Projects Firewall Mount Brake Pedal Mounting
Discussion in 'The Hokey Ass Message Board' started by swade41, Sep 30, 2022.
  1. swade41
    swade41
    from Buffalo,NY
    I'm moving the brake pedal from under the floor up to the firewall on my 57 chevy pickup, for a variety of reasons, and there's a few different methods to accomplish this.
    The braket I'm using is for a power setup with booster, which I'm not using, now of course the master mounted to the booster in that application, which leads me to the discussion.
    I could simply drill holes through the firewall and into the pedal bracket to hold the master or make a plate with a couple studs pointing towards the radiator and sandwich that between the master and the firewall the plate would be bolted to pedal bracket sandwiching the firewall.
    The holes look as if they would fall inline with the 4 holes for the bracket, so I either drill 6 mounting holes in the firewall or 4 and use the plate with the 2 studs to hold the master.
    Any other ways to go about this ?
    There's at least 3 inches of clearance between the pushrod clevis and back of master
  2. Motorwrxs
    Motorwrxs
    Hope to see more pics of the install…thinking 4 holes would be the way to go
  3. Phil P
    Phil P
    I would go with the 6 bolts. It would be easiest and would look the same looking from the engine compartment. You may need to do something with your pedal ratio because it the bracket is intended for power brakes.
    Phil
    seb fontana likes this.
  4. Crusty Chevy
    Crusty Chevy
    Did this once and the firewall flexed with each push of the pedal. Keep and eye on flex and if needed add a large reinforcing plate, it is what I had to do.
  5. swade41
    swade41
    from Buffalo,NY
    That's why I was leaning towards the plate with 2 studs, less holes in the firewall and the firewall would be sandwiched between the 2 plates.
  6. gene-koning
    gene-koning
    The rear most bolt holes on your pedal bracket bolt to the bottom of the dash, at the steering column. Between the firewall, and the bottom of the dash, a lot of flex will be eliminated.
    A larger footprint on the firewall will reduce the flex even more. If you can incorporate a bracket to the top of the dash, or the windshield reinforcing area, that too would help.
    I have a couple pictures of the in process pedal bracket installation on my 49 truck. Please excuse the late model steering wheel & column. The pictures were taken early in the process, so the dash was not present at the time (the dash bolted to the steering column mount, from the side of the firewall on one side, across the car to the other side, and was also attached to the flange at the windshield as well, the same flange that upper bracket is bolted to). I also don't believe I have the top bracket bolted to the windshield reinforcement in the pictures either, but I think you can get the idea. I've done the last 4 vehicles this way, no flex can be felt or seen.
    This particular build used a modern stamped steel firewall with built in bead rolls, so no extra reinforcing of the firewall itself was required. Had the fire been a flat piece of sheet metal, I would have welded about a 10" x 10" piece of 1/8" sheet steel to the flat firewall, centered around the master cylinder mount. Then the pedal bracket, and the master cylinder would have been bolted on to the 1/8" plate, using the same bolts if possible. The 1/8" plate is strong enough that the master and the pedal bracket can be bolted separate if need be, but you want to keep the center hole as small as possible if they are bolted separately.
    swade41, ekimneirbo and gimpyshotrods like this.
  7. bobss396
    bobss396
    I made a large steel plate on my Ford from 1/4" stock. I also have the clutch master attached to it. Sort of hard to see but it does the job.
    swade41, ekimneirbo and ramblin dan like this.
  8. lostone
    lostone
    from kansas
    I agree with above, I would add a stiffener plate to the inside of the firewall and put a bunch of spot welds around the perimeter of the plate then add some spot welds thru the center.
    I would also round the corners of the plate, say atleast a 1" radius that way you don't create stress points that may start cracking at the sharp corners of the plate into the firewall.
    I wouldn't see a need for anything heavier than 1/16" thick plate depending on how large you make it but I'd go 2 or 3 inches bigger than the bracket.
    swade41 and ekimneirbo like this.
  9. 1940Willys
    1940Willys
    My 37 has this. Wilwood hanging pedal setup. Clutch Slave Master is buried. I'll try and get pics from the other side. DSCN8027.JPG
  10. TA DAD
    TA DAD
    from NC
    I installed swinging pedals in the Studebaker and added a 1/8 inch plate tacked to the firewall and it is IMG_0060.JPG also attached to the dash were I installed a 1inch square tube running the width with a couple pieces of tubing from that to the firewall and those bolt into a piece of 1 inch on the engine side of the firewall . And it used four bolts for the pedal ***embly , plus the two for the master cyl. Mine is a little different than yours but you can never have it to strong.
    ekimneirbo likes this.
  11. squirrel
    Years ago I put a pedal on the firewall of my 39 Chevy sedan. I added a couple pieces of small square tubing from the bottom to the top of the firewall, on either side of the pedal ***y, it kept it from flexing. I welded them in before painting the car, of course.
    I love me the original pedal location on these trucks though, because natural leg motion is in the right direction. Something about ergonomics. But what do I know, I've only been driving one for 45 years.
    lumpy 63, Irish Mike and bobss396 like this.
  12. Bandit Billy
    Bandit Billy
    I went with a hanging pedal in my 41 PU under construction to make room under the car for a large transmission.
    I went with power brakes but I built a steel bracket that I welded to the outside of the firewall to hold the brakes and pedal ***embly and smoothed it all in so it would look like it belonged there and not an afterthought. It also allows a flush fitment of the booster bracket against the firewall that 'taint flat.
    I built a brace form the pedal bracket to the dash that is secured by the bolts that hold the column drop.
    And then added an adjustable brake switch bracket I fabbed up. Lightening holes in the brake pedal don't compensate for the extra steel and weight added in it's production. Pedal arm is now chromed, bracket is gloss black powder coat.
  13. swade41
    swade41
    from Buffalo,NY
    On my Henry J I used an aluminum plate between the master and firewall, I haven't had any flexing issues, the pedal bracket is also bolted to the dash and firewall.
    I won't be doing this brake pedal install on the 57 anytime soon but just trying to get my ducks in a row.
    TA DAD, LOST ANGEL and Bandit Billy like this.
  14. Kerrynzl
    Kerrynzl
    No welding needed.
    Use a decent urethane glue and it will be a lot stronger than spot or s***ch welds.
    Use Bostik ISR 70-03
    The anchor plates for the 5-point harness in my race car are attached with this sh*t
    As well as the alloy deck and fenders on my car hauler trailer.
    Kustomline54 likes this.
  15. 1971BB427
    1971BB427
    from Oregon
    When I did this on my '39 Chev coupe I made up a plate as large as the area inside the firewall would allow. That turned out to be about 14" square. I used 1/4" plate, and drilled and tapped holes for 3/8" bolts just because I wanted to not have to have somebody on one side holding bolt heads or nuts and I could do the installation by myself. I used longer grade 8 bolts for the two bolts that hold the new master, so once threaded through the plate and firewall I could slide the master in -place and put nuts and lockwashers on the master cylinder.
    The large plate worked out well, and stiffened up the firewall. But I also made a bracket to tie the pedal ***embly to the bottom edge of the dashboard too, just to give added strength.
  16. blue 49
    blue 49
    from Iowa
    My Henry J pedal ***embly "footprint" is less than 5" wide so I made a stiffener out of 2 X 5 14 ga rectangle tubing that goes from the toe board up to a 90 deg. stiffener bend in the lower firewall. It also attaches the steering column bracket that also mounts to the bottom of the dash.
    Gary
    bobss396 likes this.
  17. jimmy six
    jimmy six
    I’d use a 4 plate with the MC in the center like the photos. You may want to go to a booster at some time. With my eyes it looks like the ratio is about 6-1. With. 7/8” MC it should feel like power. I personally don’t like the look of vacuum booster cans and would rather work with MC cylinder diameter and pedal ratios.
    Irish Mike and swade41 like this.
  18. bobss396
    bobss396
    I should have backed mine up on the inside too since I still get a little flex. Something like 3/16" would have been good. I did tie the exterior plate into the pedal mount bracket.
  19. swade41
    swade41
    from Buffalo,NY
    Yeah I'm not a fan of how far out the booster/master combo sticks out from the firewall, I want the focus to be on the engine, not 2 feet of brakes blocking the view.
    Roothawg and Bandit Billy like this.
  20. Bandit Billy
    Bandit Billy
    Oh, it doesn't block the view all that bad. If it does you need a bigger engine. :cool:
    LOST ANGEL, lostone and firstinsteele like this.
  21. swade41
    swade41
    from Buffalo,NY
    Yes you do need a bigger engine
    Look at how that setup sticks out like a buzzard's beak on a 55-59, no thank you
  22. Bandit Billy
    Bandit Billy
    swade41 and LOST ANGEL like this.
