Firewall help !!!!
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Oct 19, 2003.
  1. Toqwik
    Toqwik
    Well, motor and ****** are in and its time to wack the firewall. My biggest concern is where the column will go thru the firewall. anyone with ideas or pics how they did theirs. Been seriously thinking bout just mounting my body about an inch back, then I wouldn't have to wack my firewall at all, just modify for the distributor. Come on, someone step up and help.....Scott
  2. jerry
    jerry
    find a piece of tubing that that wiil slip over the columm shaft. weld on a couple of nuts to hald the columm anf use set screws to hold it. weld into the floor board. or to a plate that will bolt to the floor .
    jerry
  3. Toqwik
    Toqwik
    No one has build pics of their A's ???
  4. Fat Hack
    Fat Hack
    from Detroit
    If moving the body back an inch will give you the room you need with only a small mod needed for the distributor, I would go that route myself.
    Of course, then your rear wheels will sit an inch farther forward on the body unless you make a change there, and your hood won't fit without moving the radiator shell back...but you weren't gonna run a hood anyway, right??
  5. Dads56
    Dads56
    Toglink... I havn't been here in a while... What's your setup.. motor, body, steering, etc. My son and I just cut our firewall for the stering shaft, were using an F1 column and will use the original F1 jacket. We plan on mounting it low with the origianl F1 column mount and mounting the upper end with a whacked off and weleded connecting rod... I will have some pics hopefully in a few days.
  6. Dirk35
    Dirk35
