Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. One Finger John
    One Finger John
    Try more initial timing.
  2. swade41
    swade41
    from Buffalo,NY
    I was reading an old 1979 PHR tunnel ram tech article and it said to put as much initial as you could turn over on a hot engine. Getting the distributor out to change the advance is a pain in the ***, it's kinda under the firewall...lol
  3. BCCHOPIT
    BCCHOPIT
    Make a set up like a model A. Use a rod or cable and move the dist. from the dash.
  4. swade41
    swade41
    from Buffalo,NY
    I ran into my old neighbor from about 12 years ago, he's in his upper 70's. I told him about getting the Henry J and he started laughing. It seems when he was 17 he and his buddy would go to the local drive-in and cause trouble in his Henry J.
    They had a windshield squirter pump hooked to a can of kerosene, with the outlet hose fastened above the carb. They would shoot the kerosene down the carb and it would smoke out the drive-in. He really had a light in his eyes while telling me of his misguided youth, "As long as you could keep it running, it would smoke out the whole place. Nobody could see then we'd tear hell out of there with that flat four"
    Good stuff
  5. swade41
    swade41
    from Buffalo,NY
    I ment to pull the distributor and recurve the advance to get more initial, I'm running pump gas and don't want to go much higher than the 36 degrees total.
  6. henry's57bbwagon
    henry's57bbwagon
    Sorry swade but I have to ask. Wisenheimer, any info on the West coast HJ?
  7. henry's57bbwagon
    henry's57bbwagon
    swade, we put a toggle switch for the ign switch in line to kill the ign power on our race cars and when they are hot and don't want to turn over with the advance we run we turn off the ign and then while the engine is cranking over turn on the ign sw.
  8. langy
    langy
    Don't know how i missed this thread, great story and a great car mate
  9. Baron
    Baron
    Have you tried adjusting the timing at all for the bog problem? I had a similar problem with one of my cars and installed the two heavy springs in the dist (MSD) to raise the RPM for full advance to come in later. Just a quick and easy (10 minute job in my Ford motor....just realized where your dist is) trick to try .
  10. One Finger John
    One Finger John
    22-24* initial should be o.k.. Get the engine nice and hot on the street, play around with the initial timing and starting situation, note, and pull the distributer once. Could go to electronic dizzy. Spending your money, Heh, Heh, Heh. I'd also invest in five galleons of race fuel. You can blend it with street fuel if the race fuel is unleaded. Don't need to rattle the engine even if it has forged pistons. What rpm do you leave the line? Do you have vacuum advance? All in by 3500 should be fine. Too bad you don't have retard for top end. Something else to play with. Main thing is to tune it to run the best at the strip and still run well on the street.
    Best of luck, John
  11. henry's57bbwagon
    henry's57bbwagon
    Thanks wise for the info, pic's.
  12. mailerguy1
    mailerguy1
    Cool Henry Phil :D
  13. swade41
    swade41
    from Buffalo,NY
    Not yet, kinda afraid to put more into it and go over that 36 degrees....lol
    Yesterday I went back to the 60 jets in the front carb and left the 63's in the rear. The rear 4 plugs looked pretty good, so left that alone and will try this and see what the plugs look like.
    Today I will move my ladder bars back down after I finish the transmission lines on the silverado, what a ****y freaking job that is !
  14. swade41
    swade41
    from Buffalo,NY
    Thanks man, not as great as what you're doing but I'm still having fun !
    Didn't get those bars moved today but everything is ready to get them out. It seems the trans cooler fittings from the dealer were the wrong ones for the silverado. So I spent the day driving around chasing the fittings but now that job is done. I can tow the J without worry of blowing a line ..woooo hoooo
  15. swade41
    swade41
    from Buffalo,NY
    Hey, got past the first round...lol
    Jet change, ladder bar back to middle hole and a couple degrees out of the pinion angle and put my timing all in at 2450.
    The car went 7.36 last time out and with new changes went 7.33 @ 93.76 on first p***. I was able to get that down to a 7.26 @ 94.02mph with a little better launch (1.590 60ft) and cooler air. So no big change in the launch with the new ladder bar location and no change in my slow reaction times either !
  16. swade41
    swade41
    from Buffalo,NY
    I've decided on two changes before the big Gold Cup race this weekend. I bought a couple 50cc pumps off a fellow HAMBer , if they get here in time those will go in.
    The other will be a jet change to 61's in both carbs, then.....let the fun begin !
  17. swade41
    swade41
    from Buffalo,NY
    Oh yeah, put my new valve covers on too, gotta look good for the race..lol
  18. Baron
    Baron
    Phil. Not being a wiseguy, but don't you want the breathers be mounted toward the inside of the motor ?
  19. swade41
    swade41
    from Buffalo,NY
    Ha ha, the big debate..lol That's the way they were mounted and also the only way I have ever seen these style mounted. These still had the factory gaskets still under them and have a heck of a baffling system designed into it. I did make new cork gaskets and took the liberty to cover a little bigger area.
    I did run some Offenhauser 90 degree breathers the same way on my t-bucket for 3 years with no drips on the headers. Those pictured on the dummy engine now
  20. swade41
    swade41
    from Buffalo,NY
    When I drilled the vette covers for Moon breathers I did put them on top. This is what's on the t-bucket now
  21. swade41
    swade41
    from Buffalo,NY
    Well with those changes the car picked up to a 7.23 @ 95.14 right off the trailer and a 1.56 60ft. We are having fun !
  22. One Finger John
    One Finger John
    Which helped more, the acc. pumps or the jet change? Have you given it more initial timing?
  23. Baron
    Baron
    Good deal. ( I think the M/T valve covers did the trick. ;) )
  24. swade41
    swade41
    from Buffalo,NY
    No on the more initial , just changed springs to bring the total in at 2450. The accelerator pumps and pump cam sure did the trick.
    I got the car down to 7.18's on Saturday with a 1.54 60ft, huge difference off the line !
    You are exactly right, they had my wheels a foot off the ground according to the spectators. This shot is early or late...lol
  25. swade41
    swade41
    from Buffalo,NY
    Thanks, I've been trying to save all the ones I find..lol
  26. swade41
    swade41
    from Buffalo,NY
    I just wanted to share a couple runs I made on Saturday, if it did this all the time it would be easy...lol
    I tried scanning these but didn't work but check out these two time slips and how it was down to the last digit for separation.
    The first at 7:04 pm and the second at 9:44 pm which was first and second rounds on Saturday.
    60 ft -- 1.545 / 1.540
    330 -- 4.604 / 4.600
    1/8 -- 7.188 / 7.183
    mph -- 94.63 / 94.61
    amazingly close runs I think
  27. Baron
    Baron
    Running like the Pro's. Now to consistantly cut that .500 light is the trick. ;)
  28. daliant
    daliant
    Looks like you finally got rid of the gremlins and the bad juju, hopefully no more broken parts or body damage. I enjoyed watching you and the other g***ers run at Empire last Saturday.
  29. swade41
    swade41
    from Buffalo,NY
    Glad you had a good time daliant and Baron oh so true. I had a 5.04 and a 5.14 last weekend but had a few 6's and a 7 too...lol Now that the bog is gone I should be able to work on those lights, there's only 3 races left to do it.
  30. swade41
    swade41
    from Buffalo,NY
    Well racing was rained out here so I gave myself a task of retro fitting some chevy ll front drag shocks to the J. The first attempt had great lift but were bottoming out a little to soon on the downward move.
    So learn a little and plan 2 worked out great, made new brackets and lowered the bottom of the shock down to get more travel. Manually working the suspension all looks like it will work great, I set them on the 90-10 setting.
    I also got my 8 yr old out to turn the fuel pump on and off to set the floats. One was a little high and the other three were low, I set them with the car at a slight uphill grade like acceleration would put it.
    Kinda excited about testing this out !
