Projects finally got my long desired 34 3 window
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Jul 19, 2013.
  1. 3banjos
    3banjos
    from NZ
    Good on ya Ben. These cool cars don't need that extra stuff. Less is more as they say.
  2. jammer
    jammer
    Ben , I think your making all the right choices ,it makes us smile each time you do
  3. Dempsey
    Dempsey
    from Murray, KY
    Awesome!
    It's already been said but build what you want. If everyone did the same thing we would all eat vanilla pudding.
  4. hotrodderhaag
    hotrodderhaag
    kiwijeff likes this.
  5. hotrodderhaag
    hotrodderhaag
    Since the hamb was down, I've made some progress. We fired the 327 tri power. It has a nice sound to it. Should be a good power plant! I've been working on small odds and ends. I finally finished the steering shaft. I had to splice a shaft onto the box with a 6 inch stub. I got that all taken care of and ten needed to figure out radiator mounting, alt bracket , and fuel system.. Sooo, I sheared out some pieces and hand made a fuel tank for the trunk. It has 2 baffles inside , fuel sender and all the fittings . Fully tig welded and pressure tested. It was a good fit. It's 18 gallons and takes up a small amount of the trunk
    On to the alternator. I looked all over for brackets to fit.. Nothing worked with the tri power . So I drew my own. It's works rather well. At least it fits under the hood and no one will see it! Don't mind the main through bolt. That was temporary
    The radiator was way to low . So I had to make some c channels to lift it up 2 inches . I ran to the auto parts store and dug out some hoses that will work .
    I will be fitting the grill and hood next along with fitting up exhaust. I ordered two inch smithy steel packs for the car. Should give it a great tone with stainless pipes.
    I need to weld the filler neck back on the radiator and some brackets.. I may have to go bug Matt thrasher again since I still haven't bought an AC tig welder to do aluminum .
  6. ago
    ago
    from pgh. pa.
  7. brian55lvr
    brian55lvr
    from ma
  8. hotrodderhaag
    hotrodderhaag
    After working a 14 hour day, I came home to a bunch of speedway boxes! My drag link, smithy gl*** packs, fuel Sender.. A few other odds and ends. I picked up a 10ft stick of stainless 2 inch exhaust . It only took a few mins to have some wire templates made of what I needed. Our local auto parts store bends exhaust for $2 a bend! So I had 5$ in bending the exhaust. I welded it to the new flanges on the manifolds and installed the steel pack mufflers. It looks great. The pipes after the mufflers are just sitting in place. I haven't decided what to do with them yet.
    So I moved onto the steering. I shortened the drag link to fit the car, welded the steering hoop gusset in and called it a day.
    Sounds soooo healthy! And I have steering! Finally
  9. hotrodderhaag
    hotrodderhaag
    I received my adjustable 240/33 ohm Stewart Warner fuel sending unit yesterday. Fully adjustable for a 10-14" deep tank.
    So knowing my side view of the tank. I use that view in auto cad and began laying out the fuel sender and the float rod inside that view. Stewart Warner sends you a list of dimensions depending on the depth of your tank, but since my tank is odd ball shaped, I had to play around to make it fit jus right, t******* the float rod also. I like the fact when it says "empty" there will be about 2 gallons of gas in reserve.. It may be needed! After that was done I made a bung for the tank that the sender could attach to. I drilled and tapped it 10/32 and it will be welded to the top of the tank. I accounted for the material thickness of this bung when I set up my sender. So it should work like it was made for the tank.
  10. ss34coupe
    ss34coupe
    Your nice work continues, with good attention to detail. This will be a great hot rod!
  11. Mart
    Mart
    Good work, good progress. It's handy having a shop that can bend the exhaust tubing like that. I've used autocad lite a few times for laying stuff out like that. This build reminds me of the gl*** 34 I built a few years ago.
    Mart.
  12. hotrodderhaag
    hotrodderhaag
    Today wasn't very productive on the account of blowing a tire on my DD going 75 on the interstate with no spare!
    I test fit the sending unit and it's good to go. It needs tig welded yet
    I bought some stainless exhaust clamps to hang the exhaust.. I didn't weld the pipes after the mufflers because I have no idea what I wanna do, opinions? Should I put turn downs? Leave em straight? Or have tail pipes made?
    Andy kohlers 34 had nice exhaust that the new owner installed
    This was the look I wanted..... Notice the bumper/chin guard!!
    Anyways tomorrow is another day. I'm ready to start the brake system.. I will be using the factory 34 pedals and copying Andy kohlers master cylinder.... Seems like this guy knows how to build a car.
    I'll be driving this thing before you know it
  13. alpo
    alpo
  14. joemac05
    joemac05
    That is the part that pains me about it not being there, the grill is not protected. But I think it LOOKS better without it... maybe the black would be better than nothing at all. The chrome just looked wrong in the photos at least. In the end it is only what you like not me or the rest of us nitpickers.
  15. 26 T Ford RPU
    26 T Ford RPU
    Love the way you have put this car together, Totally cool package. JW
  16. box50
    box50
    Looking good buddy everybody liked the open drive kit it looks good and I don't see any reason why it won't work thanks a ton for all the help with parts and the trip down to NC and all the hands on work ya'll did.
  17. hotrodderhaag
    hotrodderhaag
  18. daddio211
    daddio211
    Your continual progress continues to amaze me!
  19. Mat Thrasher
    Mat Thrasher
    Looking good Ben. You can bug me anytime to weld that neck up for ya.
    SquintBoy likes this.
  20. travj31
    travj31
    from Western PA
    it's really coming together, gonna be one sweet ride when its finished.
    ive been following this thread since day 1 and i cant remember if you mentioned it before or not and i went back through and looked quickly, but what make is that body? thanks...
  21. chevy54man
    chevy54man
    from NC
    Very sweet car, good for you man! Doing great work on her~!
  22. fordf1trucknut
    fordf1trucknut
  23. texkbc
    texkbc
    Thanks for postng your build, the coupe looks great!
  24. 3banjos
    3banjos
    from NZ
    Ben, have you left the building..
  25. painkiller
    painkiller
  26. MAD 034
    MAD 034
    from Washington
    You are so close -- can we see please?
  27. hotrodderhaag
    hotrodderhaag
    guys,
    its been a while.. several weeks ago my best friend/co worker was killed in an ATV accident on the Hatfeild-Mccoy trails in West Virginia... so its been pretty hectic. between dealing with the loss, and trying to get work straightened back out to function with out him, it has been a chore and a half... but life goes on.
    also my CELL decided to **** the bed so i haven't had one of those in a while....
    I have also shut my shop doors to any outsiders... I now do NOT work on any projects other than my own.
    This was decided after i was hounded even through a very rough viewing and funeral service. I've done a lot of fab work for pennies on the dollar for a few guys, even took some not so nice parts on trade for work, and they still feel fab work is dirt cheap.... and its NOT. If they were to find out what a real metal shop would charge... they would be broke....not to mention the fact they could call me anytime and what they needed would be done... done exactly how they wanted..
    anyways, not to vent too much,.. i may be moving to a warmer place. hopefully...
    When life gets back to normal, and i have time to mess with it, i will post some progress. the 34 has not changed much other than get dusty.
    thanks a lot guys, glad i still have your interest!!
  28. 26 T Ford RPU
    26 T Ford RPU
    Sorry to hear the loss of your friend Ben. JW
  29. box50
    box50
    I hear ya dude hope the move to a warmer place like NC I know you need to have a job before you move so hope it works out dude. See yall soon.
  30. Man that really ****s. I know in a very small way what you must be going thru. The only thing I can say is,it's true that "time will heal all wounds". Hang in there pal. I spent many a time alone and sobbing. I guess that is part of the healing process. God Bless!
