Projects firewall flip: 1930 Ford Model A with 401 Nailhead
Discussion in 'Traditional Hot Rods' started by Phil Carracho, Dec 11, 2023.
  1. Phil Carracho
    Phil Carracho
    from Atlanta GA
    I got a little distracted from my main project when I traded my 39' Ford for a cool little roadster with a 401 Nailhead. After taking a closer look I identified some issues with the car that needed to be fixed.
    The firewall was far from nice and rubbing against the bellhousing putting a lot of stress on the cowl.
    I had a s**** Brookville firewall on the wall for years that was partially stamped. Time to take it off the wall...
    The firewall feet needed to be extended on both sides:
    Outback, Nominal, bchctybob and 7 others like this.
  2. Oneball
    Oneball
    I think “far from nice” was a bit of an understatement :eek: You need to put the old one on the wall just so you can look at it every now and again and chuckle at it.
  3. Phil Carracho
    Phil Carracho
    from Atlanta GA
    Next step was to make a steering column mount and a throttle pedal linkage through the firewall, the shape of the reversed firewall is perfect for the throttle pedal shaft. 11.jpg 12.jpg 13.jpg 15.jpg
      300.9 KB
    Outback, bchctybob, GordonC and 5 others like this.
  4. Phil Carracho
    Phil Carracho
    from Atlanta GA
    Next challenge was to cut the floor and firewall support brackets. I decided to go with a wood floor plate...
      216.3 KB
      387.2 KB
      402.1 KB
      378.3 KB
      351.1 KB
    Outback, bchctybob, GordonC and 3 others like this.
  5. Phil Carracho
    Phil Carracho
    from Atlanta GA
    Oh, I forgot the part where I spot welded the firewall back with a harbor Freight spot welder that works great 16.jpg 17.jpg
    Nominal, curt e, bchctybob and 5 others like this.
  6. 1biggun
    1biggun
    Interesting . I have 30 PU cab I may but a early Hemi in flipping the fire wall like that might work well as its all butchered now and missing most of it . I had planned on using a wheelbarrow tub I bought new years ago for it .
    Outback and Stan Back like this.
  7. Phil Carracho
    Phil Carracho
    from Atlanta GA
    I think it looks better than a recessed firewall and it is not that complicated, I had to do a couple of pie cuts at the cowl radius. Once it is painted it will look like it rolled from Henry`s ***embly line.
  8. 1biggun
    1biggun
    Looks pretty clean to me . I have like a 3 foot open rectangle hole to its going to need a lot of attention .
    Originally I was going to fit a wheel barrel tub in what's left.
    The cab is painted and I hate to try and get the reminder out as it's going to be fenderless so the area were its spot welded in will show but I could cover it maybe.
    I kind of like what you did here.
    I'll need a new Brookfield fire wall with no holes to do it.
    I'm planning on channeling it over a A frame ( plan this week it changes every few months) so the feet needing attention are no big deal .
    A lot of good food for thought here .
    Good write up and pictures .
    Do you loose a lot of foot room? PU'S are cramped as it is.
    mine is pretty ugly right now.
    Been looking at ideas of how to this better with out some square looking recessed box.
  9. wuga
    wuga
    I did not want to reverse my firewall and I had the same issue as you. I pulled the firewall in just above the bellhousing recess. You can barely tell the difference, but it gave me the needed clearance.
    Warren
  10. flatheadpete
    flatheadpete
    from Burton, MI
    That looks great! So subtle.
  11. 1biggun
    1biggun
    I like that to also very clean . looks like I should look for a spare fire wall this spring at the swap meets .
    On my 28 PU the stuff is so tight hate working on it and swore ill do the 30 with more clearance . of course its completely different set up but I want to be able to run a physically bigger engine if I wish .
  12. Phil Carracho
    Phil Carracho
    from Atlanta GA
    The food room is still good, I`m 6`3" so it is always a challenge to fit me in but it turned out good.
    Outback likes this.
  13. Phil Carracho
    Phil Carracho
    from Atlanta GA
    Outback likes this.
  14. akoutlaw
    akoutlaw
    Phil, do you have any pics of where you did the pie cuts?
  15. Phil Carracho
    Phil Carracho
    from Atlanta GA
    I forgot to take detailed pictures but here is one where you can see the cuts: firewall.JPG
  16. wheeltramp brian
    wheeltramp brian
    It's good man. What kind of transmission do you have going on there with all that linkage?
  17. Nailhead Jason
    Nailhead Jason
    Man the T & F shifter is killer! Ive been looking for one ever since they stopped making them!
  18. Nailhead Jason
    Nailhead Jason
    The Linkage is all part of a shifter that was availble years ago from Hot Rods and Custom Stuff I believe. They called it a T&F shifter (Top and Front) that let you put a GM 4 speed into and early ford and get the shifter in the factory location. Super slick.
    Outback and bchctybob like this.
  19. akoutlaw
    akoutlaw
    Thank you!
  20. Phil Carracho
    Phil Carracho
    from Atlanta GA
    I`m pretty happy with the result!
  21. wheeltramp brian
    wheeltramp brian
    Results! Looks good
    Outback likes this.
