have lost the little ball bearing out of where the speedometer tone ring goes on. I looked all over the garage floor but still not luck. So now all i have to do is come up with that ball bearing or one to replace it and put the tailshaft on. I will be ready to go. After that i am gonna put the trans behind the engine and put it in the frame to stay. All held up by a little ball. Anybody know where to find one of those?? or what size it is. It is wc with elec. speedo
Ace Hardware etc. should have a selection of loose balls. Use a drill bit to get a idea of the hole size for the ball,close is good as long as it goes in the hole and stick above the surface a bit.
got it all back together and put it behind the engine sittin in the frame. gonna start test fitting all the parts now.
