Projects finally got my long desired 34 3 window
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Jul 19, 2013.
  1. 4 banger 4 life
    4 banger 4 life
    from ohio
    This is going to be one tuff car when done...
    Glad to see u keep it. Its the little things that make em scratch there heads.
    Dash looks right at home.....
  2. hotrodderhaag
    hotrodderhaag
    Finally got the new rear widow frame glued in. Lots of fill work to do but it will work perfectly ! Once I get it smoothed into the window opening, I can use a flat plate of glass and sandwich it between the on window frame and a trim ring I made ,
    I also primed the windshield frame because it kept turning brown every week
  3. hotrodderhaag
    hotrodderhaag
    My metal glass channels finally came in from the all mighty wonderful macs antique auto!! And if you can't hear that sarcasm your def!
    They claim a Tudor sedan and a 3 window are the same,... Flat chance. I called Dick Spadaro, he had to set me straight and give me a bunch of layout measurements so I can cut the brand new ones all apart to make them work. At this point I should have used a gm roller and channel and welded it to the original regulator, but I just can't do that kind if stuff. I want it right , my window channels are not designed to let te window roll back before down as a 34.would have, but I'm ok with that. I just removed the ear off the channel for that. I attached it to my templates for the glass and goes up and down like a champ . For someone using these metal glass changes out of the box!? It will never happen, terrible fit, they were spot welded together crooked and they were also stamped poorly.. I understand cheap parts but these were beyond cheap. They were junk!
    And here is how much they changed .
  4. hotrodderhaag
    hotrodderhaag
    And my buddy gave me NoS brake light switch for it. I like the mechanical ones better than the pressure switches . Just my opinion
  5. 4 banger 4 life
    4 banger 4 life
    from ohio
    Hell ya nice pics. Looks like there is sone extra room for anouther car in there.
  6. hotrodderhaag
    hotrodderhaag
    I stuck the headlights back on. I located a set of early guides with aluminum wing stands on them , but I need to contact the owner and try to pry them off his wall . These will do for now. I just don't like the lenses.
    It seems like a take a lot of photos of this car. Pictures are my motivation ..
    I just noticed the photos that were posted from rolling bones garage night, it showed Richie whalens 33 3 window that they are doing, using a stock good and side panels , the car is top notch perfect! It makes me wish my roof was lower, probably 2 inches to look like his
    It's almost time to trim door skins and get them all fit together. I got new door strikers today. Autozone, ford truck striker bolts. Perfect. They are .105 undersized compared to the original ones designed for the bare claw latches I am using. so I'm ordering brass sleeves to go over them just so the door doesn't have any way to rattle. I won't keep the outter guard on them. It makes a good spacer washer for now though
  7. I know what you mean about photos being motivation. I try and take lots of photos too. it's fun to go back and see where you began and how far you've come.
    As for the strikers, instead of using brass, you can buy plastic ones too. Just thought the plastic might provide some vibration insulation. Either way, I know you'll get it all working perfect.
  8. brian55lvr
    brian55lvr
    from ma
  9. hotrodderhaag
    hotrodderhaag
  10. 4 banger 4 life
    4 banger 4 life
    from ohio
    Headlight are f n sweet looks great...... nice work ben....
  11. Looks really good! :cool:
  12. hotrodderhaag
    hotrodderhaag
    Adding some color
  13. MAD 034
    MAD 034
    from Washington
    Snow shots look killer. Keep at it -- spring is right around the corner!
  14. daddio211
    daddio211
    I get the whole "rather have steel than 'glass" thing, but all that really matters is your smile when you're behind the wheel. Will your smile be bigger in a steel car? I'd venture no, because YOU, with your two hands, sliced and diced this Tupperware body into the proportions and direction it needed to be. YOU did that.
    Sure, you'd so the same with a steel car, but the end result only matters to the one behind the wheel. If someone doesn't like your Tupperware kit car (tongue in cheek) as them to see their Model 40 that they built with their own hands. Screw 'em and keep doing what you do. There is NO shame in what you're accomplishing and you don't need anyone else's approval. Carry on good sir.
    My '27 T Roadster build: www.jalopyjournal.com/forum/showthread.php?t= 734383
  15. Retro61
    Retro61
    I totally agree my friend! I finally scored a '34 5 Window that I begged an old man for, for 25 Freakin years! The whole bottom was rotted off by the time I got it! He's got another one, complete old Hot Rod, won't even talk about selling it! He's 80 yrs old, and has been diagnosed with Leukemia-Twice!! He also has 2, 34 Plymouth Coupes, complete, buildable Cars! Not For Sale!! Pisses me Off!!!
  16. 37jimmy
    37jimmy
    from kentucky
    I know what and who you are talking about ;). But guys, retro61 has taken that beat body and done one hell of a job on it. It is turning into a head turner.
  17. nitrobrother
    nitrobrother
    Hey, if 'glass is good enough for builders like Magoo and Squeeze Jerger (did you see the feature of his 'glass rebuild in Street Rodder?) it should be good enough for us.
    Posted from my steam-powered tablet...using the best Android app out there!
  18. Shamus
    Shamus
    from NC
    I have a glass car with steel fenders, running boards, hood & gas tank panel that I thoroughly enjoy - has all the other "street rod" goodies, too. I also have a few other later model on going projects. I have always wanted an all steel roadster with flathead, wide whites, etc, so I bit the bullet & paid the mans price for a car being restored as original & after a couple of years collecting a few more parts I realized I could never finish it myself (I'm 72 & my body is worn out) so I hired a young guy to finish it. Planning on driving it to Pomona in June. Couldn't afford to do it while raising a family in between wars. I have met guys (even have a few friends) that will not sell U anything but junk & they & I know it will still be there when they are put in the ground. When it's done, I'm cleaning out the garage & storage building & having a yard sale for the left overs. After that I'm going to finish what projects I can & drive one of them everyday I'm able & have fun. Recently sold the '55 after 13 years & my darlin wife didn't survive cancer long enough to see her "Ultra Pearl Violet" & red truck finished. Life is too short to worry about what the other guy says about what U drive!!
  19. BIG-JIM
    BIG-JIM
    from CT
    I hear ya on the rant. Daddio211 said it best. He is one of my big supporters. In the end when you hit the go pedal on the right the smile will be just as big in a glass car as it would in a steel car at a fraction of the cost. I too am taking my glass 34 tudor street rod and hot rodding it. It probably wont come out as good as yours but I can say I did it and it's mine.
  20. 3banjos
    3banjos
    from NZ
    Having a glass 34 too, it's easy for me to understand where ya coming from Ben. Hell, would love to have a steel car also, but mine was an 8yr budget build, only as I could afford things. Acquiring 1 in shit condition is still high dollar, but if that's the dream I fully understand. Like yourself, I tried to keep it real. Original grille, hood, windshield and gas tank. Ali deck skin so could louvre. Genuine 682's also. Just body and doors glass.
    Refused to rechrome the rusty but straight grille, so rest of car built to suit. All legal now and having a ball.
    Your screaming through your build and credit to ya. Looking fine, and I wont tell ya to ditch that front spreader bar, Yet.. Pete
  21. alchemy
    alchemy
    EDIT: There was a big ol' rant above that got removed.
    I think you are being impatient. How long have you been in this hobby? How long have you been searching for a steel body? If you answer under 5 years for the first, and under 1 year for the second, you're being a big crybaby. This stuff doesn't fall in your lap. You have to earn it.
    Do I sound pissed? :)
    PS: You should have told me you were looking for a decklid. I just sold a decent one a couple months ago.
  22. hotrodderhaag
    hotrodderhaag
    Received original window crank out, and I drew and plasma cut the new cowl vent ratchet arm.. I could have Bought one , but what fun is that :) all I have left to do to it is open the holes up to correct drill size to attach it properly
  23. hotrodderhaag
    hotrodderhaag
    And my windshield crank out didn't have the bracket the bolts onto the Windshield frame. So I fabbed one up .. Close to factory look
  24. mad mechanic
    mad mechanic
    very nice! I love the way your doing your best to make it look factory...devils in the detail mate and your nailing it!
    Jay
  25. hotrodderhaag
    hotrodderhaag
    A little better picture of the windshield frame bracket in the flat pattern and all done .. Ooo I got my 2014 hamb member plate in the mail yesterday also. Thank you Ryan
  26. Hotrodmyk
    Hotrodmyk
    Really looking good! Great project.
  27. hotrodderhaag
    hotrodderhaag
  28. Rocky
    Rocky
    Classified Editor
    WHAT??? YOU HAD A GOOD DECKLID??? Damn! Guess I shoulda asked you before I blew 1400 clams on my Steve's louvered decklid.
  29. alchemy
    alchemy
    Rocky I already sold you plenty of parts for your car.
  30. Shamus
    Shamus
    from NC
    "glass" car is looking good - your'e already way past at least 50% steel/real Henry Parts.
    Way to go - you'll be on the road before U know it.
