Finally finished my flathead...
Discussion in 'The Hokey Ass Message Board' started by jody165, Feb 21, 2010.
  1. yellow wagon
    yellow wagon
    from WI
  2. jody165
    jody165
    Heads are from Don. So was the NOS mallory 6v coil on the front of the engine. Has alot stronger spark than stock 6v coil. What a nice guy by the way.
  3. jody165
    jody165
    Look up "Mal Ord" on here or google. One of the originals.
  4. jakedmoe
    jakedmoe
  5. 65PANELRAT
    65PANELRAT
  6. banjorear
    banjorear
    Cool. Love that you kept it 6V. You are hard core or have a lot of hills to jump start it!
  7. jody165
    jody165
    I hear 8BA starters have a little more torque due to slightly increased compression of later flattys, would like to know if that's true or not. (anyone?) Might have to get one if the increased compression causes slow starter rotations....
    Also thinking I may need to modify a stock battery shell with a secret Optima inside.... will do whatever I have to. I don't need no 12 stinking volts.
  8. Doc.
    Doc.
    Also thinking I may need to modify a stock battery shell with a secret Optima inside.... will do whatever I have to. I don't need no 12 stinking volts.[/QUOTE]
    Check out the Antique Battery company. They do exactly what you are thinking about and their stuff is top notch. They are a little spendy, but the quality is awesome.
    Doc.
  9. NealinCA
    NealinCA
    I've heard Lincoln V-12 starters are higher torque and were the ticket for high compression engines....according to a local old timer. They are about an inch longer than a Ford starter.
    I'm not that ********. I like my 12 volts. :cool:
    Neal
  10. banjorear
    banjorear
    I thought they were all the same. If your starter is in good shape, it should do it. Making sure the timing is spot on is going to be the trick with the 6V system.
    My pops '32 Tudor w/ a 59 AB & '49 F-1 are still 6V and they will start. Sometimes quicker than other times, but they always (generally maybe) start.
  11. Beautiful! '40 pick-up has always been one of my favs since Highschool. :D
    the one that got away. :( 1980
  12. banjorear
    banjorear
    Neal:
    C'Mon, bro. They don't come much "hard core" than you my friend. Didn't you start out using a 6V system?
    Tim
  13. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Killer Flatty, Happy Crusin'.
  14. pa1nter2
    pa1nter2
    Sweet, I'll be drooling all night over that motor, lol
  15. I SMELL SMOKE
    I SMELL SMOKE
    very nice work!! flawless!!
  16. FordMaverickFanatic
    FordMaverickFanatic
    from Taylor, MI
    Bad***, I wish I had room time and money for a flattie.
