Projects Finally I get my Flathead powered T Roadster
Discussion in 'Traditional Hot Rods' started by mctim64, Dec 4, 2014.
  1. bone31
    bone31
    the lower shaft made from 4140 heat treated steel, turned between centers the only way. DSCF0003.JPG the
    mctim64 likes this.
  2. bone31
    bone31
    chryslerfan55 and mctim64 like this.
  3. Jethro
    Jethro
    I was wondering how you were going to solve that....easy peasy!
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
    Bone31, as a retired aircraft tool & die maker and A&P mechanic I love your work. I really miss having all the machines of a shop to build stuff with. Now I'm building with a drill press and belt sander, but it's fun seeing how you are doing this quick change.
    mctim64 and volvobrynk like this.
  5. bone31
    bone31
    Tom I am lucky I have had my shop at home 18 yrs. made a living here for 15 yrs.In the shop 7 days a week never get enough.
    mctim64 likes this.
  6. bone31
    bone31
    Jethro glad you like it starting to get good.
  7. bone31
    bone31
    IMG_1078-001.JPG this is my dividing head made in 1933, any division of a circle can be made, or a movement of lets say 7 degrees and 21 mins.as there are 60 mins. in one degree.Also this is the way you cut gears will cut any number of teeth, the lower left shaft was hooked to a drive now we can cut helical gears. IMG_1076.JPG IMG_1077-001.JPG
  8. bone31
    bone31
    there are a set of plates with hole patterns,we are cutting six splines it takes 40 turns to make one chuck rev.I an using a 42 hole circle 6 turns plus 28 holes make cut repeat. IMG_1085.JPG
  9. bone31
    bone31
    ruff out spline with 3/16 carbide cutter full depth,next I made a solid carbide four side cutter I make most all my cutters, that is a job done on the surface grinder. IMG_1080.JPG IMG_1083-001.JPG IMG_1080.JPG IMG_1082-002.JPG
  10. thunderbirdesq
    thunderbirdesq
    Damn, Mike! So cool!!
    And congrats Tim on the T!
    mctim64 likes this.
  11. Mock up with engine in place, stance looks good. Frame is coming together.
    Doing excellent work on that QC Mike. Love it!
    chryslerfan55, bct, bambbrose and 2 others like this.
  12. Blue One
    Blue One
    from Alberta
  13. bone31
    bone31
    the bearing is a .001 press fit on the drive shaft end,grinding the bearing retainer. IMG_1105.JPG IMG_1111-001.JPG
  14. bone31
    bone31
    the bearing is up .001 so the retainer plate holds the outside race from turning, the torque tube also covers the plate trapping everything .The transfer of the bluing confirms the fit. IMG_1109.JPG IMG_1107-001.JPG IMG_1108-001.JPG
  15. bone31
    bone31
    the bearing holder fits in a pocket,all the fits are .001 or less. IMG_1099.JPG IMG_1097.JPG IMG_1098.JPG
  16. bone31
    bone31
    the bearing is. up .001 the top cover holds everything tight IMG_1102-001.JPG IMG_1100.JPG
    chryslerfan55, kiwijeff and mctim64 like this.
  17. bone31
    bone31
    the shaft goes in from the drive shaft end, the bearing fit on the qc end is .0005 half thou.shown is the gear spacer and gears.everything is safety wired.Bolts are under a lot of stretch the problem is they may not come loose with loctight or lock washers or lock nuts but if they break they will cause a lot of damage flying around. The little tabs that bend up against the bolt hex can only bend one time if you use them again you know what happens.They still do not contain the bolt head, so safety wire is another thing we learned from old Henry. IMG_1116.JPG IMG_1114.JPG
  18. bone31
    bone31
  19. bone31
    bone31
    things did not work good today on the one eye monster. Started the rear bearing plate today.
  20. s55mercury66
    s55mercury66
    from SW Wyoming
    Just curious, is that a Monarch I see?
  21. bone31
    bone31
    LeBlond 1956
  22. hugh m
    hugh m
    from ct.
    Thanks for giving up all this specialized knowledge, always wondered how it was done. If I buy some tools all I need now is a six year apprentiship.
  23. Moving right along. Derrek has my frame together and I will be taking the rear end to his shop this Sat. to measure the tube to cut.
    Also BIG thanks go out to Eric (daddio211) for scoring a much better body for me. I will see him at GNRS next week to pick it up. Very exciting! :)
    1656424_10203724974233257_6145295542150060079_n.jpg 10406648_10203724973633242_6409436256969187066_n.jpg
  24. Blue One
    Blue One
    from Alberta
    That looks great Tim, exciting isn't it. Good that Eric was able to get a line on that body.
    mctim64 and daddio211 like this.
  25. stephane-rod
    stephane-rod
    from france
    Nice project
  26. bone31
    bone31
    starting on the rear housing,parts in welding jig IMG_1124.JPG IMG_1122.JPG IMG_1123.JPG
    Lil'Alb, chryslerfan55 and spasecadet like this.
  27. bone31
    bone31
    will machine this side then flip over in the jig and weld the other side. IMG_1127.JPG w
  28. -Brent-
    -Brent-
    @bone31, I've always admired your work, even more so now with the updates you show. I would love love love to have one of these under my 26 Roadster, in the future.
  29. pitman
    pitman
    Great guide in building this QC rear!
  30. lowtruck
    lowtruck
    from Omaha
    That stance is PERFECT. This one is shaping up to be a killer little car.
