Technical Finned Buick Brake Drum Balancing
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Sep 17, 2022.
  1. Speed Gems
    Speed Gems
    My dad has an original set of finned Buick brake drums on his model T but always complains about the handling when he drives it to a show. Does anybody know who can still balance these drums?
  2. NoelC
    NoelC
    I'm not going to say they need it, but most machine shops should be able to balance them out.
  3. Why does he think out of balance drums are causing handling problems? Seems unlikely to me
  4. Speed Gems
    Speed Gems
    Not so much handling but the ride.
  5. dana barlow
    dana barlow
    from Miami Fla.
    He/you can check balance,just by jack up wheels off the ground, back off shoe adjuster an, spin wheel,let it stop on its own,and mark the top near the tread. Spin it a few times,to see if it stops about the same place all the time. If it dose,add a rim Wt./tire Wt.. Put mark at 90* from top;see if it go up or down? If it goes down=you added too much,if up;not enough.
    One of the most done mistakes with Buick Drums added to anything; Is using a tire rim on them that has too much out set!= Big scrub, :(that makes messed up handling{ some do it,to show off the Buick Fins:( and have no understanding of scrub and what high scrub dose to both braking an bumps road.;)
    60 Special, lurker mick and BJR like this.
  6. krylon32
    krylon32
    from Nebraska
    Does he still have the factory balance weights bolted on the drums? A common F--K up is removing these weights.
    Speed Gems and flynbrian48 like this.
  7. Andy
    Andy
    I had a thread about balancing them. I made a insert that centered on the inner bearing and had a point to fit to a stand. I used a bubble level on the end of the hub.
    dana barlow likes this.
  8. flynbrian48
    flynbrian48
    That's sometimes necessary, to a degree, because many 15" rims won't clear the fins. I had to run 1" thick spacers (wheel adaptors, as my hubs are small Ford bolt pattern) to have the Dayton 15" wires fit. The offset isn't ridiculous, and it drives and handles great. I've seen some cars that have the entire drum exposed. I have a set of 15" Ansen slotted chromes that likewise don't fit. 16's, no issue, but Buick 15" rims are specific to those cars that had the big finned drums, Chevy and Ford 15's will not clear.
    As mentioned, DO NOT remove the factory balance weights. They're there for a reason. CA0195BB-C741-4001-AEA6-03B000492643.jpeg
