1952-59 Ford Finally some progress
Discussion in 'Off Topic Hot Rods & Customs' started by the-stig, Jun 17, 2011.
  1. the-stig
    the-stig
    I've been working to install a 302/5 speed in my 56 for what seems like forever.
    I first filled some holes and painted the firewall and fender wells.
    The previous owner installed a wiper off a newer car, not sure what it's from but it ugly and it works.
    The brake master cylinder is from CPP with built in proportioning valve, $200.
    I then installed a hydraulic throwout bearing on the trans. This is the kit I used. It's a RAM Automotive unit I got from Summit for $200.
    Added a brake booster. I made the booster bracket and had it chromed at a local shop.
    And the clutch master cylinder.
    Now I need to get a hose made from the master cylinder to the throwout bearing, test the bearing for leaks and install the engine & trans and clean up the wiring.
    My son just got a 64 Cadillac and he's been having me help him with it also.
  2. flyboy89
    flyboy89
    from So. Cal.
    Looks good, keep going!
  3. dragonknucks
    dragonknucks
    I like the smoothness of it all. Keep up the good work.
  4. old lady's mad
    old lady's mad
    never seen an master cyl like that before. i need to clean up my engine bay , one day.
  5. fordsbyjay
    fordsbyjay
    from Lafayette
  6. Ole don
    Ole don
    Very nice work. I had a 302 in a 54, I used early Mustang tri Y headers. They were a huge improvment. They did need some welding on the very bottom, so if you dont weld at home, its not a good idea.
  7. shadyg
    shadyg
    from S.Georgia
    Looking good. I like a clean look undeer the hood. Have any of you ever tried using a Geo Metro booster and cyl. I am running one on my 56 Mainline with original drums. It works real nice. I used the same setup on a 64 Falcon with 74 Mustang II front end several years ago.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    I posted info on the Geo Metro swap several years ago before the kits became available for our Fords,if you are on a budget check it out: www.fordfalcon2000.com click on "restoration"a lot of what applys to the Falcon works on our early Fords,the tilt column article is interesting.
