Firewall Gauges ..do you use them
Discussion in 'The Hokey Ass Message Board' started by NITROFC, Jan 30, 2008.
  1. NITROFC
    NITROFC
    Wondering who has gauges mounted to there firewall .. got pics ? ..thanks
  2. SlowandLow63
    SlowandLow63
    from Central NJ
    I've though about them for my '51 Ford. But then again I know I would never use them, they would be there for show. I like the look of them, especially if there is striping around them, but I don't know how worth it they are.
  3. Dreddybear
    Dreddybear
    After seeing live wire, I've been converted. I'm thinking about it for my coupe, as I really like how it looks.
  4. KIRK!
    KIRK!
    I'm putting mine in the trunk and door jams.
  5. Revhead
    Revhead
    from Dallas, TX
    and for bagged cars.. air pressure gauges at the end of each rocker
  6. cuznbrucie
    cuznbrucie
    I have a fuel pressure gauge on my fuel block so I can monitor that from the engine area .......
    CB
  7. Dreddybear
    Dreddybear
    Trans Temp in the floor?:D
  8. SlowandLow63
    SlowandLow63
    from Central NJ
    Tire pressure in the tire!
  9. CLSSY56
    CLSSY56
    Here ya go... and they are CUSTOM :D
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    HA..**** im lucky enough to have gauges on my dash
  11. "Doc" Parsons
    "Doc" Parsons
    I've got a Amp and oil pressure on my firewall, that is how it was done in 1957, the guys with lot's of money had a full set all across the firewall, anyway that's how I remember it lol
    "Doc"
  12. gas pumper
    gas pumper
    I got a water temp and oil press on my 54. I think it looks good, i seem to spend a lot of time with the hood up with the car running before I leave for a ride. and this year, with trying to cool it between runs it helped to watch the temp while standing around.
    Frank
  13. KomptonKid
    KomptonKid
    I had a buddy once who had an old dwell meter/tach he tore apart and installed in the firewall. I don't think it was really hardwired, tho. Very functional, but it just didn't look great, like a normal gauge installation. I always thought a tach on the firewall might be usefull for tuneups and carb work.
  14. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I had an ammeter under hood of my 75 Duster. It was cool when I was 18....
    I like the look of them generally, I think it was a '60s thing? I still may do that on the 50 Burb, I have a nice flat area that needs something.
  15. I have a tach under the hood of the Hup. Handy for carb setup and I couldn't find room inside to put it.
  16. klazurfer
    klazurfer
    This setup will be mounted on my `32 Firewall . Not sure if I ever will need them , but I belive they will look cool :)
    Klaz
