finned valve covers
Discussion in 'The Hokey Ass Message Board' started by spark, Nov 12, 2009.
  1. <meta http-equiv="Content-Type" content="text/html; ch****t=utf-8"><meta name="ProgId" content="Word.Do***ent"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDO***E%7E1%5CGayle%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDo***ent> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:EN-AU;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Just got these ford valve covers haven&#8217;t seen these before- desirable?
  2. adamabomb76
    adamabomb76
    from York, Pa
    I'd say they are chromed aluminum, and I've seen them before, but not w/chrome on them. The chrome job is shotty at best.
  3. yes I plan to get the chrome taken off, go for a cast look with paint in between the finns. Didn't cost a lot but apart from the chrome they are in good condition.
  4. 63Compact
    63Compact
    My mate runs a set, I think they are shallow so no rollers.
  5. yes no rollers, I hope to build a 260 or 289 if I can find one.
  6. tommy
    tommy
    The ones you see with the rectangle in the middle like these were the El Cheapo units usually sold at Pep Boys and other chain stores. The same as the 29.99 chrome dress up kits that are sold everywhere today. Often there was a thin aluminum plate glued into the rectangle as a name plate. Back in the day they were not prized because they were cheap. If you like them?...why not?
  7. Tommy's got an excellent point.
    Install them, run em until you find a pair that speaks to you.
    Installing new and better a ways down the road is always a fun project.
    Goes right along with the old saw that "a hot rod is never done."
