1952-59 Ford Finding weird little trim fasteners
Discussion in 'Off Topic Hot Rods & Customs' started by Roothawg, May 8, 2020.
  1. Roothawg
    Roothawg
    I am looking for the little pieces that hold the trim on around the garnish moldings. I pulled them off to blast the paint. The previous owner didn’t want to mess with it. I do. That kinda ****s eats me up. Leaving the original finish under the trim is not my style.
    I know why he probably did though.
    8A8C2744-5F91-43ED-85DD-3FC27386E251.jpeg A47D6CA6-F2C3-43C1-ACBC-BED8E9F6AECA.jpeg 380F29C5-84F6-4D0E-A529-E66085006997.jpeg
  2. Dave Covey
    Dave Covey
    I'm looking for them too..
    Dave
  3. Roothawg
    Roothawg
    Worst case is I can make something and use small screws from the backside.
  4. 56longroof
    56longroof
    Restoration Specialties may have them.
    customline3859 and bobss396 like this.
  5. Ron53Sunliner
    Ron53Sunliner
    I misplaced a couple so I made some. The dash has the same trim but used different fasteners. I ground small flathead screws to fit which need to be slid in rather than push and turn like those. I used a dremel.
  6. bobss396
    bobss396
    Yes, try them for sure. They had it all for my '59. Be aware that some of these clips have been sold out. Give them your car info and they should have all the clip part numbers on file.
  7. Roothawg
    Roothawg
    That would be nice. One the dash the PO used a small spring clip. If I can find those I may go that way, if they aren't available.
    bobss396 likes this.
  8. bobss396
    bobss396
    I talked to Jeff over there. He had a list of everything for my car, so he probably has one for yours. Another place is Avueco Fasteners. Their online catalog is like 700 pages, happy hunting! The Restoration Specialties online catalog used to be tough to sift through. I may have a hard copy of one....
  9. danman55
    danman55
    about a year and a half ago I went through the exact same scenario with my 55 Fairlane - your trim on the garnish is peculiar to the 55 Fairlane Sedans when it comes to those clips and being attached to the sheet metal garnish. There is a larger version of the same style clip that holds your plates for the headliner (just above the doors) and also your "J" dogleg brackets for your kickpanels. I had to get two guys who had parts cars to scrounge a few for me. Back then I did contact Restoration Specialties and they did not have them, but it's worth a shot to check since it has been awhile. I do not have any extra or I would send them to you, I know they are HARD to find. As a matter of fact, I ended up not having enough for both sides, so I went without one clip at an interval where I was convinced the trim was ok.
  10. Roothawg
    Roothawg
    I am keeping the ones that are salvageable. Some are beyond saving...
  11. 56longroof
    56longroof
    I know a guy that may have some also. PM me and I'll forward his contact info.
    Roothawg likes this.
  12. Roothawg
    Roothawg
    Thanks. So, not to be dumb but how were these designed to go in? Press in after installed in the trim or what?
  13. Ron53Sunliner
    Ron53Sunliner
    if you think of the trim profile as a "C", the little horns on the fastener catch the ends of the "C" when you twist the fastener while pushing the trim against the sheet metal.
  14. danman55
    danman55
  15. Roothawg
    Roothawg
    I have used your website a lot in this build. I am stripping, painting, polishing etc. on the removable parts.
    danman55 likes this.
