Any thing special we need to know about building the firewall for our HA/GR car? Gauge metal? Insulation? Also ****** is attached to a '49 Merc or truck Steel bell but ****** has the large cast bell that attaches to it. Flywheel, clutch disk and pressure plate are covered by the steel bell. Need a ****tershield? Recommended thickness? Sorry for the questions but need to get it right the first time. Thanks in advance. Jim
Jim, I'm no expert on this, but I used the same gauge metal that I made the sides out of for my firewall. It is probably 14-16 gauge. As far as the ****tershield, I had to make mine as the ****** is aluminum. Try and find one for a slant six truck ******.
We also made our firewall with the same gauge aluminum as the side body panels. I think it was 050 aluminum. I dont know about this cl*** but on our flathead powered bonneville truck we had to make a 1/4 inch wrap around the factory bell housing in the clutch and flywheel area. The scta wont allow just the ford merc housing for some reason. Beats me on this one though??.
our firewalls were 1.6mm alloy (same as the rest of the body panels), and we made a 1/4 mild steel ****tershield to suit...whilst a bit more weight added, it gave us something to lock our firewall into, as well as the floor panel. We like having toes on our feet. Cheers, Drewfus
Roger that, get a piece of stainless, or at least use an old galvanized trashcan if you want a real period look to it. Burns hurt for a long time, better to try and avoid them.
