Finned Valve Covers & Spark Plug Wires
Discussion in 'The Hokey Ass Message Board' started by 1959apache, Oct 1, 2011.
  1. 1959apache
    1959apache
    I was wondering if other Hambers can post some pictures of their finned valve covers, spark plug wire separators, and what year/model of spark plug wires are a good purchase at an auto parts store for a 350 chevy engine. Where are you getting your plug wire separators? Are you cutting your own plug wires? Are you going with angled spark plug wires?
    I am going to be firing this truck back up after the small $400 bling makeover and need some help, so post what you have please! :D
  2. thepoz57
    thepoz57
    1964 vette wires are a little longer and can tuck underneath/behind your headers. There are small bolt holes on the side of your block that you can make a small tab to hold the front two wires(#1,3, driver side and 2,4 on p***. side) up against the block and away from your headers. It will clean up the engine area by having the wires out of the way.
    POZ
  3. thepoz57
    thepoz57
    The engine size for the wires is the 327 for the parts guy. A simple piece of strapping tape bent into a U shape with the edges rounded will do the trick.
    POZ
  4. D-man313
    D-man313
    I just used universal plug wires and small zip ties to keep the wires separate.
    The way i ran my plug wires and used the zip ties keep the wires off the headers. Im using angled plug caps to.
  5. GassersGarage
    GassersGarage
    Got these from Cal Customs...........
  6. Flingdingo
    Flingdingo
    I always buy the cut-to-fit wire sets from Summit or whoever. Seems like every pre-made wire set I've ever installed has at least one that has to be wrapped around the carb three times so it's short enough to fit, and one that needs to be stretched a few inches so it's long enough.
  7. slammed
    slammed
    Take the time to route them behind. Black so they disappear.
  8. spoons
    spoons
    from ohio
    I make my own..
  9. indyjps
    indyjps
    edited post, removed my douchebag comments
  10. cruzr
    cruzr
    I dont care for wires crawling all over the place, its easy to "tuck' them away
  11. 1959apache
    1959apache
    Listen dude, next time keep that **** to yourself. Perhaps you should read the build thread that I am doing before you go on your "rant." The point is that I am going to be pulling the engine to make it look nice, but not before working all of the leaks/bugs out first.
    Please explain to me how it is bright to paint a cylinder head (the block and other head are painted... you would know this if you viewed the thread...) then remove an electrical temp sender spilling coolant and another plug, spilling even more coolant, and probably have oil leaking from the new valve covers that are untested all over that nice paint job that I took a couple hours out of my day doing??? The moral of the story is to please ****yze your post before replying to peoples questions to avoid looking like a complete dip****, especially when you're chastising someone's work.
    To everyone else, including most of indyjps information: Thank you so much for the pictures and other related information; It has really given me a couple good ideas. If anyone has any other pictures, I would greatly appreciate it.
  12. Kripfink
    Kripfink
    Before you commit to anything, go here;
    http://www.jalopyjournal.com/forum/showthread.php?t=614746
    and check out the electrical section of the website, which carries more variety and possible problem solving, not to mention traditional looking stuff than you can shake a stick at. On the 351W pictured above we made up our own leads. We used cut to length clear wires, Raja terminals which have very little to melt, a set of rubber distributor boots and a "power master" retro hot Rod alternator. To keep the wires out of the way of the headers we just used some carefully shaped welding wire attached under the valve cover screws to lift them safely away from the heat. We got excellent service, a well-dressed engine and a hamb Alliance discount.
    Hope this helps.
    Good luck
    Paul
  13. hrm2k
    hrm2k
    Here is mine. I run my wires behind and underneath. Clark Bates showed me how to do wire tie separators. I do them with black and white wire ties. The main hoop is black and thick. The in between wire ties are thin white ones. I have had several compliments on the wire separators.
  14. yekoms
    yekoms
    D-Man313, What are your headers? Brand and application?
    Thanks,Smokey
  15. derpr
    derpr
    I like tayor wires and zip ties.
  16. 1959apache
    1959apache
    does anyone have a set of block huggers that they are running their plug wires through?
  17. mj40's
    mj40's
    I went with the simple wire clamps with the cloth looking wires.
  18. chaddilac
    chaddilac
    Beautiful!!!!
  19. apache matt
    apache matt
    Here is mine, $30 dollar wire seperators of ebay and taylor wires , ill try and get a better pic of the engine now with the finned valve covers. this the only pic i have at the moment.
  20. Great engine shot mj40s! That is a pinicale of art! I love the detail of color and polished aluminum and the cloth wires are the icing on the the cake, job well done!
  21. lawman
    lawman
    Heres mine.
  22. mj40's
    mj40's
    Thanks everyone. I want a old custom look for my first nailhead. I'm not using the air cleaner in the photo but don't know what to go with yet. Suggestions?
  23. brigrat
    brigrat
    from Wa.St.
    Maybe a finned Moon air cleaner cover...................
    What's the color code on that Gold?
  24. Separators are from Made For You products,,,nice parts.
  25. indyjps
    indyjps
  26. Work of Art!
    Suitable for framing.
  27. mj40's
    mj40's
    I have thought about both of those designs. But have looked at these also.
    The engine paint is Eastwoods engine paint in Olds Gold.
  28. D-man313
    D-man313
    The headers are hedman, but not sure on model number. Bought them off craigslist and the guy we bought them off didnt know much about them either. They bolted right on for my s10 frame swap. You can buy a specific s10 v8 swap header but they are a different configuration than the ones i have.
    Found em
    http://www.advanceadapters.com/products/pn-717053/
  29. big creep
    big creep
  30. Hot Rod Chris
    Hot Rod Chris
    What are these covers off of? Got a pic of the other side?
