Finally finished my flathead...
Discussion in 'The Hokey Ass Message Board' started by jody165, Feb 21, 2010.
  1. NealinCA
    NealinCA
    Wow...that's gotta be one of the best looking flatheads I've seen.
    What's the finish on the wire looms and air cleaner bonnets...brushed nickel?
    Thanks,
    Neal
  2. jody165
    jody165
    Yes, heads on the floor in background are stock Ford Canadian 24 stud heads.
  3. HeyyCharger
    HeyyCharger
    Now that's a beautiful looking Flathead!
    Excellent job!
    HC.
  4. jody165
    jody165
    Wire looms are stock steel looms sanded with scotch brite pad and painted with matt clear enamel. Air cleaners are spun aluminum, I had holes cut and wire mesh put behind for better breathing. I wanted louvers in them but nobody I found could do it. Mike at Sir Michaels did the holes and screen for me. They came out nice and they are unique for sure. Should breath well.
  5. WOW! Well done, excellent detailing!!!
    James
  6. jody165
    jody165
    Actual Neal, your engine is the bomb. I studied the pics you posted of it quite a few times... Perfect.
  7. Sellers Equipped
    Sellers Equipped
    from San Jose
    Wel sir I have quite a few, my bad, looks like the thermostats screwed in,?? I've always modified the neck on the heads to hold a thremastate in. So I guess I'm anybody, Still a sick looking motor with the brushfinish
  8. jody165
    jody165
    Thermostats are sitting in the neck (after alot of grinding to make room for em) but have a very small set screw in them which goes vertically into the thin neck to keep them in place. They also have a few little holes drilled in them so they don't shut off the flow completely when closed.
  9. Sellers Equipped
    Sellers Equipped
    from San Jose
    I noticed the holes, way to do it. Very well thought out,
  10. zephyrV12
    zephyrV12
    from pomona ca
    nice really nice
  11. tikidiablo
    tikidiablo
    from so cal
  12. HotRodMicky
    HotRodMicky
    Awesome Engine!!!!!!!
  13. Rickybop
    Rickybop
    Wow...I have to apologize, SE. I really didn't mean to disrespect you. I think it was actually my bad. I made light of what you were saying. The truth is, I have never messed with aftermarket heads...just stock ones. And as I'm sure you know, the thermostats are designed to go in that location on stock heads. Now after thinking about it, I understand where you were coming from. If I've got my facts right, you were referring to the fact that aftermarket heads don't usually accept stock-style thermostats, and you were complimenting Jody on the fact that somebody took the time to modify the heads so that the thermostats could be installed there! Am I correct? I'm sorry. I was trying to be a smarty with actually limited knowlege...doing exactly what I dislike seeing others do. I'm sorry. I'm an ***............I'm a sorry ***! LOL.
  14. Flying Tiger
    Flying Tiger
    from Japan
    Beautiful looking motor!
  15. 1928arat
    1928arat
    from australia
    Mate that is the ducks guts
  16. 40FORDPU
    40FORDPU
    Sweet, very nice detail, well thought out. I like your '40 also.
  17. tommy
    tommy
    I love the luster on the intake and heads is that a speed secret that you'd care to share? Your detailing is beautiful!
  18. JeffCTN
    JeffCTN
    Nice. Gotta keep this thread.
  19. f1 fred
    f1 fred
    from mn
  20. thunderbirdesq
    thunderbirdesq
    Hey Great looking engine! Funny that you mention Neal's engine, when I saw yours, I thought of his. You can see the influence. They're both showstoppers!! Nice work!:cool:
  21. jody165
    jody165
    Gl***beaded and then a coat of Gibbs penetrating oil.
  22. bikeguydave
    bikeguydave
    from Kentucky
    Beautiful motor, what are your plans for an oil filter and a fan?
  23. NealinCA
    NealinCA
    So similar, yet so different...
    Amazing how much the different colors/finishes change the look.
    I really like what Jody did...
    Neal
  24. NealinCA
    NealinCA
    ...I just noticed something. Is it the angle of the pics or did Edelbrock take the ***y curves out of the Slingshot "Y" when they cast the new ones?
  25. jody165
    jody165
    Fan will be stock 40 fan bolted to crankshaft, you can see the hub in the pic.
    No oil filter or PCV. I used good air filters and will change the oil often. I should get alot of time out of this engine despite no filter considering it's only used 5K miles per year. Using thermostats should help a little with the sludge issue too so no PCV valve. I'm actually just lazy ... but instead will claim that I wanted it old school...;)
  26. jody165
    jody165
    Must be a technical upgrade, I'll probably get 5 more HP than you :eek::D
  27. treb11
    treb11
    ok, I'll be the dummy, what are "ORD" heads / where did the originate?
  28. Uptown83
    Uptown83
    what a sweet lookin engine
  29. banjorear
    banjorear
    Man, that is nice looking mill. Great job. I also like the look of those looms. I think I'm going to steal that idea.
    Question: Are those Ord heads from D. Orosco? They look awesome.
  30. deucegasser
    deucegasser
    The combination of that motor in that truck will be a helluva good looker. Now about that worthless intake hangin' on the wall that you don't need.............?
