Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. swade41
    swade41
    from Buffalo,NY
    Next up was moving the electronics since I moved the firewall and running all the wiring back through the new firewall and out to the engine bay, fun stuff.
    I bought new gauges so that ment I also needed to make a new gauge panel out of my favorite dental parking only sign.
  2. swade41
    swade41
    from Buffalo,NY
    I found another set of 427 M/T's that already had a breather in the same location I wanted to mount breathers to in my really nice practically nos 427 covers, so I got them to avoid drilling the nice ones.
    They looked rough but I knew they'd come around with some sweat equity and I definitely put some sweat into sanding and polishing them.
    20220909_155339.jpg 20220914_172501.jpg 20220916_165338.jpg 20220921_164734.jpg 20230205_194732.jpg 20221005_145720.jpg
  3. swade41
    swade41
    from Buffalo,NY
    I decided to move the fuel tank from under the car to inside the car since under the car the wheelie bars are trying to take up the same spot. Moving it inside means I need a bulkhead to separate it from the p***enger compartment so I started making patterns trying different arrangements.
    I thought a 3 piece design would work with the center removable so I can service the fuel cell if need be.
    That didn't work out so a new 2 piece pattern upper/lower seemed to work
    Transferred that over to aluminum and put together a homemade break to bend it up.
    Got the fit down pretty tight
    20230222_160153.jpg 20230222_160206.jpg 20230222_160521.jpg 20230222_160452.jpg
    Currently working on a couple braces for support and making mounting tabs.
  4. alumslot
    alumslot
    I'm going to steal the idea of the mounting bar for the fuel regulator. I'm doing a big block J my self. can't wait to get it done.
    Jim
    swade41 likes this.
  5. FinnishFireball
    FinnishFireball
    Thanks for the update Swade. How about some X's bead rolled to those puzzle pieces. Like that they might shake rattle and roll quite annoying.
  6. swade41
    swade41
    from Buffalo,NY
    The upper half has to bend like a banana to go into place do to the shape of the car and rear window, so definitely can't put anything in that piece.
    I did think about putting something in the lower piece but I'm hoping the two vertical braces just on the inside of the roll bar tubes will quiet the rattle.
    I've also thought about gluing some inner tube rubber in the mounting points.
    enloe and SS327 like this.
  7. FinnishFireball
    FinnishFireball
    Sounds like a plan then, thumbs up!
    swade41 likes this.
  8. enloe
    enloe
    from east , tn.
    VERY COOL
    swade41 likes this.
  9. swade41
    swade41
    from Buffalo,NY
    I've used that spot in the past on a couple different engines, just space it off the head so it doesn't get heat soaked. When you don't have inner fenderwells or bars off the roll cage out there you need to get creative.
    INVISIBLEKID, enloe and mad mikey like this.
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    nice
    I would think about eliminating the power valves in the 2 x 4s and up-jet about six sizes to compensate.
  11. alumslot
    alumslot
    ^^^^ Man that sure looks good. Yea mine doesn't have fender wells either. I used 62-67 Nova big block fender well headers and had to make room for the drivers side don't know why but had too. It's not a stock fire wall either. they are making M/T valve covers again got a set of those.
    Jim
    swade41 likes this.
  12. swade41
    swade41
    from Buffalo,NY
    I blocked off the secondary power valve in the other original carb to match the new carb that doesn't have provisions for a rear. I'll see how it goes and adjust accordingly while tuning things in, I tend to keep at them until they are right.
    enloe likes this.
  13. 4 pedals
    4 pedals
    from Nor Cal
    Good to see you back at it!
    Maybe I'll find another one that's not all rotten someday.
    Devin
    swade41 likes this.
  14. swade41
    swade41
    from Buffalo,NY
    I just piddle away a couple hrs a day (or week) I'm trying to live a stress free life here ya know.
    Having multiple projects and jumping around between them, nothing major seems to get done towards the goal of having them "finished" per say, but the more I do today means there's less to do tomorrow.
    After this fuel cell/bulkhead/cutting a hole in the body for fuel inlet debacle it'll need :
    battery relocated and wired
    brake lines made
    couple fuel lines from cell to filter made
    transmission lines made
    lower radiator hose sorted out (pain in the ***)
    gas pedal located (pain in the ***)
    throttle linkage
    exhaust
    Hopefully it'll run, then sort out the new car blues, how do these guys build these cars in an hour on these TV show lol
    59Apachegail likes this.
  15. swade41
    swade41
    from Buffalo,NY
    I ended up collecting a set of 15x11 and 15x10 slots in 5x4.75 pattern
    So I pulled the axles and sent them back to Moser to get redrilled to 5x4.75 with screw in studs in 1/2 inch ford size.
    I redrilled the drums myself, pulled the street tires off the old ford pattern 15x10's and put them on the 11's
    Bolted them up and for the first time I have the same bolt pattern front and rear, now the only one that still has a miss match of bolt patterns is the t-bucket.
    Still need to order different lug nuts and get the 29x11 slicks swapped around.
    OahuEli, enloe, LOST ANGEL and 5 others like this.
  16. 59Apachegail
    59Apachegail
    from New York
    Coming along, she is looking good!
    swade41 likes this.
  17. swade41
    swade41
    from Buffalo,NY
    Thanks, slow and steady progress
    Not looking forward to cutting a hole in the body for that fuel neck but it's getting close to the time to start planning it out and ordering parts.
    I have to look up the NHRA rules on flip top caps too, I think I remember that they have to have a positive locking mechanism to be legal.
    Something like this
    https://www.speedwaymotors.com/Smal...AfE4N9EeWXqtQvlDZ_ITBuuOwW1MYSIhoCJWAQAvD_BwE
    Or this maybe
    https://blueteksupply.com/products/...YX7aUGiGeGKqyvLxG-AZHeoL4ocYCpkRoCP6AQAvD_BwE
  18. -Brent-
    -Brent-
    Hell yeah! Looking great!
    swade41 likes this.
  19. 59Apachegail
    59Apachegail
    from New York
    My mind starts spinning when I see something like that. I thought how cool would it look if you were able to get the monogram from the horn ****on into the center of that gas cap. A little tribute to before it was a race car.
    enloe and swade41 like this.
  20. swade41
    swade41
    from Buffalo,NY
    Interesting idea, to be honest I've never seen a stock Henry J, so that's a first seeing the the big K.
    enloe and 59Apachegail like this.
  21. ididntdoit1960
    ididntdoit1960
    from Western MA
    I've got this one left over if you can use it
    swade41 likes this.
  22. swade41
    swade41
    from Buffalo,NY
    What's the size of the hole and the bottom look like ?
  23. swade41
    swade41
    from Buffalo,NY
    Ist day of spring !
  24. swade41
    swade41
    from Buffalo,NY
    SHAZAM !
    Bulkhead is done
    Now onto the fuel side of town
    Tman, enloe, malibumonte78 and 3 others like this.
  25. swade41
    swade41
    from Buffalo,NY
    I've been making a gas cap out of some kind of coupler I bought for $5 bucks at a swap meet, I capped it off with a domed gl*** lense and made a couple different inserts to fit inside.
    20230329_144743.jpg 20230329_154238.jpg 20230330_170217.jpg 20230410_172642.jpg 20230409_171847.jpg 20230410_172624.jpg 20230403_124500.jpg 20230407_183530.jpg 20230407_184751.jpg 20230413_165611.jpg 20230413_163633.jpg
  26. swade41
    swade41
    from Buffalo,NY
    I got a piece of aluminum 2 inch pipe to serve as a filler tube, didn't fit so I expanded it over a trailer hitch ball and hammered a lip up top.
    20230414_174406.jpg 20230414_174801.jpg 20230415_175055.jpg 20230417_144734.jpg 20230417_144709.jpg
  27. swade41
    swade41
    from Buffalo,NY
    I ordered an RCI 45 degree filler neck, it came in and it was indexed crooked when welded on, that'll throw things off kilter.
    I didn't have any tubing that was a tight fit to the fill neck to mark the location of the gas cap so I improvised with some pvc.
    This won't give me an exact location since the blind man welded it on all catawompus, but at least it'll give me the height of it.
    Then I marked center on the outside of the body in preparation for cutting a big damn hole in it.
  28. swade41
    swade41
    from Buffalo,NY
    After measuring 10 ways from Sunday I marked my hole location
    Picked up a 2 1/4 hole saw to sneak up on the 2 3/8's hole I need
    And cut a big *** hole in my body
    All that measuring paid off, filler neck cap is straight down the pipe
    I'm digging it, now to order a 2 inch to 1 3/4 inch fuel hose to connect the two
    OahuEli, Tman, 59Apachegail and 7 others like this.
  29. 59Apachegail
    59Apachegail
    from New York
    That is COOL!!
    swade41 likes this.
  30. swade41
    swade41
    from Buffalo,NY
    Updating some photos of making a removable scoop so I have options for different looks, reversed the flange on the Shelby GT350 so it looks better and added a filler piece on the rear.
    20200422_160901.jpg 20210516_174109.jpg Screenshot_20230322_001202_Facebook.jpg FB_IMG_1681996804106.jpg Screenshot_20230322_001124_Facebook.jpg Screenshot_20230322_001137_Facebook.jpg FB_IMG_1681996800769.jpg FB_IMG_1681996811348.jpg
    Sure it's a 427 ..... uh-hmmmm ... wink wink
    10-32 ****on head fasteners hold it on
