Customs finishing off my pre-war cheveee project
Discussion in 'The Hokey Ass Message Board' started by nunattax, Aug 31, 2015.
Tags:
  1. nunattax
    nunattax
    ordered the parts to overhaul the steering wont see them til sept.moved on to the front brakes one side nearly re***embled
    TFoch and tb33anda3rd like this.
  2. nunattax
    nunattax
    steering parts are in some limbo.fedex are looking for more information because do***entation is missing.what a set - up.gives the customs more time to make up charges.no volatile materials,just a steering joint get a grip i blame the dope trump for all of this.
  3. nunattax
    nunattax
    front brakes finished off with some help from andrew. pedal feels firm.still waiting on steering parts.due on tue but time will tell.
    TFoch likes this.
  4. nunattax
    nunattax
    parts due on tuesday and arrived on thursday.glad to have them now got to find the time
    TFoch likes this.
  5. nunattax
    nunattax
    been moving forward rebuilding the steering.new bearing in but discovered i also need a spacer.we have come to a stop until i get the spacer knocked up.hopefully this week.also improved things by using a captive nut.took a while to sort it out but now its done glad we went to the trouble
    tb33anda3rd likes this.
  6. nunattax
    nunattax
    spacer made top of the range job ,by mick thanx bud
    tb33anda3rd and JohnLewis like this.
  7. nunattax
    nunattax
    spacer painted spacer fitted,grub screw added .***embled with copper ease,should it need to come apart in the future..***embly wouldnt go back together with the new parts .need to shorten 1 shaft by 3/16 either end for a little breathing room.hopefully it will re***emble the next evening.thanx to andy for ***istance and encouragment .went for beers
  8. nunattax
    nunattax
    the good news is the steering is ***embled.its the best it has been everything painted with new steering joints. everything loc***ed tightened and operating smoothly.glad that one is over.thanx to andy for keeping me laughing and the ***istance.good job!!!.holley jet tool ordered,could have that in a week or so .
  9. Very nice,worth it going with better quality!
    nunattax likes this.
  10. nunattax
    nunattax
    holley jet tool arrived early ordered monday arrived thur well done ups..unfortunatly proforms version of holleys tool is a piece of ****. a poor quality piece of ****.**** it
  11. tb33anda3rd
    tb33anda3rd
    bummer
  12. nunattax
    nunattax
    because the cost of importing everything inc tax and shipping is so high im thinking of making a version of this based on a small 1/4" drive socket.[​IMG]
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    I probably shouldn't say anything But I've never used anything on a Holley jet other than an appropriate sized screwdriver ? Never found the need for a specialized tool ?
  14. bubba55
    bubba55
    Chris I can’t imagine how frustrating it is for all y’all that live over the pond in dealing with the cost - time of this hobby of ours - y’all are truly dedicated to this hobby and my hat’s off to ya !
  15. nunattax
    nunattax
    thats the way it is .the most frustating thing for me is parts that are advertised to do a job and when i get them they dont do it or need to b modified hows things with you bubba ?
  16. bubba55
    bubba55
    Woke up today - so off on a great day - tinkered on the A today - flushed out the radiator and hooked up the heater hoses to the heater - turned it on when the engine was warm - no heat - called Vintage Air and got a list of checks to do - found temperature speed pot not working thus no signal to heater control valve to open - they are sending me a new switch - should be here sometime next week
    Ya take care ya Irish Nut
  17. nunattax
    nunattax
    downsized the primary jets from 70 to 69.still rich down to 67..this carb has allways ran rich. from new.fired it up black smoke from the exhaust is gone but still not perfect.thinking this could be a E10/15/20 ISSUE..idleing well and responds to throttle well.needs a good spin to check out plug colour.,but the rear brake is leaking allover,**** it
  18. nunattax
    nunattax
    added rad flush to the rad .discovered the bottom rad hose is leaking..at 16e a go fired her up went through a heat cycle and drained her out.didnt look too bad.so at the moment my mission is to fix bottom rad leak and lean out the mixture an other bit.got one size smaller primary jets to try worth a try.nothing ventured nothing gained
  19. nunattax
    nunattax
    when i stepped the fan shroud back from the rad (15 mm )it was difficult to place the hose clamp correctly and tighten.i clearance the bottom of the shroud.unfortunatly this weakened the shroud so i strengthened it up again with a curved reinforcment JB welded and located with some screws. upload_2025-11-19_12-51-24.jpeg
    72yenkonova and tb33anda3rd like this.
  20. nunattax
    nunattax
    upload_2025-11-19_12-55-54.jpeg .etch primed and painted black they will never know
  21. nunattax
    nunattax
    ive been using locknuts to hold the fan to the shroud.but its a real tight fit mounting it .so ive decided to use captive nuts so i can mount the shroud and add the fan to it later.the captive nuts are pieces of 30x 8 aluminum tapped shaped and stuck to the shroud with jb weld.its slow setting so its inside waiting to set.ive bought m6 rivnuts which i may use depending on how they would work out length wise.
  22. nunattax
    nunattax
    the jb weld seems to have stuck fast.painted the new pieces of aluminum.andy arrived.well we offered it up .it didnt want to fit with the fan attached .removed the fan and bolted in the shroud with a few screws.tried the fan seperate.it flew in this time bolted that home.delighted with the changes ive made.spent a couple of days at this lot.the bottom hose clip is easy to access.and the fan comes in and out easy.happy as larry.
  23. nunattax
    nunattax
    38Chevy454 likes this.
