firing order 48 chevy
Discussion in 'The Hokey Ass Message Board' started by Huckster59, Dec 7, 2009.
  1. Huckster59
    Huckster59
    can someone tell me the firing order straight 6 and also where #1 is on cap. thanks
  2. Ebbsspeed
    Ebbsspeed
    Contrary to what some may say, #1 can be anywhere on the cap except, of course, the center terminal. Whichever terminal the rotor lines up with when cylinder #1 is ready to fire is where the number 1 wire goes, and then the rest follow based on distributor rotation and firing order. To approximate when #1 cylinder is in firing position, pull the plugs, seal the #1 plug hole with your finger, then slowly turn the motor over by hand. You'll feel pressure build when it's coming up on compression. At this point you should be able to feel the position of the #1 piston with a carefully bent piece of wire fed through the spark plug hole. I believe on a 235 Chevy you can actually see the piston near/at TDC through the plug hole with a carefully aimed light and a sharp eye. If not, use the bent wire to keep track of where the piston is. Keep turning the motor until the piston is at the top of the cylinder. Now pull the distributor cap off, and whatever terminal the rotor is pointing to is #1. This rotor position can be changed by lifting the distributor and turning the rotor to wherever you need it to point, then dropping the distributor back in. The turn the engine over slowly by hand until the distributor drops all the way in when the oil pump tang re-engages.
  3. Huckster59
    Huckster59
    checked the firing order,1 wire was crossed ,that was my popping .changed it ,filled the float bowl with gas and cranked her over spit a couple of times ,sanded points a little .tried her again,it started ,has not been started since 1972,ran until gas ran out . got 3 dead mice out of the tailpipe and a bucket of acorns and peanuts .did a couple of adjustments to the carbs and it ran on its own,did not run it to long ,no coolant ,changed the oil ,it had at 10 to 15 qts in it and a little condensation,not bad for not being started since 1972,pulling the gas tank and fuel pump tuesday ,where is the best place to get brakes ?
  4. sdluck
    sdluck
    Some cars have a position the dist needs to be in to direct oil,which is why no 1 position is important.
  5. you might want to use the 48' as your avitar instead of the camaro. really surprised nobody "flamed" you about it. nice camaro though.
  6. LAROKE
    LAROKE
    The easy to remember this is that "fifteen is too young, thirty-six is too old and twenty-four is just right"
  7. Huckster59
    Huckster59
    IS THAT BETTER ,its my 48 .
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...plus, although it's probably a bit crusted over by now, a '48 should have the firing order cast on the front half of the exhaust manifold.
  9. RichG
    RichG
    I learned that when I was 16 years old...and have never forgotten it:p
  10. sure is! cool ride there and no chance of "flameage dude"! just hate to see a fellow hamber get torched thats all. lets see more pic's of your 48'.:D
  11. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Agian 153624...........
  12. truckncoupe
    truckncoupe
    Yep, 153624! Good luck!
  13. Huckster59
    Huckster59
    i got the to old thing now ,just caught it. hell im 50
  14. Ebbsspeed
    Ebbsspeed
    True, but the position of the distributor body has no bearing on where the #1 wire goes on the cap. That is all dependent upon the meshing of the distributor gear with the cam. Hence, the #1 position is NOT important, but the positioning of the distributor body is.
  15. el conejo 1964
    el conejo 1964
    so, will you change your handle when you're 51? ;)
  16. Huckster59
    Huckster59
    50 was my dodge ,would like to change it to 48.how do you do that
  17. Huckster59
    Huckster59
    now thats service ,they changed it for me to 48
