finished tacking up my 4link nd bags to my shoebox
Discussion in 'The Hokey Ass Message Board' started by bungle, May 9, 2010.
  1. bungle
    bungle
    from el paso tx
    i left the rear with the 3" blocks on it, then i mocked up the 4link off of that. i'll use that as my normal drive height. i didn't want to slam it, so it will just go down to the bump stops.
    i'll take the blocks off another day, remove the leaf springs and see if everything works out, then i'll finish welding stuff in place. then on to the front...much respect to you car guys, i made a motorcycle a year ago and decided i wanted to try my hand at a car. wow! much harder, but still fun as hell. it takes an hour just to get to the part you wanna start working on! oh well, if i could work all day i would but life and a day job..you know.
  2. Stefan T
    Stefan T
    from Sweden
    Are you not afraid to have problems with the angel down on the upper bars on the rearaxle hausing.
    It's better to have them not angled so they aline with the front end.
    With your set up when the rearaxle is moving it will rotate the bars
    /Stefan
  3. bungle
    bungle
    from el paso tx
    i think the angle of the frame in the pics makes them look like they are angled down, but they are at 0deg. i moved the car up and down and everything seems to function...we'll see when i take the leafs off.
  4. Stefan T
    Stefan T
    from Sweden
    I mean this that the bar must parlell in the ends like this pic
    /Stefan
  5. ford51
    ford51
    from sweden
    Torsion function!
  6. 59mercsled
    59mercsled
    You should notch the frame man. You will regret it later if you dont do it now. Its never low enough. You are always want to go down.
  7. dante81_98
    dante81_98
    1. A-D Truckers
    What he said. I have seen so many people not put the notch in then have to go back and redo it later.
    Looks good though. I can't wait to do mine.
  8. Albie
    Albie
    Third that. From the pics its hard to tell, but you want the instant center around, or slightly below the front bumper. Good luck.
  9. Hooligan63
    Hooligan63
    Basically what he is saying,is the end bungs should be horizontally flat. Basically they should be level.
  10. goshawks00
    goshawks00
    from Saline, Mi
    Maybe dumb question, if he doesn't tighten the nuts on the 4-link bars won't the screw and un screw themselves enough to compensate for torsional twist?
  11. bungle
    bungle
    from el paso tx
    ahh, i see what you guys mean by having the bungs being parallel. that makes sense, i bet the bushings will wear out a lot faster the way i have it now. I have moved it up and down, and didn't see any wierd movement in the bar, or binding, but again, it does make sense what you are saying. i'll probably fix that. i'll just alter the mounts on the ax so it levels off.
    as for the notch, i'll look at it when i get the leafs off and see what it looks like. i'm thinking skirts might give it a lower appearence without notching it.
    oh well, can't do anything today, it's mothers day so...yhea, i better not.
  12. Da Tinman
    Da Tinman
    yes for a time, then it galls the threads and failure becomes emminent.
  13. Diavolo
    Diavolo
    Uhm, unless one side is reverse thread I really don't think it will unscrew. The threads are for adjustment, and I think that means taking the end of the link out of the bracket and unscrewing it, then sticking it back in the bracket. Still, one should tighten any loose nut... just saying.
  14. Stefan T
    Stefan T
    from Sweden
    Thats big problem you were out the treads and you have a failure
  15. fksmog
    fksmog
    from so cal
    aside from what other have said, when you take the leafs off jack up the rear end so that the axel is on the bump stops or the frame where ever you want the lowest position to be, then with the bags fully compressed mount the upper bag mounts
  16. scottybaccus
    scottybaccus
    Put heim ends on one end of your upper links and you will solve your problem. Otherwise, nicely done. It doesn't require overkill to do a good job.
  17. bungle
    bungle
    from el paso tx
    this is why i love the hamb. i'm learning as i go, and don't really have anyone to help me out other than the internet.
    thanks for all the good info. i definately want to do it right.
  18. hombres ruin
    hombres ruin
    Go for the notch before its to late,it happened to me.There is never a concept of to low.Once bitten by that bug your hooked.
  19. bungle
    bungle
    from el paso tx
    damn, you might be right about that. i'll have to sleep on it.
  20. HotRod31
    HotRod31
    Scottys right, use heim ends on one end. I use them with mis-alignment spacers.
    Later, Mark
