Technical Firestone dirt track tires
Discussion in 'Traditional Hot Rods' started by jtbender, May 4, 2025.
  1. jtbender
    jtbender
    from troy, mi
    Anyone know of a replacement tube for Firestone 8.9-16 dirt track tires? Picked up a nail yesterday and today I learned that the Speedway/Coker part number is discontinued. Even worse the rod with the flat is preventing access to the other three. Need help quick.
    Thanks, Jim
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Did you google 9x16 tire tubes? They show them. Just need to pick the ones that will apply to your needs.
    caprockfabshop likes this.
  3. wheeldog57
    wheeldog57
    Tractor Supply has tubes in stock, good luck
  4. jimmy six
    jimmy six
    Protect the tube with a patch on the inside. I like tubes with metal stems. Millertire.com …
  5. krylon32
    krylon32
    from Nebraska
    My local tire store orders them for me. I tried T S tubes but they had some kind of strange valve stem that wouldn't work? My experience with Coker tubes hasn't been good. Can't you just put a good quality patch on he tube you have?
    Speccie likes this.
  6. 29Sleeper
    29Sleeper
    from SoCal
    Put a patch on it. Bike stores still carry patch kits.
  7. Hitchhiker
    Hitchhiker
    Coker tubes are terrible. Ultra thin garbage.
  8. tim troutman
    tim troutman
    I bought a tube at the local firestone store last summer for a 15 inch tire they had them in stock
  9. hotrodA
    hotrodA
    Patch the tube correctly and roll on.
    OR
    Try to find a 7.50R16 with a TR-15 valve stem. You may need to use the little reducer washer if your wheel hole is 5/8”. That is about as close as you can get. Search online for Michelin, Dunlop, etc.
    The radial tube is better than the universal farm tube. Heavier gauge rubber, better body splices and heavier valve stem base. Also designed for speeds above 20 mph like the farm tubes.
    Also patch plug the penetration from the inside of the tire.
    Water will eventually get compressed into the hole and it may separate down the road.
    Also patch the flat tube and keep it as a spare in the trunk.
    Inflate the tube twice after it’s installed. Lets it stretch out and reduces the chance of a wrinkle.
    From a lifetime in the tire biz. YRMV.
