Finishing Aluminium
Discussion in 'The Hokey Ass Message Board' started by What, Sep 26, 2006.
  1. What
    What
    I'm looking for intresting/different finish for a dash I'm building. I don't have a mill so that is out. Has anyone got any ideas? I was thinking maybe a wire wheel or something along those lines. I'm Listening.
  2. tred
    tred
    motor turned finish from your drill press.
  3. What
    What
    Enlighten me, what is a motor turned finish?
  4. Thirdyfivepickup
    Thirdyfivepickup
  5. This was done with a drill press and scotch brite pads on a dowel.
  6. bobw
    bobw
    I've used a random orbital sander (DA) with 120 freecut paper and created a matte finish, which I then sprayed with clear lacquer. Try it on a piece of scrap and see what you think.
  7. What
    What
    Thats a sweet look hiboy, how did you attach the scotchbrite pad to the dowell?
  8. Gorilla glue.. trim off excess scotch bright.. Make up some in advance so you don't have to wait for the glue to dry
  9. lolife
    lolife
    Diamond Plate baby!
    Just kidding....
  10. scootermcrad
    scootermcrad
    Bead blasted finish looks kind of cool. Plain and simple looking. Almost looks cast depending on the type of media used.
  11. boozoo
    boozoo
    I used something similar. I found an old valve the right size for the swirls, then glued a leather scrap to the face and kept it coated with valve lapping compound. You can kind of sort of see the results in the background of this one:
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    That's engine turned. Also heard it called jeweling.
  13. scootermcrad
    scootermcrad
    Also demascening is another name as well. OLD practice! Been around for a long time and done lots of different ways and in many styles.
