Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. LOST ANGEL
    LOST ANGEL
    Looking good!-MIKE
  2. swade41
    swade41
    from Buffalo,NY
    Thanks Mike, I'm addicted to working on it, not even sure if I'm going to the g***er series race at Empire today...lol
  3. Chieftec160
    Chieftec160
    Are you creeping that Lada 2103/2106 speedometer?:D Not very traditional eh?
    Cool build! [​IMG]
  4. Hdonlybob
    Hdonlybob
    Very nice build.
    Looks like you are taking your time and doing it right!
    Good for you.
    Cheers..........
  5. NortonG
    NortonG
    Keep at it Phil! I still need to get down there to see you guys asap!
  6. INJUNTOM
    INJUNTOM
    Awesome. I remember building the model when I was a kid..
  7. swade41
    swade41
    from Buffalo,NY
    Hey that speedometer says it will really go fast. lol
  8. sololobo
    sololobo
    Yikes, atta boy, no messin around here!! Congrats man. ~sololobo~
  9. LZ
    LZ
    Geez Phill. How did I miss this??:eek:
    Heard you got one. Good deal hope you can get it out soon.
    There is a J that a RSR member has picked up this spring. heard it needs a bunch of work. Should see the dude at the club race Wednesday... Will ask him if he has seen your link.
    Car looks great.
    Crunch time is here ,call if I can be of some help.
    see ya
    Luke
  10. dragrcr50
    dragrcr50
    Im likin this deal for sure..... ony question I have is maybe the trans cooler looks like the first thing you see in the front, i have the same one but is under floor out of sight??/ just my 2 cents. the J front end is timeless with the big open here I am mouth on it... keep up the great work ... i have another one to do this winter more streetable like yours ....sam :cool:
  11. gassercrazy41
    gassercrazy41
  12. swade41
    swade41
    from Buffalo,NY
    Thanks everyone, to hear compliments and just general feedback is pretty cool.
    Luke I would put you to work if you were closer, but you might not like the working conditions of my garage..lol
    Sam I stuck that cooler up there to be seen, I don't have a moon tank or the likes so something has to go there. lol Actualy I have that canteen to use as the overflow that I'm going to try and put up front. I think the general shape will fit in the area where the hood is arched up front.
    I got my driveshaft today and installed that, then was side tracked by a broken motor mount in the t-bucket. I put solids ones back in there so that should take care of that.
    I ordered a master cylinder and that should be in tomorrow, so brake work will start with a bit of wiring to the starter.
    Got a question though about vac***e, there is only one port on these 450's. Will it work for the th350 trans modulator ?
  13. swade41
    swade41
    from Buffalo,NY
    Fired it up yesterday and broke the motor in, running hot for sure. I can't get anymore out of the distributor, hits tunnel ram, so I'm going to back the wires around one hole and try and tune it today.
    I put the slicks on and they stick out just right, was happy about that
  14. Hdonlybob
    Hdonlybob
    Great job on this project. Really looks great.
    Anxious to here how it runs down the track!
    Cheers.....
  15. 550Coupe
    550Coupe
    You sounded like Baron Von Frankenrod on the phone last night. "It's Allliiiiive!!"
  16. swade41
    swade41
    from Buffalo,NY
    Moving the plug wires didn't work so I sanded the window down on the distributor. I need to remark the balancer with the white paint, I couldn't even see the line..lol For now it was done by vac***e guage, but it's ALIVE ! ! ! ! ! !
  17. ModelAPunk
    ModelAPunk
    from Buffalo NY
    IT's ALIVVEE!!!! Congrats Phil, cant wait to see it out this weekend.
    By the way, nice touch on the *******s background music... haha
  18. Hot Rod Trash
    Hot Rod Trash
    Lookin good...sounding great!
  19. LZ
    LZ
    Good going Phill.
    Good for you. Are you going to try and make the Gold Cups??
    As far as the garage goes. Shoot your is way nicer then my **** hole.
    Funny you brought up the vacuum Modulator thing. years ago when I messed with this. I ended up buying an aftermarket adjustable Modulator.
    It was a street car but had a decent cam in it , aftermarket convertor and beefed up T 350.. The vacuum was such that I had to mess a bit with the modulator. . It was easy as a hex (allen) wrench just slipped into vacuum tube fitting end. Just had wrench with me to slip in and adjust on road. after a few adjusts it was spot on for what it was. I had tried the dowel in the line trick with a few different size holes in them ( pushed into vacuum line). All they did is show me it needed tweaking. You manually shifting this most likely??
    Another thing if you dont mind me saying. Make sure its Below throttle plate vacuum. Not ported vacuum.
    FWIW
    hope to see you this weekend, best to you
    Luke
  20. 550Coupe
    550Coupe
    Sounds good. Now some fine tuning and you'll be ready! This is goung to be a fun weekend!
  21. LZ
    LZ
  22. dragrcr50
    dragrcr50
    on the 350 turbo, find a red stripe small can modulator at the local part store or trans supply and it will shift a tad higher and therefore stiffer for you ... get your va*** from the intake if possible or below the throttle plates on the carbs. also you may want to richen it up a bit over all too. t rams will cause hot and lean conditions sometimes, good luck , I like it
  23. paco
    paco
    from Atlanta
    Super job!!
    Was that period correct background music??
    Paco
  24. Dooley
    Dooley
    from Buffalo NY
    advacne it tot he highest reading and then back off 2 inches...looks and sounds great
  25. swade41
    swade41
    from Buffalo,NY
    My buddy Bob just had to bring his timing light with the advance, so now we are in better shape. We set it at 32 degrees at 3000 rpm and it sounds way better, it was advanced in the video. Hope that cools it down some too, lots of bugs to chase as with any new deal.
    Steve (modelApunk) I figured you'd like that, your band and all rockin it out in the garage.
    Thanks for all the advice, I'll be out there this weekend racing or not, a few things left to do and the week is getting shorter.
  26. swade41
    swade41
    from Buffalo,NY
    First time out of the garage, I used the front wheel setup off my truck since the slots were dry rotted.
    I found out the king pins are far worse than I thought once I had jacked the car in the air too. That sure took the wind out of my sails to get it down the track but better safe than a pile of wadded up metal I guess. I have been busting my *** with lots of late late hours in the garage the past month to run this at the first Gold Cup race, really ****ed to say the least.
    I took it to the track anyhow, put it across the scales and to my surprise it weighed 2360, much lighter than I expected ! It still needs tuned but I did goose it a couple times and it had no problem breaking the slicks loose but that front end was looser than those slicks.
    Here it is out in the day light and at the track where it belongs
  27. Good to see you and the car this weekend Swade...your doing a great job !
    Rick
  28. swade41
    swade41
    from Buffalo,NY
    Rick wish it could have been longer, allways great to talk you and your wife.
  29. paco
    paco
    from Atlanta
    Don't get down on yourself about the front end ... you've done way more than most in the time frame you set.
    Drag it back into the garage - fix the needed items & press on.
    Great job so far & you wayyyyyyy ahead of my rig!!!
    PACO
  30. swade41
    swade41
    from Buffalo,NY
    Yup that's the hose, after the king pin find I kinda said screw it and just went on to putting the sealed battery box in the back and putting in the gas pedal and linkage. The things it needed to be able to drive, I've got a polished canteen that will be the over flow catch can.
    I did let everyone know that looked at it if they seen something that needed addressed to let me know. More eyes the better, sometimes you get tunnel vision on certain things and overlook the obvious.
