Projects Finally starting on my 32 Chev...
Discussion in 'The Hokey Ass Message Board' started by Deuce Chev, Apr 24, 2010.
  1. looks like you started off with a nice ride and get to make it better - that engine looks sweet - good luck with the rest of it - cant wait to see/hear the videos !!!
  2. Deuce Chev
    Deuce Chev
    from Pacific NW
    getting the test stand put together, mounting is a little strange since the motor mounts are strangely offset, the factory mounts are being used now but I will more than likely have to fabricate my own mounts when the time comes to put it in the ch***is. so this brings up a question, do I use the factory location of the mounts? or modify this old Hurst SBC motor mount and mount the engine from the front?
  3. Deuce Chev
    Deuce Chev
    from Pacific NW
    test stand partially done...
  4. Paul
    Paul
    Editor
    looks good Jim
    either mount location should work fine
  5. Deuce Chev
    Deuce Chev
    from Pacific NW
    Thanks Paul. Your brother came by last night and was admiring "The Crosley"...
  6. 29woodie
    29woodie
    from boston, ma
    Looks great. I'm curious how you will mount the engine. If you use that Hurst rear mount, what will you use for a front mount? I've seen front mounts for Chevy 250's for the marine crowd, but they look a bit bulky.
  7. Deuce Chev
    Deuce Chev
    from Pacific NW
    I am not positive but I think that Hurst mount is a front mount for a small block Chevy, I'll either modify that to work on the front or I'll build some custom motor mounts that use the location of the factory mounts.
  8. Deuce Chev
    Deuce Chev
    from Pacific NW
    a little more progress on the engine stand, front motor mounts figured out and installed!
  9. Looking good!
  10. chopper526
    chopper526
    from Phila., PA
    Any updates????????????
  11. Deuce Chev
    Deuce Chev
    from Pacific NW
    Every so often i get a burst of motivation, finally got the fenders pulled off, I am liking the "no fenders" look so they more than likely will be sold off to help with the rest of the project. Looks like I'll be doing a channel job here too, that's all foreign territory to me so I will be asking some advice on that.
      85.4 KB
      91.9 KB
      107.3 KB
  12. larry woods
    larry woods
    from venice fl
    If you're going with the fenderless channeled look, you may want to check out car in my album. good luck with the build.
  13. Deuce Chev
    Deuce Chev
    from Pacific NW
    Thanks Larry. is that the stock 32 axle in front on yours?
