Well I finally got the 37 ford fodor home. Now I needing some help. It looks like the brake switch is a 31 for a model a. It is not working. Is this the correct switch, or does it look different. Are the wiring harnesses available? This one seems to have a short inside the switch bail, will have to look inside. Also how do you get the rear tail light lens off? Also, how does one remove the front headligh bulbs? Need to check them, to see if they are any good. It looks like they twist, but want to be sure before attempting. It only has one horn under the front, should have two I believe. Missing the one on the p***enger's side. It started up and runs pretty good. Well need to rebuild the carb. I believe it is a Stromberg 97. Any helpcomments and such would be greatly appreciated. Jon in Ill.
