Technical finally joined....now for a brake question
Discussion in 'The Hokey Ass Message Board' started by shtboxyj, Sep 8, 2017.
  1. shtboxyj
    shtboxyj
    used the site for research but finally joined today. I have a 1966 Pontiac catalina. original brake master cylinder was a single line output. I recently changed to a dual outlet master. car is power brakes and drum/drum. swapped in a master from a 67 catalina with power brakes drum/drum. (a1cardone 1-1328 1" bore). normal stopping brakes fine, panic stop the pedal hard and will not lock wheels(maybe a slight chirp from rear). any ideas? normally I would switch to a smaller bore but its already 1". im positive there is no air in the system, or leaks. bad reman?
  2. Are the shoes and drums new too?
  3. shtboxyj
    shtboxyj
    not new but lots or material. drums are within spec and shoe contact is consistent across the friction material. and properly adjusted. it stopped great before. that's why i'm thinking just a bad remanufacture.
    clunker likes this.
  4. shtboxyj
    shtboxyj
    original master was a 1" bore and new master is also 1" bore.
  5. Budget36
    Budget36
    Same thing happened with an OT car I had, at the time a kit for the MC was $32.00 and a rebuilt MC was $28.00...heck, couldn't beat the idea of buying one ready to run...wound up taking the MC back, got a kit for my old one, worked fine.
    Ever since then,anytime I buy a new or rebuilt MC's and WC's, I take them apart and clean them out...a few have had shavings and debris in them...overseas QC I guess...
  6. manyolcars
    manyolcars
    1966 off topic car
    This forum gets so many brake questions that we need a separate sub-forum for brakes
    X38 likes this.
  7. Hmmm. I did the same thing to my Cad. But I changed out the shoes and drums at the same time, and it did the same thing. Pretty quickly after driving a bit, the shoes seated and it went back to normal. But yours sounds like it's definately the MC. Interesting.
  8. Blues4U
    Blues4U
    from So Cal
    Sounds to me like the problem is in the power unit. How much vacuum?
    clunker likes this.
  9. shtboxyj
    shtboxyj
    agreed, there is not a lot of options for discussion sections. but clunker I was thinking the same. gonna try to find a new one instead of a reman. :blues4u holds vacuum.
